Atom Feed | View unanswered posts | View active topics It is currently 28 Apr 2024 10:49
Reply to topic  [ 7 posts ]
Knowledge Base (2003)
It's taken from my local archive - in 2003 it was copied from petersplus.com web-site (creators of computer Sprinter).
How-to articles
Q10001. How to parse the command line in my programm?
Summary
This article contain example for getting command line.
More information
   ORG   8100h-512
;EXE-file header:
   dw   5845h     ; EXE Signature
   db   45h     ; Reserved (EXE type)
   db   00h     ; Version of EXE file
   dd   00000200h ; Code offset
   dw   0000h     ; Primary loader size or 0 (no primary loader)
   dd   00000000h ; Reserved
   dw   0000h     ; Reserved
   dw   START     ; Loading address
   dw   START     ; Starting address (register PC)
   dw   0BFFFh     ; Stack address (register SP)
   ds   490     ; Reserved
;code of program
START   PUSH   IX   ;IX pointer to Command line parameters
   POP   HL   ;ld hl,ix
   INC   HL   ;skip size of Command line
         ;Now, HL pointer to first simbol of parameters
         ;If you typed "TEST.EXE Hello", then HL pointer to " Hello"
         ;with first space.
   LD   C,5Ch   ;system call number (PCHARS)
   RST   10h   ;call kernel
;return from your program
   LD      C,41h   ;system call number (EXIT)
   RET
24 April 2002.
PETERS PLUS LTD.
Q10002. How to access the modem from Sprinter computer?
Summary
This article describe ISA-8 interaction.
More information
If you want to interaction with ISA devices, you have to make following steps:
1) send 10h value to port 1FFDh(system port);
2) send control byte to port 0E2h(third memory window port);
control byte (corrected in Jan 2021):
;D7...should be 1
;D6...should be 1
;D5...should be 0
;D4...should be 1
;D3...should be 0
;D2...specify access mode (0 - ISA memory, 1 - ISA ports)
;D1...specify index of ISA slot (0 - ISA#1, 1 - ISA#2)
;D0...should be 0
The read/write signals are forming from read/write signals memory range 0C000h-0FFFFh.
And the address lines A13...A0 has taken from processor data-BUS. The other ISA-signals such as RESET, AEN, A19...A14 can be set in port 9FBDh. And default value is 00h.
port 9FBDh:
D7...RESET
D6...AEN
D5...A19
D4...A18
D3...A17
D2...A16
D1...A15
D0...A14
ISA_DIR      EQU 9FBDh
SC_PORT      EQU 1FFDh
PAGE3        EQU 0E2h
SAVE_PAGE    DB 0           ;variable for previous status of third memory port
RESET_ISA:                  ; reset ISA device
        LD C, ISA_DIR
        LD A,0C0h
        OUT (C),A
   CALL Pause_10ms
        LD A,0
        OUT (C),A
        RET
Pause_10ms:
        LD HL,10000
Loop:
        DEC HL
        LD A,H
        XOR L
        JR NZ,Loop
        RET
OPEN_ISA_PORTS:             ; open access to ISA
        LD BC,SC_PORT
        LD A,11h ; <<<<<<<<<< corrected in Jan 2021
        OUT (C),A
        IN A,(PAGE3)        ; read value from memory port
        LD (SAVE_PAGE),A    ; save previous status of memory port
        LD A,0D4h           ; control byte for (ports of the 1st ISA slot)
        OUT (PAGE3), A      ; opening ISA port address space
        LD C,ISA_DIR
        LD A,0              ; high ISA addresses RESET and AEN signals.
        OUT (C),A
        RET
CLOSE_ISA_PORTS:            ; close access to ISA
        LD A,(SAVE_PAGE)
        OUT (PAGE3),A       ; restore value of memory port
        LD BC,SC_PORT
        LD A,1 ; <<<<<<<<<< corrected in Jan 2021
        OUT (C),A           ;
        RET
WRITE_ISA_PORT:
        LD HL,ADRESS_PORT+0C000h     ; ISA port address + 0C000h offset 3
memory page
        LD A,DATA_OUT                ; data for writing
        LD (HL),A                    ; write data to port which pointered HL
        RET
READ_ISA_PORT:
        LD HL, ADRESS_PORT+0C000h    ; ISA port address + 0C000h offset 3
memory page
        LD A,(HL)                    ; read data from port which pointered HL
        RET
When you work with ISA, the access to third memory page are disabled. If you want to address ISA-memory more than 3FFFh, you should specify high bits in port 9FBDh.
