Atom Feed | View unanswered posts | View active topics It is currently 04 Jun 2024 05:48
Reply to topic  [ 11 posts ]
Open source CMOS reusable blocks for LTspice IV and Magic 8
In January 2015 I was playing with LTspice IV and decided to create a number of reusable blocks of CMOS logic for our nedoPC.org community.
Later I started adding CMOS layouts, created in Magic VLSI Layout Tool v8.0, and some were even silicon proven in October 2015 for CMOS 0.5um technology...
http://nedopc.org/nedopc/files/nedocon-cmoslib.zip (693K) v1.0alpha (March 2016)
This PUBLIC DOMAIN archive consists of a number of close to reality
CMOS blocks for LTspice IV in form of ASC and ASY files that you need
to copy (from "sym" subfolder) to
C:\Program Files\LTC\LTspiceIV\lib\sym\
You can see internals of any block and you can use it anywhere.
Tests are also included with screenshots of oscillograms. Enjoy!
cmos-not - NOT gate (invertor)
cmos-nand - 2-input NOT-AND gate
cmos-nand3 - 3-input NOT-AND gate
cmos-nor - 2-input NOT-OR gate
cmos-nor3 - 3-input NOT-OR gate
cmos-tgate - transmission gate (SPST switch)
cmos-tgate2 - 2 transmission gates connected as SPDT switch
Then it will be xor, nor-and, rs-trig, d-trig, mux2, mux4, mux8 etc.
P.S. Used book:
Uyemura, John P. Circuit design for CMOS VLSI. 1992 (11th printing 1998) ISBN 0-7923-9184-5
P.P.S. On January 8th, 2016 I started adding silicon proven Magic layouts here...
24 Jan 2015 17:41
Inverter cmos-not (with added parasitic capacitor on output to simulate gate delay - about 0.1ns):
Testing:
Voltage transfer curve:
P.S. In January 2016 CMOS layout 0.5um for Magic v8.0 was added here (silicon proven in October 2015):
Simulation of 1 GHz input (SPICE model extracted from layout by Magic and simulated by ngspice):
24 Jan 2015 18:18
Two input NAND block cmos-nand (with parasitic capacitor on output to simulate gate delay - about 0.2ns):
Test schematics:
Blue curve is output when both inputs connected together and two other curves for cases when one of the inputs tied to high voltage.
P.S. Magic layout and simulation (silicon proven in October 2015):
Both inputs changed, then just one - 1st one (A) and 2nd one (B):
1GHz signal on both inputs:
24 Jan 2015 18:21
Two input NOR cmos-nor
Test schematics:
Blue curve is output when both inputs connected together and two other curves for cases when one of the inputs tied to the ground.
24 Jan 2015 18:24
Single CMOS switch (transmission gate) cmos-tgate
24 Jan 2015 23:14
SPDT CMOS-switch (2 transmission gates) cmos-tgate2
24 Jan 2015 23:55
Three input NAND block cmos-nand3
Test schematics:
Curve is moving if we connect different number of inputs to V+
14 Feb 2015 16:14
Three input NOR block cmos-nor3
Test schematics:
Curve is moving if connect different number of inputs to ground
14 Feb 2015 16:16
I moved library elements to folder "sym"
06 Jun 2015 21:18
I decided to add "silicon proven" layouts of CMOS reusable blocks to the same archive...
06 Jan 2016 14:55
And now on Hackaday!
https://hackaday.io/project/11779-shared-silicon
02 Oct 2016 21:20
