Atom Feed | View unanswered posts | View active topics It is currently 16 May 2024 15:59
Reply to topic  [ 2 posts ]
Improved Integer-based balanced library
I've put together a library in C that merges ideas discussed in this thread and this thread.
It can be easily extended to use any balanced base. By default, it supports logic and arithmetic up to 18 balanced ternary digits.
It implements both host integer-based balanced logic and functions for host integer-based arithmetic, that can be delayed in many cases!
So, if you wanted to calculate something, like a sum of hundred numbers. You can calculate it as though it was any number, and then pass it to the wrap function and it returns the result of doing the calculations on a balanced computer. Comparisons are also native speed.
This makes it incredibly fast.
On my computer it performs over 150 million bit get operations in a second.
It requires no initialization, but you may need to redefine bint as signed long long on some architectures (32 bit?)
ibalanced.h:
/* (C) 2009 - Viktor Lofgren
 * Free to use for non-commercial purposes.
#ifndef IBALANCED_H
#define IBALANCED_H
#include <limits.h>
#ifndef BINT_OVERRIDE
 #define BINT_MAX   LONG_MAX
 #define BINT_MIN   LONG_MIN
 #define BINT_TYPE    signed long
#endif
typedef BINT_TYPE bint;
extern bint* b_powers;
extern bint* b_powers_2;
extern bint  b_power_count;
#define b_remainder( value , divisor )  ((value) >= 0 ? \
         (value) - (divisor) * (( 2 * (value) + (divisor) - 1 ) / ( 2 * (divisor) )) : \
         (value) - (divisor) * (( 2 * (value) - (divisor) - 1 ) / ( 2 * (divisor) )))
#define b_remainder_odd( value , divisor )  ((value) >= 0 ? \
         ((value) - (divisor) * (( (value) + (divisor)/2 ) / ( (divisor) ))) : \
         ((value) - (divisor) * (( (value) - (divisor)/2 ) / ( (divisor) ))))
#define b_quotient( value , divisor ) (( (value) > 0 ? \
         ( ( 2 * (value) + (divisor) - 1 ) / ( 2 * (divisor) ) ) : \
          ( - ( - 2 * (value) + (divisor) - 1 ) / ( 2 * (divisor) ) ) )
#define b_quotient_odd( value , divisor ) (( (value) > 0 ? \
         ( ( (value) + (divisor)/2 ) / ( (divisor) ) ) : \
          ( - ( - (value) + (divisor)/2 ) / ( (divisor) ) ) )
bint b_get_digit(register bint value, register int digit);
bint b_set_digit(register bint value, register int digit, register int new);
bint wrap(register bint value, register int width);
/* Wrap is a front-end for b_remainder_odd(value, b_powers_2[width])
 * and returns the portion of the value that can be held in a word with
 * width digits.
 * It is the cornerstone in integer-based balanced arithmetic.
 *  It looks like this:
 *            wrap(value, N)
 *                A
 *           /           /     |     /           /   - - - - /- - -  base_powers_2[N]
 *   --/-----|-----/-----|-----/-----------/ ----|-----/-------- > value
 *                             |     base_powers_2[N]
 * The following arithmetic are safe to perform on a wrapped value without a re-wrap:
 *    modulo (%), division,
 * The following arithmetic are unsafe, and need a re-wrap:
 *    addition, subtraction, multiplication
 * Useful properties of wrap:
 *    wrap(wrap(a, N) + b, N) = wrap(a+b, N)
 *    wrap(wrap(a, N) - b, N) = wrap(a-b, N)
 *    wrap(wrap(a, N) * b, N) = wrap(a*b, N)
 *   wrap(-a, N)       = -wrap(a, N)
 *    wrap(a+M*N, N)      = wrap(a, N)    for M = ... -3, -2, -1, 0, 1, 2, 3, ...
 *   wrap(a, N)      = a      if  |a| < base_powers_2[i]
 *    wrap(wrap(a, P), Q) = wrap(a, Q)   if  Q < P
 *    wrap(wrap(a, P), Q) = wrap(a, P)   if  P < Q
 *    Be careful about multiplication though. Piling up
 *    too many numbers may result in a datatype overflow.
