Atom Feed | View unanswered posts | View active topics It is currently 03 Jun 2024 22:11
Reply to topic  [ 9 posts ]
Balanced ternary arithmetics
Due to rising interests to implementation of arithmetics operations in balanced ternary system I decided to publish some source code, that was written by Mr. James Allwright, since his web-site - http://perun.hscs.wmin.ac.uk/~jra/ternary/ - is no longer available. The code is in C language and shows how to perform some elementary operations.
/* Package of routines for arithmetic in balanced ternary */
/* Numbers are held as an array of size lena stored least */
/* significant byte first */
/* Developed by James Allwright,                   */
/* Department of Electronics and Computer Science, */
/* University of Southampton, UK                   */
#define MAXLEN 50
static int plus_one[MAXLEN] = {1};
static int len_plus_one = 1;
add(lena, lenb, lenc, a, b, c)
/* c = a + b */
/* add together 2 numbers in balanced ternary */
int *lena, *lenb, *lenc;
int a[MAXLEN], b[MAXLEN], c[MAXLEN];
  int carry, i;
  zero(lenc, c);
  carry = 0;
  i = 0;
  while ((carry != 0) || (i < *lena) || (i < *lenb)) {
    c[i] = carry;
    if (i < *lena) {
      c[i] = c[i] + a[i];
    if (i < *lenb) {
      c[i] = c[i] + b[i];
    carry = 0;
    if (c[i] > 1) {
      c[i] = c[i] - 3;
      carry = 1;
    if (c[i] < -1) {
      c[i] = c[i] + 3;
      carry = -1;
    i = i + 1;
    if ((i >= MAXLEN) && (carry != 0)) {
      printf("Overflow error!\n");
      exit(-1);
  *lenc = i+1;
  while ((*lenc > 0) && (c[*lenc-1] == 0)) {
    *lenc = *lenc -1;
negate(lena, a)
/* a = -a */
int *lena;
int a[MAXLEN];
  int i;
  for (i=0; i < *lena; i++) {
    a[i] = -a[i];
neg(lena, lenb, a, b)
/* b = -a */
int *lena, *lenb;
int a[MAXLEN], b[MAXLEN];
  int i;
    b[i] = -a[i];
  *lenb = *lena;
sub(lena, lenb, lenc, a, b, c)
/* c = a - b */
/* subtract numbers in balanced ternary */
/* using negate and add */
  int lent;
  int temp[MAXLEN];
  /* temp = -b */
  neg(lenb, &lent, b, temp);
  add(lena, &lent, lenc, a, temp, c);
copy(lena, lenb, a, b)
/* copies a into b */
int *lena, *lenb;
  int i;
  for (i=0; i<*lena; i++) {
    b[i] = a[i];
  *lenb = *lena;
zero(lena, a)
/* a = 0 */
/* sets a to zero */
int *lena;
int a[MAXLEN];
  int i;
  for (i=0; i<MAXLEN; i++) {
    a[i] = 0;
  *lena = 0;
mshift(lena, a)
/* shift left one place (multiply by 3) */
int *lena;
int a[MAXLEN];
  int i;
  if (*lena >= MAXLEN ) {
    printf("Overflow error in mshift\n");
    exit(-1);
  *lena = *lena + 1;
  for (i=*lena-1; i>0; i--) {
    a[i] = a[i-1];
  a[0] = 0;
dshift(lena, a)
/* shift right one place (divide by 3) */
int *lena;
int a[MAXLEN];
  int i;
  if (*lena > 0) {
    *lena = *lena - 1;
      a[i] = a[i+1];
mul(lena, lenb, lenc, a, b, c)
/* multiply together 2 numbers in balanced ternary */
  int lend, lent;
  int d[MAXLEN], temp[MAXLEN];
  int i;
  zero(lenc, c);
  if (*lena + *lenb - 2 > MAXLEN) {
    printf("Result too large error in multiplication!\n");
    exit(1);
  copy(lenb, &lend, b, d);
    if (a[i] == 1) {
      /* c = c + d */
      add(lenc, &lend, &lent, c, d, temp);
      copy(&lent, lenc, temp, c);
    if (a[i] == -1) {
      /* c = c - d */
      sub(lenc, &lend, &lent, c, d, temp);
    if (i < *lena-1) {
      mshift(&lend, d);
int compare(lena, lenb, a, b)
/*  used by div           */
/*  returns :             */
