Atom Feed | View unanswered posts | View active topics It is currently 28 Apr 2024 12:54
Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4
[ZX] SE Basic IV 4.0 Anya
But what is "Var" thing anyway?...
Sorry for the late reply. It's just a copy of whatever is in the variables area after the program. I'm making good progress on SE Basic 4.1 now and have added the TRACE, SCROLL, and SPEED commands. The latter replaces two commands (FAST and SLOW).
03 Oct 2013 02:18
Small update to version 4.0. I've backported the new keyboard mode from 4.1 and juggled a few characters around to support the Chloe 280SE's keyboard.
https://www.dropbox.com/s/vbjgqzkvllpwf ... sic405.zip
21 Mar 2014 20:01
Updated to v4.0.7 with experimental Kempston mouse support:
https://dl.dropboxusercontent.com/u/15659782/se407.zip
22 Apr 2014 07:55
Somehow missed this topic, found it only today. Despite already knowing about OpenSE Basic, didn't know about this fork. Seems to be a great project. And it supports 8-bit encoding, just like OpenSE Basic does. Good luck in continuing developing it.
14 Nov 2015 12:29
Playing with SE Basic IV v4 on my TS2068 (in normal mode):
Machine boots as TS2068, but after OUT 244,3 command it switches to SE Basic IV ;)
04 Jun 2016 18:37
I didn't know that I can enter hexadecimal numbers here :)
Like poke &ff00,&ff
Nice :)
12 Jun 2016 06:19
Post Re:
Interesting, but I'll stay with v4.0.4 :roll:
https://gitlab.com/retro-forks/sebasic4
P.S. I want to build simplifyed "ZX Spectrum SE" clone with v4.0.4 onboard and I understand that most likely it's a decade long jorney :rotate:
P.P.S. Links to all major versions - Anya 4.0.7: https://github.com/cheveron/sebasic4/blob/SE-Basic-IV-Anya/
v4.1 Buffy: https://github.com/cheveron/sebasic4/tree/SE-Basic-IV-Buffy
v4.2 Cordelia: https://github.com/cheveron/sebasic4/tree/SE-Basic-IV-Cordelia
09 Jun 2019 09:17
Some clarification on which version of SE Basic to use for what.
If you want maximum Spectrum compatibility, use SE Basic 3.2 (https://zx.itch.io/sebasic3)
If you want a high degree of Spectrum compatibility, plus an 80 column mode, use SE Basic 4.0 (link above).
Version 4.1 was a failed attempt to refactor the code base that introduced a number of bugs. It's really best to avoid it.
If you think you might be interested in developing for the Chloe 280SE microcomputer, use SE Basic 4.2. It has no Spectrum compatibility. It also requires an esxDOS compatible OS kernel (https://zx.itch.io/sebasic4)
23 Jul 2019 05:54
Good to know. Thank you!
23 Jul 2019 18:17
You're welcome. It's also probably worth noting that SE Basic 4.2 is entirely disk based and it *might* be possible to get it to use TR-DOS instead of esxDOS. It avoids all the TR-DOS address traps (because the divMMC emulates TR-DOS). It depends on if TR-DOS will work with the SE Basic 4.2 ROM, which is radically different from the Spectrum ROM.
23 Jul 2019 23:53
Users browsing this forum: No registered users and 11 guests