enum {
   // FUT UUU TUF
   B_XOR = 1  * -1 +   3    * 0 +   9    * 1  +
      27  * 0   +    81   * 0 +    243  * 0  +
      729 * 1 +    2187 * 0 +    6561 * -1,
   // TTT TUU TUF
   B_OR =  1   * 1 +   3    * 1 +   9    * 1  +
      27  * 1   +    81   * 0 +    243  * 0  +
   // TUF UUF FFF
   B_AND = 1  * 1  +   3    * 0 +   9    * -1 +
      27  * 0   +    81   * 0 +    243  * -1 +
      729 *-1 +    2187 * -1 +    6561 * -1,
   // FTU TUF UFT
   B_SHIFT= 1  * -1 +   3    * 1 +   9    * 0  +
      27  * 1   +    81   * 0 +    243  * -1 +
      729 * 0 +    2187 * -1 +    6561 * 1,
   // TTU TUF UFF
   B_SNR=   1  * 1 +   3    * 1 +   9    * 0  +
      729 * 0 +    2187 * -1 +    6561 * -1,
bint bivalent(bint op, register int width, register bint a, register bint b);
/* Bivalent operations are coded so that (in the case of base 3),
 *    a   b   (digit of op = result)
 *   1   1   op[0]
 *   1   0   op[1]
 *   1   -1   op[2]
 *   0   1   op[3]
 *   0   0   op[4]
 *   0   -1   op[5]
 *   -1   1   op[6]
 *   -1   0   op[7]
 *   -1   -1   op[8]
#endif
ibalanced.c:
#include "ibalanced.h"
/* Default constants */
bint default_b_powers[]   = { 1,    3,    9,    27,    81,    243,    729,
                2187,    6561,    19683,    59049,    177147, 531441,   1594323,
                4782969,      14348907,   43046721,   129140163,
                387420489L,  };
bint default_b_powers_2[] = { 0,    1,    4,    13,    40,    121,    364,
                1093,   3280,   9841,   29524,   88573,   265720,    797161,
                2391484,      7174453,   21523360,   64570081,
                193710244L
/* Pointers to constant tables. Can be changed to use another base,
 * or more or fewer values according to whatever rocks your boat*/
bint* b_powers = default_b_powers;
bint* b_powers_2 = default_b_powers_2;
bint b_power_count = 19;
/* Basic functions */
bint b_get_digit(register bint value, register int digit) {
   if(digit >= b_power_count - 1 || digit < 0) return 0;
   if(value >= 0) {
      return (value + b_powers_2[digit]) / b_powers[digit] - b_powers[1] * ((value + b_powers_2[digit+1]) / b_powers[digit+1]);
   } else {
      return (value - b_powers_2[digit]) / b_powers[digit] + b_powers[1] * (( - value + b_powers_2[digit+1]) / b_powers[digit+1]);
bint b_set_digit(register bint value, register int digit, register int new) {
   if(digit >= b_power_count - 1 || new* new>= b_powers[1]*b_powers[1]) return 0;
   if(value >= 0) {
      return value - b_powers[digit] * ((value + b_powers_2[digit]) / b_powers[digit] - new) +
            b_powers[digit+1] * ( ( value + b_powers_2[digit+1]) / b_powers[digit+1]);
   } else {
      return value + b_powers[digit] * ((-value + b_powers_2[digit]) / b_powers[digit] + new) +
            b_powers[digit+1] * ( ( value - b_powers_2[digit+1]) / b_powers[digit+1]);
bint wrap(register bint value, register int width) {
   return b_remainder_odd(value, b_powers[width]);
bint bivalent(bint op, register int width, register bint a, register bint b) {
   while(width--) {
      a = b_set_digit(a, width, b_get_digit(op, -3 * b_get_digit(a, width) - b_get_digit(b, width) + 4));
   return a;
test.c (test case)
#include <stdlib.h>
#include <stdio.h>
#include <assert.h>
#include <math.h>
#include <time.h>
int main(int argc, char* argv[]) {
   int i;
   bint bi;
   srand(time(NULL));
   printf("IBALANCED TEST CASE\n");
   printf(" Parameters: \n");
   printf("\tsizeof(bint) = %lu\n", sizeof(bint));
   printf("\tb_power_count = %ld (%ld accessible digits)\n", b_power_count, b_power_count-1);
   printf("\tb_powers = %p", (void*) b_powers);
   assert(b_powers);
   printf(" = ");
   for(i = 0; i < b_power_count; i++) {
      printf("%ld ", b_powers[i]);
   puts("");
