Atom Feed | View unanswered posts | View active topics It is currently 29 Apr 2024 04:32
Reply to topic  [ 11 posts ]
Great algorithm to convert an integer to ternary
This is fantastic. I've written an algorithm for host integer to trit array representation that is incredibly simple and fast. It's O(log(v)), all-integer and has no superfluous variables or overhead.
/* Convert a native integer v to
 * an array of at most n ternary digits, t. */
void to_ternary(int* t, int n, int v) {
        int i;
        for(i = 0; i < n && v != 0; i++) {
                if(v >= 0) {
                        t[i] = v-3*((v+1)/3);
                        v = (v+1)/3;
                } else {
                        t[i] = v-3*((v-1)/3);
                        v = (v-1)/3;
        for(; i < n; i++) t[i] = 0;
It's based on a mathematical insight I had on balanced bases when I was taking the bus earlier today. I wrote it down in a PDF if anyone is interested...
http://nedopc.org/ternary/tunguska/math ... .bases.pdf
The algorithm takes advantage of what happens to equation (8) when you let kappa be 1, and from that it's just a matter of inserting values into equation (11) and making optimizations.
22 Jan 2009 14:53
Congratulations! Very nice piece of quick working code :) It works with C# too (with small changes in definitions of course).
22 Jan 2009 15:20
Thanks. It should hopefully work with any language that where a*(b/a) is the same as a*floor(b/a) for integers a and b.
22 Jan 2009 15:26
Hi,
I tried to understand...but could not :-(,
i will try again :-)
23 Jan 2009 03:35
I find it's a very useful formulation. This function extracts an arbitrary digit in a host integer. It should be pretty easy to extend for systems that use wider words than 6.
/* Get the n:th trit in v */
int tritn(int v, int n) {
        if(v >= 0) {
                switch(n) {
                        case 0: return v - 3*((v+1)/3);
                        case 1: return (v+1)/3 - 3*((v+4)/9);
                        case 2: return (v+4)/9 - 3*((v+13)/27);
                        case 3: return (v+13)/27 - 3*((v+40)/81);
                        case 4: return (v+40)/81 - 3*((v+121)/243);
                        case 5: return (v+121)/243 - 3*((v+364)/729);
        } else {
                switch(n) {
                        case 0: return v + 3*((1-v)/3);
                        case 1: return (v-1)/3 + 3*((4-v)/9);
                        case 2: return (v-4)/9 + 3*((13-v)/27);
                        case 3: return (v-13)/27 + 3*((40-v)/81);
                        case 4: return (v-40)/81 + 3*((121-v)/243);
                        case 5: return (v-121)/243 + 3*((364-v)/729);
        return 0;
I haven't tested this one very extensively, but it seems to work. It allows you to set a trit in a host integer. It doesn't check so that t is in a valid range, so obviously care must be taken.
/* Set trit n in integer v to t */
int settrit(int v, int n, int t) {
        if(v >= 0) {
                switch(n) {
                        case 0:
                                return t + 3*((v+1)/3);
                        case 1:
                                return v - 3*((v+1)/3 - t) + 9*((v+4)/9);
                        case 2:
                                return v - 9*((v+4)/9 - t) + 27*((v+13)/27);
                        case 3:
                                return v - 27*((v+13)/27 -t) + 81*((v+40)/81);
                        case 4:
                                return v - 81*((v+40)/81 -t) + 243*((v+121)/243);
                        case 5:
                                return v - 243*((v+121)/243 -t) + 729*((v+364)/729);
        } else {
                switch(n) {
                        case 0:
                                return t - 3*((1-v)/3);
                        case 1:
                                return v + 3*((1-v)/3 + t) + 9*((v-4)/9);
                        case 2:
                                return v + 9*((4-v)/9 + t) + 27*((v-13)/27);
                        case 3:
                                return v + 27*((13-v)/27 + t) + 81*((v-40)/81);
                        case 4:
                                return v + 81*((40-v)/81 + t) + 243*((v-121)/243);
                        case 5:
                                return v + 243*((121-v)/243 + t) + 729*((v-364)/729);
        return 0;
23 Jan 2009 12:28
Hi,
I am using the first code to convert int to Tryte....its useful....and i will be using 2nd one to perform memory operations in TVM...:-)
24 Jan 2009 01:07
Yeah, this method is incredibly useful. In Tunguska, I changed the lines
tryte instruction = memref(ip);
tryte highbits = instruction >> 4;
instruction = (instruction << 2) >> 2;
to
int highbits, instruction = memref(ip).to_int();
if(instruction > 0) {
  highbits = ((instruction + 40) / 81);
} else {
  highbits = ((instruction-40) / 81);
instruction -= 81 * highbits;
And got a 10-40% speed increase. I knew this was a bottleneck in the design, but yikes! :-o On my system, it's now just below 3,000,000 operations per second!
24 Jan 2009 16:06
Hi,
10-40% is a really good progress Waaw!!!!
Just wanted to know if you have developed any ternary algorithms for Matrix operations.
24 Jan 2009 17:57
Hmm, I'm not sure how that would be applicable. Most matrix operations are just a series of regular scalar operations. Base really doesn't factor in.
Though I have developed a wraparound function that allows you to use native integer arithmetic and still get "wraparound" of numbers bigger or smaller than what fits in the word.
For word size 6 (where of course 364=(3^6-1)/2 and 729=3^6):
int wrap(int v) {
  if(v > 364) return v - (v+364)/729;
  else if(v < -364) return v - (v-364)/729;
  return v;
So then if you want to know something like a*b, you simply skip the intermediate trit array step by using
int result = wrap(a*b);
So you get like
wrap(364) = 364
wrap(365) = -364
wrap(366) = -363
wrap(-365) = 364
etc.
24 Jan 2009 18:24
Thats an interesting function...i guess this can be used in case of representing Angels as they always lie between 0 t0 360 deg....so in ternary we can have them between "0-729"...yup its useful for matrix transform of 3D objects :-)
24 Jan 2009 18:45
changed dead link to new one
10 Nov 2012 08:55