/*    1  if  |a| >  |b|   */
/*    0  if  |a| == |b|   */
/*   -1  if  |a| <  |b|   */
int *lena, *lenb;
  int signa, signb;
  int place;
  if (*lena > *lenb) {
    return(1);
  if (*lena < *lenb) {
    return(-1);
  /* get sign of a and b */
  signa = a[*lena-1];
  signb = b[*lenb-1];
  place = *lena - 1;
  while ((place >= 0) && (signa*a[place] == signb*b[place])) {
    place = place -1;
  if (place == -1) {
    return(0);
  } else {
    if (signa*a[place] > signb*b[place]) {
      return(1);
    } else {
      return(-1);
div(lena_in, lenb_in, lenc, lena, a_in, b_in, c, a)
/*  divide numbers in balanced ternary  */
/*  calculates a_in / b_in, returning   */
/*  c = result, a = remainder           */
/*  algorithm is like decimaltoBT       */
/*  a and b are working copies of a_in and b_in */
int *lena_in, *lenb_in, *lenc, *lena;
int a_in[MAXLEN], b_in[MAXLEN], c[MAXLEN], a[MAXLEN];
  int lenb_store;
  int *lenb;
  int lent;
  int b[MAXLEN], temp[MAXLEN];
  int pos, digit;
  if (*lenb_in == 0) {
    printf("Division by zero error!\n");
    exit(1);
  if (*lena_in == 0) {
    *lenc = 0;
    return;
  copy(lena_in, lena, a_in, a); /* remainder starts as a */
  lenb = &lenb_store;
  copy(lenb_in, lenb, b_in, b); /* copy in b */
  pos = 0;
  digit = - 1;
  /* align b appropriately */
  while (*lenb < (*lena+1)) {
    mshift(lenb, b);
    pos = pos + 1;
  while (*lenb > (*lena+1)) {
    dshift(lenb, b);
    pos = pos - 1;
  if (pos >= 0) {
    *lenc = pos + 1; /* initial guess at length of result */
  } else {
    *lenc = 0;
  while ((*lena > 0) && (pos >= 0)) {
    /* decide whether to try +b or -b */
    if (a[*lena - 1] == b[*lenb - 1]) {
      digit = - digit;
      /* b = -b */
      copy(&lent, lenb, temp, b);
    /* temp = a + b */
    add(lena, lenb, &lent, a, b, temp);
    if (compare(lena, &lent, a, temp) == 1) {
      /* accept digit */
      /* a = temp */
      copy(&lent, lena, temp, a);
      c[pos] = digit;
    } else {
      /* don't accept digit */
      c[pos] = 0;
    pos = pos - 1;
    dshift(lenb, b);
  /* if we've reduced a to zero, fill in the remaining digits with 0 */
  while (pos >= 0) {
    c[pos] = 0;
    pos = pos - 1;
  /* correct the length of the result */
    *lenc = *lenc - 1;
  /* ensure that the remainder is the same sign as a_in */
  if (*lena > 0) { /* no problem if there is no remainder */
    if (a_in[*lena_in - 1] != a[*lena-1]) {
      if ((a_in[*lena_in - 1] == b_in[*lenb_in-1]) ) {
        /* a = a + b_in */
        add(lena, lenb_in, &lent, a, b_in, temp);
        /* c = c - 1 */
        sub(lenc, &len_plus_one, &lent, c, plus_one, temp);
      } else {
        /* a = a - b_in */
        sub(lena, lenb_in, &lent, a, b_in, temp);
        /* c = c + 1 */
        add(lenc, &len_plus_one, &lent, c, plus_one, temp);
BTtodecimal(lena, a, result)
/* convert Balanced Ternary to decimal */
int *lena;
int a[MAXLEN];
int *result;
  int b, i;
  b = 1;
  *result = 0;
  for (i=0; i < (*lena); i++) {
    *result = *result + b * a[i];
    b = b * 3;
int abs(a)
int a;
  if (a > 0) {
    return(a);
  } else {
    return(-a);
decimaltoBT(lenr, result, value)
/* convert decimal to Balanced Ternary */
int *lenr;
int result[MAXLEN];
int value;
  int target, val, goal, pos;
  *lenr = 0;
  target = value;
  pos = 0;
  val = 1;
  goal  = 2 * target;
  if (goal < 0) {
    goal = -goal;