   printf("\tb_powers_2 = %p", (void*) b_powers_2);
   assert(b_powers_2);
   printf(" = ");
      printf("%ld ", b_powers_2[i]);
   puts("");
   printf("Checking whether b_powers[%ld]*b_powers[%ld] <= BINT_MAX ", b_power_count-1, b_power_count-1);
   if( 2*log(b_powers[b_power_count-1]) > log(BINT_MAX)) {
      printf("\a... FAIL!\n !!! \t This architecture does not fully support arithmetic this wide!\n"
             " !!! \t Recommend using smaller b_power_count, or a bigger data size. \n");
      puts(" Press Enter to continue (expect errors) \n");
      getchar();
   } else puts("... OK");
   printf("Checking whether b_power_count is big enough to hold a logic table for base %ld: ", b_powers[1]);
   if( b_powers[1] * b_powers[1] > b_power_count - 1 ) {
      printf("\a FAIL!\n !!! \t Logic functions will be useless\n");
      getchar();
   printf("Checking whether 2 * b_powers_2[n] + 1 - b_powers[n] = 0");
      if(b_powers_2[i]*2+1-b_powers[i] != 0) {
         printf("\t%d: \t2*%ld+1 - %ld \t = %ld", i, b_powers_2[i], b_powers[i],
              b_powers_2[i]*2 + 1 - b_powers[i]);
         printf("... FAIL\n"); return EXIT_FAILURE;
   puts("... OK");
   printf("Checking b_get_digit of %ld to %ld (in steps of 400): ", -b_powers[b_power_count-2], b_powers[b_power_count-2]);
   for(bi = -b_powers[b_power_count-2]; bi <= b_powers[b_power_count-2]; bi+=400) {
      bint j, sum = 0;
      for(j = b_power_count - 2; j >= 0; j--) {
         sum = 3 * sum + b_get_digit(bi, j);
      if(sum != bi) {
         printf("%ld != %ld... FAIL\n", sum, bi);
   printf("... OK\n");
   printf("Checking b_set_digit on 5000000 random samples: ");
   for(i = 0; i < 5000000; i++) {
      bint rand_start = (rand() % b_powers[b_power_count-2]) * (rand() % 2 == 0 ? -1 : 1);
      bint digit = rand() % (b_power_count - 2);
      bint new_value = rand() % 3 - 1;
      bint expected_value = rand_start - (b_get_digit(rand_start, digit) - new_value) * b_powers[digit];
      bint result = b_set_digit(rand_start, digit, new_value);
      if(result != expected_value) {
         printf("b_set_digit(%ld,%ld,%ld) = %ld", rand_start, digit, new_value, result);
         printf("... FAIL!\n");
   puts("... OK");
   printf("Testing wrap(..): ");
   for(i = -100; i <= 100; i++) {
      if(4*i*i <= b_powers[4]*b_powers[4])
         if(wrap(i, 4) != i) {
            printf("... FAIL (test wrap(%d, 4) = %d)\n", i, i);
      if(wrap(i, 4) != b_set_digit(i, 4, 0)) {
         printf("... FAIL (test wrap(%d, 4) = b_set_digit(%d, 4, 0)\n", i, i);
   puts("... OK");
   printf("Printing base 3 truth tables: \n");
   bint k;
   puts("\tA\tB\t|\tXOR\tAND\tOR\t|\tSHIFT\tSNR");
   for(k = -1; k <= 1; k++) {
      bint j;
      for(j = -1; j <= 1; j++) {
         printf("\t%2ld\t%2ld \t|\t %2ld \t %2ld \t %2ld \t|\t %2ld\t%2ld\n", k, j,
            bivalent(B_XOR, 1, k, j),
            bivalent(B_AND, 1, k, j),
            bivalent(B_OR, 1, k, j),
            bivalent(B_SHIFT, 1, k, j),
            bivalent(B_SNR, 1, k, j)
   printf("Testing bivalent: \n");
      bint TTTUUUFFF = 1 + 3 + 9 - 729 - 2187 - 6561;
      bint TUFTUFTUF = 1 - 9 + 27 - 243 + 729 - 6561;
      if(bivalent(B_XOR, 9, TTTUUUFFF, TUFTUFTUF) != B_XOR) { printf("... FAIL (in B_XOR)\n"); }
      if(bivalent(B_OR, 9, TTTUUUFFF, TUFTUFTUF) != B_OR) { printf("... FAIL (in B_OR)\n"); }
      if(bivalent(B_AND, 9, TTTUUUFFF, TUFTUFTUF) != B_AND) { printf("... FAIL (in B_AND)\n"); }
      if(bivalent(B_SHIFT, 9, TTTUUUFFF, TUFTUFTUF) != B_SHIFT) { printf("... FAIL (in B_SHIFT)\n"); }
      if(bivalent(B_SNR, 9, TTTUUUFFF, TUFTUFTUF) != B_SNR) { printf("... FAIL (in B_SNR)\n"); }
   puts("... DONE");
   return EXIT_SUCCESS;
10 Apr 2009 16:30
moving up
10 Nov 2012 08:57