27 April 2002
PETERS PLUS LTD.
Q10008. How to make Sprinter's EXE program?
Summary
This article contain simple example of Sprinter's EXE program.
More information
You can use any assemblers, which have Z80 support. You have to add Sprinter's EXE-header only.
        ORG     8100h-512
;EXE-file header:
        dw 0000h     ; Reserved
        ds 490       ; Reserved
;code of program
START
;your program here
        LD BC,0041h  ;exit with 0 error code
        RST 10h      ;system call
        RET
Also, we recommend to you use as STACK address value between 8000h-0BFFFh. It will care you to avoid mistakes with STACK. The DSS and BIOS functions can opened another memory pages in third memory window 0C000h-0FFFFh.
30 May 2002.
PETERS PLUS LTD.
Q10010. How to use FastRAM?
Summary
This article describe features of using FastRAM.
Guide
For activating FastRAM you need execute CPU instruction IN A,(#FB). After that, in the first memory frame (0000h-3FFFh) will paged empty 16K of FastRAM memory. You may use this memory for more fast routine speed. FastRAM not require any allocation calls for use it. And you shouldn't stored the actual data there.
Remember, if you execute external program, it may destroy your data and code in FastRAM.
And you must do copy your code to FastRAM again for restore it.
Also you can't call BIOS or DSS function during FastRAM are activated.
For deactivating FastRAM you need execute CPU instruction IN A,(#7B).
After that, a first memory frame will paged back 16K of normal memory.
We recommend to disable interrupts for avoid any errors when you will switch FastRAM.
More information
Today, only 16K of FastRAM are available for use.
If you want to use the interrupts, you should put interrupt handler in #0038.
If you plan to use Accelerator in your FastRAM-routine, you must placed data for it more high than #3FFF.
FastRAM will be useful in following cases:
1. If you not use the Accelerator.
2. If you use the RAM data not so often.
3. If program stack was placed into the FastRAM.
1 August 2002.
PETERS PLUS LTD.
Q10015. How to load any palette or separate color?
Summary
This article contain examples of loading a palette and separated color.
More information
;Set 5th color as GREEN
      LD   HL,COLOUR
      LD   DE,#0105
      LD   BC,#FFA4
      XOR   A
      RST   #08
;          B   G   R
COLOUR      DB   #00,#80,#00,#00
;Change all colors of palette
      LD   HL,COLOURS
      LD   DE,#0000
      LD   BC,#FFA4
      XOR   A
      RST   #08
;Color's parameters
;          B   G   R
;Palette
COLOURS      DB   #00,#00,#00,#00   ;Colour 0
      DB   #00,#00,#80,#00   ;Colour 1
      DB   #00,#80,#00,#00   ;Colour 2
      DB   #00,#80,#80,#00   ;Colour 3
      DB   #FF,#FF,#FF,#00   ;Colour 255
19 March 2003.
PETERS PLUS LTD.
Q10017. How the DSS/BIOS can be paged out and replaced with RAM at $0000-$3fff?
Summary
This article contain an example of replacing memory page.
More information
You should disable interrupt before replacing memory page.
Replace
        DI             ; disable interrupts
        IN A,($82)     ; get page which set $0000-$3FFFF
        LD (DSSPAGE),A ; store dss page number
        LD A,your_page ;
        OUT ($82),A    ; replace it with your page.
Restore
        LD A,(DSSPAGE) ; restore dss page number
        OUT ($82),A    ; back dss page
        EI             ; enable interrupts
7 April 2003.
PETERS PLUS LTD.
Q10021. How to call an Estex application from my program?
Summary
This article contain example for calling an external program.
More information
   LD   HL,prog
   LD   BC,DSS_EXEC
   RST   #10
prog   db   "prog.exe",0
7 May 2003.
PETERS PLUS LTD.
17 May 2013 22:36
Software issues
Q10005. Sometimes DOOM demo not work.
Symptoms
Error message of Spectrum Basic - "Out of memory".
Cause
Program need more memory. One or more RAM-disks are created.
Solution
1. Execute Setup Utility (by pressing "Delete" key during starting of computer)
2. Select 'Safe RAM-disks' item and disable it.
3. Press "F10" key for exit with changes.
30 May 2002.
PETERS PLUS LTD.
Q10011. FlashROM Writer work (update of BIOS) was aborted when the verify bar has reached its end.