  while ((val < goal) && (pos < MAXLEN)) {
    val = 3 * val;
    pos = pos + 1;
  if (pos >= MAXLEN) {
    printf("Overflow error in decimaltoBT\n");
    exit(-1);
  if ( target < 0) {
    val = -val;
  while (pos >= 0) {
    if (abs(target-val) < abs(target)) {
      if (val > 0) {
        result[pos] = 1;
        target = target - val;
      } else {
        result[pos] = -1;
      if (*lenr == 0) {
        *lenr = pos+1;
    } else {
      result[pos] = 0;
    val = val / 3;
    pos = pos - 1;
    /* make target and val the same sign */
    if ((target * val) < 0) {
      val = -val;
printnum(lena, a)
int *lena;
int a[MAXLEN];
  int i;
  for (i=*lena-1; i>=0; i--) {
    printf("(%d)", a[i]);
  if (*lena == 0) printf("(0)");
main(argc, argv)
int argc;
char *argv[];
  int a[MAXLEN], b[MAXLEN], c[MAXLEN], rem[MAXLEN];
  int lena, lenb, lenc, lenrem;
  int i, answer;
  int t1, t2, t3;
  printf("Testing decimaltoBT and BTtodecimal.\n");
  for (i=0; i<100; i++) {
    t1 = (rand() % 1000) - 500;
    decimaltoBT(&lena, a, t1);
    BTtodecimal(&lena, a, &t3);
    if (t3 != t1) {
      printf("Error : %d has been converted to %d\n", t1, t3);
  printf("Testing add.\n");
    t2 = (rand() % 1000) - 500;
    decimaltoBT(&lenb, b, t2);
    add(&lena, &lenb, &lenc, a, b, c);
    BTtodecimal(&lenc, c, &t3);
    if (t3 != (t1+t2)) {
      printf("add gives %d + %d = %d\n", t1, t2, t3);
      printf("Error : answer should be %d\n", t1+t2);
  printf("Testing sub.\n");
    sub(&lena, &lenb, &lenc, a, b, c);
    if (t3 != (t1-t2)) {
      printf("Error : answer should be %d\n", t1-t2);
  printf("Testing mul.\n");
    t1 = (rand() % 10000) - 5000;
    t2 = (rand() % 10000) - 5000;
    mul(&lena, &lenb, &lenc, a, b, c);
    if (t3 != (t1*t2)) {
      printf("mul gives %d * %d = %d\n", t1, t2, t3);
      printf("Error : answer should be %d\n", t1*t2);
  printf("Testing div.\n");
    t2 = (rand() % 50) - 25;
    if (t2 == 0) {
      t2 = 1;
    div(&lena, &lenb, &lenc, &lenrem, a, b, c, rem);
    if (t3 != (t1/t2)) {
      printf("div gives %d / %d = %d\n", t1, t2, t3);
      printf("Error : answer should be %d\n", t1/t2);
13 Aug 2008 00:50
Also on his site was a Java-based calculator to be used with balanced ternary numbers. Here is source code for it:
import java.awt.*;
import java.util.*;
import java.applet.Applet;
///* Developed by James Allwright,                   */
///* Department of Electronics and Computer Science, */
///* University of Southampton, UK                   */
public class Calculator extends Applet {
  stackbox thestack = new stackbox();
  keypad keys = new keypad(thestack);
  public void init() {
    Label label;
    int j;
//    label = new Label("Balanced Ternary Calculator", Label.CENTER);
//    add(label);
    add(keys);
    add(thestack);
  public boolean handleEvent(Event e) {
    int j;
    if ((e.target == thestack.decimalbox) && (e.id == Event.ACTION_EVENT)) {
      thestack.fromdecimal();
    return false;
class keypad extends Panel {
  Button PlusOne, Zero, MinusOne, AC;
  Button Push, Pop;
  Button Add, Sub, Mul, Div;
  Button Decimal;
  Button Neg;
  stackbox astack;
  public keypad(stackbox thestack) {
    setLayout(new GridLayout(3, 4));
    astack = thestack;
    MinusOne = new Button("-1");
    Zero = new Button("0");
    PlusOne = new Button("+1");
    AC = new Button("AC");
    add(MinusOne);
