Atom Feed | View unanswered posts | View active topics It is currently 27 Apr 2024 07:12
Reply to topic  [ 10 posts ]
[ZX] Multicolor (Rainbow Graphics) & Border effects
Rainbow graphics:
48K - River Raid Tech Demo - 2009:
http://www.worldofspectrum.org/infoseek ... id=0023528
48K - Buzzsaw+ (Foxton Locks Mix) - 2011:
http://www.worldofspectrum.org/infoseek ... id=0027057
48K - ZXodus Engine + Sources (Andrew Owen) - 2011:
http://www.worldofspectrum.org/infoseek ... id=0026639
48K - Bozxle (based on ZXodus) - 2011:
http://www.worldofspectrum.org/infoseek ... id=0027065
48K/128K/+2/+2A/+3 - BIFROST* ENGINE + Sources (Einar Saukas, Dave Hughes) - 2012:
http://www.worldofspectrum.org/infoseek ... id=0027405
Border effects:
48K - BorderTrix + Sources (Andrew Owen) - 2012:
http://www.worldofspectrum.org/infoseek ... id=0027293
48K/128K/+2/+2A/+3 - Rotatrix (Einar Saukas) - 2012:
http://www.worldofspectrum.org/infoseek ... id=0027591
18 Jun 2013 17:11
Classic Border Effects:
48K - Aquaplane (1983):
http://www.worldofspectrum.org/infoseek ... id=0000227
48K - Dark Star (1984):
http://www.worldofspectrum.org/infoseek ... id=0001263
48K - Shock Megademo (1992):
http://www.worldofspectrum.org/infoseek ... id=0007726
18 Jun 2013 20:10
Funny you should mention that. JoeFish only released Buzzsaw+ because he was worried the finished version of Bozxle would be released first. The original ZXodus engine was written in a week. I have a hugely improved version but as Einar already adapted my idea for Bifrost* I'm keeping the ZXodus II engine for my own projects. BorderTrix was written in a couple of hours and was the first western border demo to use that many colours. The lines across the screen actually go all the way from one visible edge of the display to the other. Someone ported it to the Pentagon (and added music) but they forgot to check that the colours were aligned offscreen. There is a slight glitch in it that would require a sub-t-state timing change to fix. I used a loop so the rainbow pattern in the border is only defined once but called three times. And people complained the text didn't scroll!
19 Jun 2013 00:50
Yes, right, "Shock Megademo" is "eastern" even for Russians Poland is civilized Europa :)
P.S. I have a question - BIFROST says to support all Spectrums (including Amstrad models), but ZXodus clearly defined as 48K only, but it looks like working in all models (at least in emulator), so is it really detecting model and adjusting timings as BIFROST?
19 Jun 2013 07:40
BorderTrix does more colours per line in the border than "Shock Megademo". Shock does 2. BorderTrix does 6. But I have seen some Pentagon demos that do more. I think I could probably manage 8 but not as cleanly from the code side.
I think Bifrost* has some timing detect code. ZXodus is timed for the 48K only. However, as it uses contention to synchronize the timing, it kind-of works on other models. You do get some off colour tiles and glitching on non 48 displays though. The ZXodus II engine can be tweaked to run on whatever hardware you want, but is targetted at the Spectrum +2B which has the most t-states per frame out of the Sinclair branded machines. It can handle up to 66 animated rainbow tiles on screen at once. Hardware errors and slower CPUs in the earlier machines mean they can't do as many.
19 Jun 2013 15:42
Another question - ZXodus uses sprites in ColorTILE format.
Could you please explain in details what is this format?
I know that it's 32 bytes of pixels and 32 bytes of attributes for each 16x16 sprite,
but how these bytes organized? I didn't find anything about it...
P.S. According to source code of ColorTILE it looks like a sequence of 2-byte words:
Byte 0: left part of 1st line;
Byte 1: right part of 1st line;
Byte 2: left part of 2nd line;
Byte 3: right part of 2nd line;
Byte 30: left part of 16th line;
Byte 31: right part of 16th line.
Is it correct?
19 Jun 2013 21:58
Is it correct?
That's correct. Bifrost* uses the same format and ZX Paintbrush can export it. I created ColorTILE when I while I was still attempting to port Ultima 4 to the ZX Spectrum SE. It also runs on the TC2048 though as it requires a standard ROM and the Timex 8x1 mode.
20 Jun 2013 01:11
OK, thanks!
20 Jun 2013 04:28
I have an idea! In Russia (and may be not only in Russia) there is some number of extended ZX-compatible computers "ATM Turbo 2+" and its modern "pentagonized" reincarnation ZX Evolution with hardware "multicolor" (8x1 attributes) 640x200 pixels and EGA-like 16 colors per pixel 320x200 (palette 16 out of 64). Theoretically I can create a library with Zxodus and/or Bifrost compatible API so some existing games and "rainbow" sprites can be recompiled/reused in this new hardware with a lot of freed CPU that is not used to switch attributes constantly anymore.What do you think?
P.S. ZX-evolution has its own extended video modes 256x192 multicolor 8x1 (offset between pixels and attributes is #2000) and 256x192 16-colors.
08 Jul 2013 20:15
Interesting reading about "rainbow" effect with code examples :)
http://simonowen.com/blog/2011/09/29/zxodus-engine/
09 Jul 2013 07:48