Cause
First verifing is checking of integrity of the BIOSxxx.EXE file. Program work was aborted because check was finished not successfully.
Solution
1. Copy the BIOSxxx.EXE file to your disk by another floppy disk again.
2. Executing programm again.
7 June 2002.
PETERS PLUS LTD.
Q10016. The game Thunder In The Deep not works.
Symptoms
System message "Out of memory". There are no RAM-Disks in the memory.
Cause
Program requires more memory. Several programs were run before start of the game.
Solution
Run the game in Flex Navigator or in User Menu or in command line after computer reset.
3 April 2003.
PETERS PLUS LTD.
17 May 2013 23:16
Hardware issues
Q10003. Hard disk was detected, but Estex DSS not start.
Symptoms
BIOS wrote "Detecting IDE Primary Slave - None"
Cause
Some old hard disks can't was detected as single hard disk.
Solution
1. Enter to the Setup Utility (by pressing "Delete" key during starting of computer)
2. Select 'IDE Slave' item and disable it.
3. Press "F10" key for save setting and exit.
30 May 2002.
PETERS PLUS LTD.
Q10004. Sprinter computer not work with two 3.5" floppy disk drives (FDD).
Symptoms
Two 3,5" FDD was connected to the crossed FDD ribbon cable. FDD "A" not work.
Cause
Usage of crossed FDD ribbon cable.
Solution
Use FDD which has jumper "A/B device" and FDD ribbon cable from Sprinter's mainboard package. If you haven't Sprinter's FDD ribbon cable, make Sprinter's FDD ribbon cable from a standard FDD ribbon cable. You should uncross the cable.
30 May 2002.
PETERS PLUS LTD.[/b]
Q10006. Video cable for Amstrad CTM644 monitor.
Summary
This article include info of video cable pins for Amstrad CTM644 monitor.
More information
CTM644 pins      Sprinter DB15 pins
   2                  GND 1
   4                  composite sync 13
   6                  green 10
   7                  red 11
   8                  blue 9
30 May 2002.
PETERS PLUS LTD.
Q10007. How to install CD-ROM drive?
Summary
This article describe CD-ROM drive installation.
WARNING! Installing a new drive such as a CD-ROM drive or hard disk involves opening computer cover, and handling internal cables and wiring. Because of this, you should not try to install a CD-ROM drive or hard disk unless you are already very familiar with the process. For information about how to install a CD-ROM drive or hard disk, contact the manufacturer of the device, or view the documentation included with your device.
Solution
1. Check jumper position at the back side of the CD-ROM drive. CD-ROM drive must be set as Slave device if you have installed HDD as IDE Master.
2. Switch off your computer.
3. Install your CD-ROM drive in the computer case.
4. Switch on the computer.
5. Check BIOS autodetection message for SLAVE IDE device. BIOS must detect your CD-ROM drive and write its name.
More Information
Also you can specify CD-ROM drive for the IDE SLAVE manually by Setup Utility.
1. Enter to the Setup Utility (by press "Delete" key when a computer starting).
2. Select "IDE Slave" item and change it to the "CD-ROM".
3. Press "F10" key for exit with save changes.
19 June 2002.
PETERS PLUS LTD.
Q10012. Hard disk was detected, but BIOS says "Invalid partition table"
Symptoms
600Mb-2Gb hard disk was detected by BIOS, but then BIOS says "Invalid partition table".
Cause
Your hard disk hasn't "partition table" or uses another partition code, not 0x01 (FAT12), 0x04 (FAT16 'old' up to 32M), 0x06 (FAT16 over 32M), 0x0E (FAT16 'win95' LBA-mapped). Probably, it is 0x0B (FAT32 'win95'), 0x0C (FAT32 'win95' LBA-mapped), 0x1B (FAT32 'hidden'), 0x1C (FAT32 'hidden' LBA-mapped) or another code.
Solution
You should prepare your hard disk as MS-DOS FAT16 disk before formating it.
5 January 2003.
PETERS PLUS LTD.
Q10013. Hard disk was detected, but BIOS says "Invalid BOOT sector".
Symptoms
Hard disk was formated with boot sector, but computer .
Cause
Your hard disk was prepared as MS-DOS FAT32 disk. FAT32 and FAT16 has boot sectors with different structure.
Solution
You should prepare your hard disk as MS-DOS FAT16 disk and format it again with boot sector.