    add(Zero);
    add(PlusOne);
    add(AC);
    Add = new Button("+");
    Sub = new Button("-");
    Mul = new Button("x");
    Div = new Button("/");
    add(Add);
    add(Sub);
    add(Mul);
    add(Div);
    Push = new Button("PUSH");
    Pop = new Button("POP");
    add(Push);
    add(Pop);
    Decimal = new Button("DEC");
    add(Decimal);
    Neg = new Button("NEG");
    add(Neg);
    int j;
    if (e.target == MinusOne) {
      astack.setdigit(-1);
    if (e.target == Zero) {
      astack.setdigit(0);
    if (e.target == PlusOne) {
      astack.setdigit(1);
    if (e.target == AC) {
      astack.clear();
    if (e.target == Push) {
      astack.push();
    if (e.target == Pop) {
      astack.pop();
    if (e.target == Add) {
      astack.add();
    if (e.target == Sub) {
      astack.sub();
    if (e.target == Mul) {
      astack.mul();
    if (e.target == Div) {
      astack.div();
    if (e.target == Decimal) {
      astack.todecimal();
    if (e.target == Neg) {
      astack.neg();
    return false;
class stackbox extends Panel {
  int place = 0;
  BTnumber result = new BTnumber();
  BTnumber stack[] = new BTnumber[5];
  TextField stacktext[] = new TextField[5];
  TextField decimalbox;
  BTnumber plus_one = new BTnumber();
  boolean onresult = false;
  boolean overflow;
  stackbox() {
    int j;
    setLayout(new GridLayout(6, 1));
    for (j=4; j>=0; j--) {
      stack[j] = new BTnumber();
      stacktext[j] = new TextField("", stack[j].MAXLEN);
      add(stacktext[j]);
    decimalbox = new TextField("", 11);
    add(decimalbox);
    refresh(place);
    plus_one.AddDigit(1);
  void refresh(int n) {
    stacktext[n].setText(stack[n].textify());
  void setzero(int n) {
    stack[n].zero();
    refresh(n);
  void clear() {
    if (onresult) {
      error("");
      onresult = false;
      if (place < 4) {
        place = place + 1;
    setzero(place);
  void setnull(int n) {
    stack[n].zero();
    stacktext[n].setText("");
  void setdigit(int d) {
    if (onresult) {
      error("");
      onresult = false;
      if (place < 4) {
        place = place + 1;
      setzero(place);
    stack[place].AddDigit(d);
    refresh(place);
  void error(String text) {
    decimalbox.setText(text);
  boolean pre_binary_op() {
    error("");
    overflow = false;
    if (place > 0) {
      return true;
    } else {
      return false;
  void post_binary_op() {
    setnull(place);
    place = place -1;
    onresult = true;
    refresh(place);
  void pop() {
    error("");
    stack[place].zero();
    setnull(place);
    if (place > 0) {
      place = place - 1;
      onresult = true;
      refresh(place);
    } else {
      onresult = false;
  void push() {
    onresult = true;
  BTnumber addnum(BTnumber a, BTnumber b) {
  /* c = a + b */
    int carry, i, digit;
    BTnumber c = new BTnumber();
    carry = 0;
    i = 0;
    c.digit[i] = 0;
    while ((carry != 0) || (i < a.length) || (i < b.length)) {
      c.digit[i] = carry;
      if (i < a.length) {
        c.digit[i] = c.digit[i] + a.digit[i];
      if (i < b.length) {
        c.digit[i] = c.digit[i] + b.digit[i];
      carry = 0;
      if (c.digit[i] > 1) {
        c.digit[i] = c.digit[i] - 3;
        carry = 1;
      if (c.digit[i] < -1) {
        c.digit[i] = c.digit[i] + 3;
        carry = -1;
      i = i + 1;
      if ((i == c.MAXLEN) && (carry != 0)) {