5 January 2003.
PETERS PLUS LTD. [/b]
Q10014. I've made a connector to load stuff from Tape but it not work.
Symptoms
Occasional flickering on load "".
Cause
Too high CPU frequency.
Solution
You should disable Turbo Mode by pressing F12 key before usage a Tape.
1 February 2003.
PETERS PLUS LTD.
17 May 2013 23:19
Programming
Q10009. Screen memory location.
Summary
This article contain usage examples of graphic modes.
More information
Today, Estex DSS support four screen modes: text 40x32 with 16 colors (mode 02h); text 80x32 with 16 colors (mode 03h); graphic 320x256 with 256 colors (mode 81h); graphic 640x256 with 16 colors (mode 82h); The default mode for the DSS is 80x32 text mode, if your program need another screen mode then you need to switch it by DSS function 50h (SETVMOD). Also before switching you should ask DSS and save current screen mode by function 51h (GETVMOD). And when you program will be ready to finished, restore it by 50h (SETVMOD). for example:
   LD   C,51h   ;get screen mode
   RST   10h
   LD   C,A   ;move mode number to register C
   PUSH   BC   ;and save to stack BC (B - active page, C - mode)
   .       ;your program
   POP   BC   ;restore mode from stack
   LD   A,C   ;move screen mode to register A
   LD   C,50h   ;set screen mode
   RST   10h
   LD   C,41h   ;terminate program
   RST   10h
DSS has some functions for outing symbols and strings at the text screen. But for the graphic modes you need to write it yourself. for example:
   LD   HL,STRING   ;pointer to the string
   LD   C,5Ch      ;outing string
   RST   10h
STRING   DB   "Thank you for using my program..."
   DB   13,10      ;CR and LF codes
   DB   0      ;End of string
For painting at the graphic screen memory, you need to set one of three memory frames 04000h-07FFFh, 08000h-0BFFFh, 0C000h-0FFFFh. It can be made by set value 50h to the ports 0A2h, 0C2h or 0E2h. Don't forgot about STACK place! for example: if you want to set one point then routine for 81h mode will look like:
; HL - x coord
; DE - y coord
   IN   A,(0E2h)   ;read page number
   LD   C,A      ;move it to C (save)
   LD   A,50h      ;page of video RAM
   OUT   (0E2h),A   ;set it to third frame 0C000-0FFFFh
   LD   A,E      ;Y-coord (0...255)
   OUT   (89h),A      ;set to Y-port
   LD   DE,0C000h   ;frame address
   ADD   HL,DE      ;add x-coord
   LD   A,255      ;point color (0...255) (index to palette)
   LD   (HL),A      ;put pixel
   LD   A,C      ;restore page number
   OUT   (0E2h)      ;set it
Note: Before it, you need to set required colors at the palette.
30 May 2002.
PETERS PLUS LTD.
17 May 2013 23:29
Routines collection
Q10018. Routine of transformation of half-byte to ASCII symbol.
Assembler
Any assembler.
Input
A = low 4 bits
Output
À = ASCII symbol (0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F)
Routine
        And  #0F
        Cp   #0A
        Sbc  #69
        Daa
Added by
Mac Buster
Q10019. Routine (GetSwitch) of filling of ASCIIZ buffer with the command-line parameter value.
More information
Routine fills an ASCIIZ buffer with the string after the "=" sign of a predetermined command-line switch of the form /SWITCH=VALUE. The switch name is *NOT* case sensitive.
Assembler
Any assembler.
Input
(SP+0)=Ret address
(SP+2)=Address of cmdline ASCIIZ string, preceded by its len in ONE byte
(SP+4)=Address of ASCIIZ parameter to find its value
(SP+6)=Address of ASCIIZ buffer to fill with the parameter's value
Output
Carry flag reset=OK
Carry flag set=Error (no chars in cmdline, etc)
A : Zero
BC: Amount of chars remaining in command line
DE: Points to the terminating NULL of the buffer to fill
HL: Points to one after the last byte copied from the cmdline
Routine
GetSwitch:   POP   HL      ;Fetch return address in HL
      POP   DE      ;Fetch cmdline address in DE
      POP   BC      ;Fetch param address in BC
      EX   (SP),HL      ;Push ret addr, buffer addr to HL
      LD   (GS_Param),BC   ;Save param ASCIIZ address
      LD   (GS_OutBf),HL   ;Save output buffer address
      EX   DE,HL      ;CmdLine to HL, OutBuff to DE
      LD   C,(HL)      ;CmdLine len to C (just-a-byte)
      LD   B,0      ;Hi-byte of BC is zero
      INC   HL      ;Point to first char in CmdLine
GS_GetSlash:   LD   A,"/"      ;Char to find to A
      CPIR         ;Find the slash
      JR   Z,GS_ChkParam   ;Slash found. Check param.
      JR   GS_Error   ;Outta chars or no slashes!
GS_ChkParam:   LD   DE,(GS_Param)   ;Param name address to DE
      DEC   HL      ;Compensate for first INC HL
GS_CP_Loop:   DEC   BC      ;Take char into account
      INC   HL      ;Point to next char
      LD   A,(DE)      ;Param name char to A
      INC   DE      ;Point to next char in param name
      OR   A      ;Is End Of String?
      JR   Z,GS_Found   ;Jump if so: Param found!
      CP   (HL)      ;Same as (HL)?
      JR   Z,GS_CP_Loop   ;Continue if so
      XOR   020h      ;Toggle uppercase/lowercase bit
      JR   Z,GS_CP_Loop   ;Jump if so
      JR   GS_GetSlash   ;Bad param: Continue search for "/"
GS_Found:   LD   A,(HL)      ;Char should be "="
      CP   "="      ;Is it?
      JR   NZ,GS_GetSlash   ;Jump back if not: Wrong param
      INC   HL      ;Point to char after equals sign
      LD   DE,(GS_OutBf)   ;DE points to start of buffer
GS_CopyBuff:   LD   A,(HL)      ;Move value char to A
      CP   " "      ;Is space?
      JR   Z,GS_Done   ;Jump if so. Transfer finished
      CP   00h      ;End of cmdline?
      JR   Z,GS_Done   ;Jump if so. No more to transfer
      LD   (DE),A      ;Copy char to output buffer
      INC   DE      ;Point to next placeholder
      JR   GS_CopyBuff   ;Loop back until done
GS_Done:   XOR   A      ;Reset A
      LD   (DE),A      ;Terminate the string
      RET         ;Done :)
GS_Error:   SCF         ;Flag "ERROR!!!"
      RET         ;Done :(
GS_OutBf:   DB   00h,00h      ;Output buffer address
GS_Param:   DB   00h,00h      ;Parameter name address
Added by
Marcelo Lopez
Q10020. Routine (ExpandMacros) of expanded macros in an ASCII buffer with the nth ASCIIZ string from another buffer.
More information
Will replace occurrences of "%1" to "%9" in an ASCIIZ buffer for the Nth ASCIIZ string from a parameter buffer, delivering an ASCII (not ASCIIZ) string in a supplied address. The parameter string block MUST start with a NULL char (ASCII 0).
Example:
   Src:   DB   "Marcelo %1 %2."
   Param:   DB   00,"made",00,"me.",00
   Desti:   DB   00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
After executing the routine, DESTI will hold the following string (note that the destination string is not ASCIIZ):
   Desti:   DB   "Marcelo made me."
Assembler
Any assembler.
Input
(SP+6) -> Source buffer start address (Src in the example)
(SP+4) -> Param buffer start address (Param in the example)
(SP+2) -> Destination buffer start address (Desti in the example)
(SP+0) -> Normal return address
Output
A : Zero
B : Zero (if strings replaced), Hi byte of param buff addr if not
C : Low byte of parameter buffer address
DE: Pointer to the last byte in the output buffer + 1
HL: Pointer to the last byte in the source buffer + 1
Routine
ExpandMacros:   POP   HL      ;Fetch ret addr briefly
      POP   DE      ;Fetch OutBuffer in DE
      POP   BC      ;Fetch ParBuffer in BC
      EX   (SP),HL      ;Exchg Ret to (SP) and RawBuff to HL
EM_SavePtr:   LD   (EM_PBuff),BC   ;Save param buffer ptr
EM_Loop:   LD   A,(HL)      ;Char to A
      OR   A      ;Is it a zero?
      RET   Z      ;Finished if so
      CP   "%"      ;Is it the macro indicator?
      JR   NZ,EM_CopyChr   ;Jump if not
      LD   A,(HL)      ;Char after "%" to A
      CP   "0"      ;Is char > "0"?
      JR   NC,EM_ChkNine   ;Jump if so
EM_CopyPct:   LD   A,"%"      ;Restore percentage sign in A
      JR   EM_CopyChr   ;And transfer it to out buffer
EM_ChkNine:   CP   "9"      ;Is char lower than "9"?