        carry = 0;
        overflow = true;
    if (overflow) {
      c.zero();
      error("Overflow Error");
    } else {
      c.length = i;
      while ((c.length > 0) && (c.digit[c.length-1] == 0)) {
        c.length = c.length - 1;
    return c;
  BTnumber subnum(BTnumber a, BTnumber b) {
    BTnumber t = new BTnumber();
    t.takevalue(b);
    t.negate();
    return addnum(a, t);
  BTnumber mulnum(BTnumber a, BTnumber b)
    BTnumber d = new BTnumber();
    int i;
    if ((a.length + b.length - 2) > a.MAXLEN) {
      return c;
    d.takevalue(b);
    for (i=0; i < a.length; i++) {
      if (a.digit[i] == 1) {
        /* c = c + d */
        c = addnum(c, d);
      if (a.digit[i] == -1) {
        /* c = c - d */
        c = subnum(c, d);
      if (i != a.length-1) {
        mshift(d);
    if (overflow) {
      c.zero();
    return c;
  int compare(BTnumber a, BTnumber b)
  /*  used by div         */
  /*  returns :           */
  /*    1  if  a >  b     */
  /*    0  if  a == b     */
  /*   -1  if  a <  b     */
    int signa, signb;
    int place;
    if (a.length > b.length) {
      return(1);
    if (a.length < b.length) {
      return(-1);
    signa = a.digit[a.length-1];
    signb = b.digit[b.length-1];
    place = a.length - 1;
    while ((place >= 0) && (signa*a.digit[place] == signb*b.digit[place])) {
      place = place -1;
    if (place == -1) {
      return(0);
    } else {
      if (signa*a.digit[place] > signb*b.digit[place]) {
        return(1);
      } else {
        return(-1);
  BTnumber divnum(BTnumber a_in, BTnumber b_in)
    BTnumber a = new BTnumber();
    BTnumber b = new BTnumber();
    BTnumber temp;
    int pos, digit;
    if (b_in.length == 0) {
      error("Division by zero");
      return c;
    if (a_in.length == a_in.MAXLEN) {
      error("Numerator too great");
      return c;
    if (a_in.length == 0) {
      return c;
    a.takevalue(a_in);
    b.takevalue(b_in);
    pos = 0;
    digit = - 1;
    while (b.length < (a.length+1)) {
      mshift(b);
      pos = pos + 1;
    while (b.length > (a.length+1)) {
      dshift(b);
      pos = pos - 1;
    if (pos >= 0) {
      c.length = pos + 1; /* initial guess at length of result */
    while ((a.length > 0) && (pos >= 0) && (b.length > 0)) {
      if (a.digit[a.length - 1] == b.digit[b.length - 1]) {
        digit = - digit;
        /* b = -b */
        b.negate();
      /* temp = a + b */
      temp = addnum(a, b);
      if (compare(a, temp) == 1) {
        /* accept digit */
        /* a = temp */
        a = temp;
        c.digit[pos] = digit;
      } else {
        c.digit[pos] = 0;
      pos = pos - 1;
      dshift(b);
    while (pos >= 0) {
      c.digit[pos] = 0;
      pos = pos - 1;
    if (a.length > 0) { /* no problem if there is no remainder */
      if (a_in.digit[a_in.length - 1] != a.digit[a.length-1]) {
        if ((a_in.digit[a_in.length - 1] == b_in.digit[b_in.length-1]) ) {
          /* a = a + b_in */
          a = addnum(a, b_in);
          /* c = c - 1 */
          c = subnum(c, plus_one);
        } else {
          /* a = a - b_in */
          a = subnum(a, b_in);
          /* c = c + 1 */
          c = addnum(c, plus_one);
    return c;
  long BTtodecimal(BTnumber a)
    long result;
    long b;
    int i;
    b = 1;
    result = 0;
    for (i=0; i < (a.length); i++) {
      result = result + b * a.digit[i];