      JR   NC,EM_CopyPct   ;Jump if not to transfer the "%"
      SUB   "0"      ;Now is 0 <= A <= 9
      PUSH   HL      ;Save input buffer pointer
      LD   HL,(EM_PBuff)   ;Get Param Buffer address in HL
      LD   B,A      ;Param number to B
      XOR   A      ;Reset A to zero
EM_FindPar:   PUSH   BC      ;Save counter in B
      LD   BC,0      ;Prepare to loop thru 64K
      CPIR         ;Look for a zero char
      POP   BC      ;Restore zeroes counter
      DJNZ   EM_FindPar   ;Loop back until param is found
EM_CopyPar:   LD   A,(HL)      ;Param char to A
      INC   HL      ;Point to next char in param
      OR   A      ;Is it zero?
      JR   NZ,EM_CopyPar2   ;Go on to copy char
      POP   HL      ;Restore main in buffer pointer
      INC   HL      ;Skip param number
      JR   EM_Loop      ;And continue looping
EM_CopyPar2:   LD   (DE),A      ;Copy char in param to output buffer
      INC   DE      ;Advance out buffer pointer
      JR   EM_CopyPar   ;And loop thru all chars in param
EM_CopyChr:   LD   (DE),A      ;Copy char in main to output buffer
      JR   EM_Loop      ;And loop thru all chars in main
EM_PBuff:   DW   0000h      ;Param buffer save zone
Added by
Marcelo Lopez
17 May 2013 23:59
Routines collection (cont.)
Q10022. Routine (Ascii2Word) of converting an ASCIIZ buffer with numbers to a word.
More information
Routine converts an ASCIIZ number to a 2-byte value. The number can have a prefix character to preset the number base. In case of hex numbers, the letter case does NOT matter. This routine DOES NOT deal with negative or fractional numbers. All returned values are positive. The routine will work with values in the range 0 - 65,535 (dec), 0 - FFFF (hex), 0 - 177777 (oct), or 0 - 1111 1111 1111 1111 (bin).
Prefix:
"@": Means OCTAL number follows (ex: @345; bad ex: @87)
"#": Means HEXADECIMAL number follows (ex: #F00f; bad ex: #G0)
"%": Means BINARY number follows (ex: %1010; bad ex: %5)
'no prefix': Default, for DECIMAL numbers (ex: 987; bad ex: 3A57)
Assembler
Any assembler.
Input
(SP+2) -> ASCIIZ string starting address
Output
Carry flag reset: Operation was successful.
A=Lo-byte of converted word
HL=Converted word
Carry flag set: Error (overflow or invalid char in buffer)
Routine
Ascii2Word:   POP   HL      ;Fetch ret addr briefly
      EX   (SP),HL      ;Exchg Ret (SP) with BufferAddr (HL)
A2W_Init:   LD   DE,0      ;Reset...
      LD   (A2W_RetVal),DE   ;...return value
      LD   A,(HL)      ;Get first char in buffer
      LD   C,0Fh      ;Prepare for HEX
      CP   "#"      ;Is HEX prefix?
      JR   Z,A2W_Nxt   ;Jump if so
      LD   C,07h      ;Prepare for OCT
      CP   "@"      ;Is OCT prefix?
      LD   C,01h      ;Prepare for BIN
      CP   "%"      ;Is BIN prefix?
      LD   C,09h      ;Ok, number is DEC
      DEC   HL      ;Compensate for next INC HL
A2W_Nxt:   INC   HL      ;Point to next char in buffer
      CP   0h      ;End of string?
      JR   Z,A2W_Done   ;Jump if so
      PUSH   HL      ;Save buffer address while adding
      LD   HL,(A2W_RetVal)   ;Get return value so far
      PUSH   HL      ;Copy HL to...
      POP   DE      ;... register DE
      LD   B,C      ;Get loop index to B
A2W_Add:   ADC   HL,DE      ;Perform sum...
      DJNZ   A2W_Add      ;... B times
      JR   C,A2W_Ovfl   ;Abort if overflow
      SUB   "0"      ;Convert ASCII in A to number
      CP   9      ;Less than 9?
      JR   C,A2W_Chk   ;Jump if so.
      RES   5,A      ;Force char uppercase (just in case)
      SUB   7      ;Deduct "A" - "9" diff.
A2W_Chk:   LD   E,A      ;Save number to E
      LD   D,0      ;Reset hi-byte of DE
      INC   C      ;Test if...
      CP   C      ;... A > C, and...
      JR   NC,A2W_Ovfl   ;... abort if so...
      DEC   C      ;... 'cos it's invalid char.
      XOR   A      ;Clear carry flag for next ADC
      ADC   HL,DE      ;Add the number to the return value
      JR   C,A2W_Ovfl   ;Jump if overflow
      LD   (A2W_RetVal),HL   ;Store result so far
      POP   HL      ;Fetch back string pointer
      JR   A2W_Nxt      ;Keep looping
A2W_Ovfl:   SCF         ;Set carry flag to say "Error!"
      POP   HL      ;Stack balancing
      RET         ;Return to caller
A2W_Done:   LD   HL,(A2W_RetVal)   ;Fetch return value
      LD   A,L      ;Lo-byte of result to A
      RET         ;Back to caller
A2W_RetVal:   DEFW   0000h      ;Return value storage
Added by
Marcelo Lopez
Q10023. Routine (Word2Hex) of preparing a 16 bit number to be printed in HEX form.
More information
Converts a 2-byte value to four hexadecimal characters. All values are considered positive. Uses Byte2Hex routine twice...
Assembler
Any assembler.
Input
(SP+4) -> Number to convert
(SP+2) -> Four-byte ASCII buffer start address
Output
ASCII buffer is filled with the converted number
A : Ascii code of lowest nibble of converted number
DE: Number to convert
HL: Pointer to last char in buffer
Routine
Word2Hex:   POP   DE      ;Get ret address temporarily
      POP   HL      ;Get Buffer address
      LD   (W2HBuf),HL   ;Save Buffer address
      POP   HL      ;Get Number
      LD   (W2HNum),HL   ;Save Number
      PUSH   DE      ;Push return address
      LD   L,H      ;MSB to LSB
      PUSH   HL      ;Push MSB
      LD   HL,(W2HBuf)   ;Retrieve buffer pointer
      PUSH   HL      ;Push buffer address
      CALL   Byte2Hex   ;Fill half buffer
      INC   HL      ;HL points to third char in buffer
      LD   DE,(W2HNum)   ;DE now holds LSB of Number
      PUSH   DE      ;Number to Stack
      PUSH   HL      ;Buffer to Stack
      CALL   Byte2Hex   ;Fill rest of buffer
      RET         ;Done.
W2HBuf:      DW   0000h
W2HNum:      DW   0000h
Added by
Marcelo Lopez
Q10024. Routine (Byte2Hex) of preparing an 8 bit number to be printed in HEX form.
More information
Converts a 1-byte value to four hexadecimal characters. All values are considered positive.
Assembler
Any assembler.
Input
(SP+4) -> Number to convert (in LSB, MSB is ignored)
(SP+2) -> Two-byte ASCII buffer start address
Output
D : Ignored MSB of number to convert
E : Number to convert
Routine
Byte2Hex:   POP   HL      ;Get ret address temporarily
      POP   DE      ;Get Buffer address
      LD   (B2HBuf),DE   ;Save Buffer address
      POP   DE      ;Get Number
      PUSH   HL      ;Push return value
      LD   HL,(B2HBuf)   ;Make HL point to buffer
      LD   A,E      ;Number to A (H=0, and ignored)
      RRCA         ;Get hi-nibble of A into lo-nibble
      RRCA
      RRCA
      RRCA
      AND   0Fh      ;Isolate lo-nibble
      ADD   A,"0"      ;Add ASCII for zero
      CP   3Ah      ;Greater than "9"?
      JR   C,B2HBig1   ;Jump if so
      ADD   A,07h      ;Add ASCII difference to "A"
B2HBig1:   LD   (HL),A      ;Save char to buffer
      LD   A,E      ;Rretrieve number
      ADD   A,"0"      ;Add ASCII for "0"
      JR   C,B2HBig2   ;Jump if so
B2HBig2:   LD   (HL),A      ;Save char to buffer
      RET         ;Done.
B2HBuf:      DW   0000h
Added by
Marcelo Lopez
18 May 2013 00:11
Q10025. Routine (Byte2Ascii) of preparing an 8 bit number to be printed in decimal form.
More information
Routine converts an 1-byte number to ASCII characters. Leading zeroes are replaced by spaces. All values are considered positive.
Assembler
Any assembler.