      b = b * 3;
    return result;
  BTnumber decimaltoBT(long value) {
    long target, val, goal;
    int pos;
    result.length = 0;
    target = value;
    pos = 0;
    val = 1;
    goal  = 2 * target;
    if (goal < 0) {
      goal = -goal;
    while (val < goal) {
      val = 3 * val;
      pos = pos + 1;
    if (pos >= result.MAXLEN-1) {
      error("Overflow error");
      pos = -1;
    if ( target < 0) {
      val = -val;
    while (pos >= 0) {
      if (Math.abs(target-val) < Math.abs(target)) {
        if (val > 0) {
          result.digit[pos] = 1;
        } else {
          result.digit[pos] = -1;
        if (result.length == 0) {
          result.length = pos+1;
      } else {
        result.digit[pos] = 0;
      val = val / 3;
      pos = pos - 1;
        val = -val;
    return result;
  void mshift(BTnumber n)
    int i;
    if (n.length == n.MAXLEN) {
    } else {
      n.length = n.length + 1;
      for (i=n.length-1; i>0; i--) {
        n.digit[i] = n.digit[i-1];
      n.digit[0] = 0;
  void dshift(BTnumber n)
    int i;
    if (n.length > 0) {
      n.length = n.length - 1;
      for (i=0; i<n.length; i++) {
        n.digit[i] = n.digit[i+1];
  void add() {
    if (pre_binary_op()) {
      stack[place-1] = addnum(stack[place], stack[place-1]);
      post_binary_op();
  void sub() {
      stack[place-1] = subnum(stack[place], stack[place-1]);
      post_binary_op();
  void mul() {
      stack[place-1] = mulnum(stack[place], stack[place-1]);
      post_binary_op();
  void div() {
      stack[place-1] = divnum(stack[place], stack[place-1]);
      post_binary_op();
  void todecimal() {
    long t;
    t = BTtodecimal(stack[place]);
    decimalbox.setText(String.valueOf(t));
  void fromdecimal() {
    long t;
    if (onresult) {
      onresult = false;
      if (place < 4) {
        place = place + 1;
    t = Integer.valueOf(decimalbox.getText()).longValue();
    stack[place] = decimaltoBT(t);
    decimalbox.setText("");
    refresh(place);
    onresult = true;
  void neg() {
    stack[place].negate();
    refresh(place);
class BTnumber {
  static int MAXLEN = 20;
  int digit[] = new int[MAXLEN];
  int length;
  BTnumber() {
    this.length = 0;
  public void takevalue(BTnumber n) {
    int j;
    this.length = n.length;
    for (j=0; j<length; j++) {
      this.digit[j] = n.digit[j];
  public void AddDigit(int d) {
    int j;
    if ((length > 0) || (d != 0)) {
      if (length < MAXLEN) {
        for (j=this.length; j>0; j--) {
          this.digit[j] = this.digit[j-1];
        this.digit[0] = d;
        this.length = this.length + 1;
  public void zero() {
    this.length = 0;
  public String textify() {
    int j;
    StringBuffer out;
    String map = "-01";
    out = new StringBuffer(MAXLEN);
    if (this.length <= 0) {
      out.append("0");
    } else {
      for (j=this.length-1; j>=0; j--) {
        out.append(map.charAt(this.digit[j]+1));
    return out.toString();
  void negate() {
  /* a = -a */
    int i;
    for (i=0; i < length; i++) {
      digit[i] = -digit[i];
13 Aug 2008 00:52
And the html-source to run calculator applet:
<HTML>
<HEAD>
<BASE HREF="http://perun.hscs.wmin.ac.uk/~jra/ternary/calculator/">
<TITLE>Balanced Ternary Calculator</TITLE>
</HEAD>
<BODY bgcolor="#FFFFFF">
<h1>Balanced Ternary Calculator</h1>
Below is a simple stack-based balanced ternary calculator written in Java.