Input
(SP+2) -> Three-byte ASCII buffer start address
Output
ASCII buffer is filled with converted number
A : Ascii code of LSB
C : Ascii code of mid-significant digit (or space, if it was zero)
Routine
Byte2Ascii:   POP   BC      ;Fetch ret address temporarily
      POP   HL      ;Fetch ASCII buffer address
      POP   DE      ;Fetch nmber to convert in E
      PUSH   BC      ;Push back ret address
      LD   A,E      ;Get number to convert in A
      LD   C,"0"-1      ;Prepare character
B2A_3:      INC   C      ;Inc char
      SUB   100      ;Subtract 100 from A
      JR   NC,B2A_3   ;Keep looping until negative
      ADD   A,100      ;Restore positive value
      LD   E,A      ;Save value temporarily
      LD   A,C      ;Hundreds char to A
      CP   "0"      ;Is zero?
      JR   NZ,B2A_Hundreds   ;Jump if not
      LD   C," "      ;Preset to put a space if Hundreds=0
B2A_Hundreds:   LD   (HL),C      ;Save hundreds char
      LD   A,E      ;Retrieve old value
B2A_2:      INC   C      ;Inc char
      SUB   10      ;Subtract 10 from A
      JR   NC,B2A_2   ;Keep looping until negative
      ADD   A,"0"+10   ;Restore positive value (and ASCII)
      LD   E,A      ;Save char briefly
      LD   A,C      ;Tens char to A
      CP   "0"      ;Is zero?
                JR   NZ,B2A_Tens   ;Jump if not
      LD   C," "      ;Change char to be a space
      LD   A,E      ;Retrieve last char
B2A_Tens:   LD   (HL),C      ;Save tens char
      LD   (HL),A      ;Save units char (don't check for 0)
      RET         ;Done
Added by
Marcelo Lopez
Q10026. Routine (Word2Ascii) of preparing a 16 bit number to be printed in decimal form.
More information
Routine converts a 2-byte number to ASCII characters. All values are considered positive.
Assembler
Any assembler.
Input
(SP+2) -> Five-byte ASCII buffer start address
Output
BC: 000Ah
DE: Buffer start address
HL: Least significant digit of number to convert
Routine
;Word2Ascii:   POP   BC      ;Retrieve ret address
;      POP   DE      ;Fetch ASCII buffer
;      POP   HL      ;Fetch number to convert
;      PUSH   BC      ;Push ret address back
Word2Ascii:   POP   HL      ;Ret addr briefly to HL
      POP   DE      ;Fetch ASCII buffer to DE
      EX   (SP),HL      ;Exchg Ret (SP) with Number (HL)
      LD   BC,10000   ;Prepare BC to subtract
      PUSH   IX      ;Save content of IX
      PUSH   DE      ;Transfer content of
      POP   IX      ;Register DE to IX
      LD   (IX+0),"0"-1   ;Insert char in buffer
W2A_5:      INC   (IX+0)      ;Inc char
                SBC   HL,BC      ;Deduct 10K from HL
      JR   NC,W2A_5   ;Loop until negative result
      ADD   HL,BC      ;Restore positive in HL
      LD   BC,1000      ;Prepare BC to subtract
      LD   (IX+1),"0"-1   ;Insert char in buffer
W2A_4:      INC   (IX+1)      ;Inc char
      SBC   HL,BC      ;Deduct 1K from HL
      JR   NC,W2A_4   ;Loop until negative result
      LD   BC,100      ;Prepare BC to subtract
      LD   (IX+2),"0"-1   ;Insert char in buffer
W2A_3:      INC   (IX+2)      ;Inc char
      SBC   HL,BC      ;Deduct 100 from HL
      JR   NC,W2A_3   ;Loop until negative result
      LD   BC,10      ;Prepare BC to subtract
      LD   (IX+3),"0"-1   ;Insert char in buffer
W2A_2:      INC   (IX+3)      ;Inc char
      SBC   HL,BC      ;Deduct 10 from HL
      JR   NC,W2A_2   ;Loop until negative result
      ADD   HL,BC      ;Restore positive to HL
      LD   A,L      ;Last number to A
      ADD   A,"0"      ;Add the "0" difference
      LD   (IX+4),A   ;Put last char in buffer
      POP   IX      ;Restore original value in IX
      RET
Added by
Marcelo Lopez
18 May 2013 00:14
Users browsing this forum: No registered users and 9 guests