<APPLET CODE="Calculator.class" WIDTH=400 HEIGHT=200>
</APPLET>
<P>
The buttons are :
<UL>
<LI><b>-1</b>, <b>0</b> and <b>+1</b> to enter a number.
<LI><b>AC</b> clear entry and start again.
<LI><b>PUSH</b> entry finished - ready to enter next number.
<LI><b>POP</b> remove top item from stack.
<LI><b>+</b>, <b>-</b>, <b>x</b> and <b>/</b> perform the appropriate action
on the top 2 items on the stack.
<LI><b>DEC</b> display decimal value of current number in the bottom slot.
<LI><b>NEG</b> negate current entry.
</UL>
Enter a decimal number in the
bottom slot and it will be converted to balanced ternary and placed on the
stack.
<p>
Here is the <A HREF="Calculator.java">Java source</A>.
<HR>
Written by <A HREF="http://diana.ecs.soton.ac.uk/~jra/cv.html">James
Allwright</A>.
</BODY>
<SCRIPT language="Javascript">
// FILE ARCHIVED ON 20040906154742 AND RETRIEVED FROM THE
// INTERNET ARCHIVE ON 20080813074243.
// JAVASCRIPT APPENDED BY WAYBACK MACHINE, COPYRIGHT INTERNET ARCHIVE.
// ALL OTHER CONTENT MAY ALSO BE PROTECTED BY COPYRIGHT (17 U.S.C.
// SECTION 108(a)(3)).
   var sWayBackCGI = "http://web.archive.org/web/20040906154742/";
   function xResolveUrl(url) {
      var image = new Image();
      image.src = url;
      return image.src;
   function xLateUrl(aCollection, sProp) {
      var i = 0;
      for(i = 0; i < aCollection.length; i++) {
         if (typeof(aCollection[i][sProp]) == "string") {
          if (aCollection[i][sProp].indexOf("mailto:") == -1 &&
             aCollection[i][sProp].indexOf("javascript:") == -1) {
            if(aCollection[i][sProp].indexOf("http") == 0) {
                aCollection[i][sProp] = sWayBackCGI + aCollection[i][sProp];
            } else {
                aCollection[i][sProp] = sWayBackCGI + xResolveUrl(aCollection[i][sProp]);
   xLateUrl(document.getElementsByTagName("IMG"),"src");
   xLateUrl(document.getElementsByTagName("A"),"href");
   xLateUrl(document.getElementsByTagName("AREA"),"href");
   xLateUrl(document.getElementsByTagName("OBJECT"),"codebase");
   xLateUrl(document.getElementsByTagName("OBJECT"),"data");
   xLateUrl(document.getElementsByTagName("APPLET"),"codebase");
   xLateUrl(document.getElementsByTagName("APPLET"),"archive");
   xLateUrl(document.getElementsByTagName("EMBED"),"src");
   xLateUrl(document.getElementsByTagName("BODY"),"background");
   var forms = document.getElementsByTagName("FORM");
   if (forms) {
       var j = 0;
       for (j = 0; j < forms.length; j++) {
              f = forms[j];
              if (typeof(f.action)  == "string") {
                 if(typeof(f.method)  == "string") {
                     if(typeof(f.method) != "post") {
                        f.action = sWayBackCGI + f.action;
</SCRIPT>
</HTML>
13 Aug 2008 00:54
Thanks, for the code,
actually i was looking for the code for devision, and its there....:-)
14 Aug 2008 05:57
Yes, it seems to be the only public code that does division with balanced ternary numbers.
14 Aug 2008 06:10
Do you know what license it's released under?
14 Aug 2008 10:09
I've got no idea about license, he just uploaded the code to his own web-site, nothing more.
14 Aug 2008 13:14
There is no copyright notice, just "Developed by James Allwright" message, so it looks like "public domain"...
See some historical snapshot of that web-page from 2005:
http://web.archive.org/web/200502110914 ... a/ternary/
E-mail of author is J.R.Allwright@westminster.ac.uk
14 Aug 2008 22:31
up
10 Nov 2012 07:01
