nedoPC.org
Atom Feed | View unanswered posts | View active topics It is currently 18 Feb 2019 14:54
Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
[Ternary] Ternary VM (TVM)
Author Message
It should look better now.
Code:
String add(String[] a, String[] b)
String result_s="";
int lcv=0;
int[] result = {0, 0, 0, 0, 0, 0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // J Note that the array is N+1 trits long, and the last one is carry M.
if(a.length>b.length)
lcv=a.length;
}else{
lcv=b.length;
for(int i=0;i<lcv;i++)
int a1=Integer.valueOf(a[i]);
int b1=Integer.valueOf(b[i]);
if(((a1==1)&&(b1==1))||((a1==-1)&&(b1==-1))){
String[] tryte_=(add_rule(a[i],b[i])).split(",");
int temp=(Integer.parseInt(tryte_[0]));
if(((temp==1)&&(result[i]==1))||((temp==-1)&&(result[i]==-1))){
String[] tryte_1=(add_rule(Integer.toString(result[i]),Integer.toString(temp))).split(",");
result[i]=(Integer.parseInt(tryte_1[0]));
result[i+1]=(Integer.parseInt(tryte_1[1]));
}else{
result[i]=Integer.parseInt((add_rule(Integer.toString(result[i]),Integer.toString(temp))));
temp=(Integer.parseInt(tryte_[1]));
if(((temp==1)&&(result[i+1]==1))||((temp==-1)&&(result[i+1]==-1))){
String[] tryte_1=(add_rule(Integer.toString(result[i+1]),Integer.toString(temp))).split(",");
result[i+1]=(Integer.parseInt(tryte_1[0]));
//result[i+1]=(Integer.parseInt(tryte_1[1]));
}else{
result[i+1]=Integer.parseInt((add_rule(Integer.toString(result[i+1]),Integer.toString(temp))));
else
int temp=(Integer.parseInt((add_rule(a[i],b[i]))));
}else{
result_s=result_s+Integer.toString(result[i]);
result_s=result_s+Integer.toString(result[lcv]);
return result_s;
14 Aug 2008 05:38
Hello all,
below is the Java Class file which can be used for ternary
addition and multiplication.
Ternary API.
TernaryMath.class
This contains following methods:
Compiled from "TernaryMath.java"
class TernaryMath extends java.lang.Object{
TernaryMath();
java.lang.String add_rule(java.lang.String, java.lang.String);
java.lang.String add(java.lang.String[], java.lang.String[]);
java.lang.String subtract(java.lang.String[], java.lang.String[]);
java.lang.String multyply(java.lang.String[], java.lang.String[]);
http://TernaryMath.class
Usage:
The input:
Please provide input only as array of trits.
Also,
Please post your views on same.
Thanks,
18 Aug 2008 01:50
It would be just great if you can also provide link to source code of the class.
Please correct method name from multyply to multiply.
18 Aug 2008 03:40
Profile
Below is the location of the source file:
http://tvm.manojky.net/tmath.php
or
http://tvm.manojky.net/TernaryMath.java
TernaryMath.java
Corrected multyply to multiply.
TernaryMath();
java.lang.String multiply(java.lang.String[], java.lang.String[]);
18 Aug 2008 04:52
Hello All,
Now that i can perform addition and multiplication, can any one suggest me how should i store the information in the file in ternary format, Basically I am looking for file format for ternary.
I have already selected the Tryte codes for Ascii Chars, they are available at following location,
http://manojky.net/terPrj/TernaryWithCharC.htm
19 Aug 2008 00:48
In tunguska, I store the integer values in an array type signed short, which is subsequently compressed with zlib when saved to a file.
This has the advantage of being very fast and very space effective (since a memory image will have lots of zeros).
I suppose you can also save the individual trits in pairs of bytes in a short. This is harder to manipulate, since you need to juggle around a lot of bits to extract and set values.
19 Aug 2008 01:53
Profile
It does not look very effective, since you do not use negative part of diapason that could be easily used for lower case letters and fractional numbers (1/2, 1/3, etc). Also I see no letters for Cyrillic (Russian, Ukrainian, and so on) and Greek alphabets. And some more mathematical symbols have to be added.
19 Aug 2008 02:20
Profile
Hi,
I am planning for use following format,
<hr>
I will store the instructions/definition/method into the METADATA file to read the DATA File, it will help the users to use their own file formats.
Mostly the METADATA file will be in XML Format
Please post your views.
19 Aug 2008 02:37
Yes, I agree, I intentionally left it for future use, as nothing was striking to my mind,
If you can help me in preparing/utilizing the negative part, it will be great.
19 Aug 2008 02:41
19 Aug 2008 02:43
I'll be going with the below mentioned table.
http://tvm.manojky.net/csv/TernaryWithCharC.htm
22 Aug 2008 05:35
Hello All,
Finally I have prepared an applet which converts the ASCII text to tryte, and displays it based on the table mentioned above....
http://tvm.manojky.net/TryteEditor/
Please visit and post your views.
25 Aug 2008 02:55
Here http://trinary.ru/projects/bttencoder/ you can find a coder which do the same that your applet, but it use more effective algorithm (Saved space 33% vs 25%).
To see result press blue button.
You will see code in bytes In the first column and in trytes in the second column.
We use -0+ as equivalent of -1 0 1.
P.S.: The english version of the coder on plan. )) Don't use IE (it's not supported)
Good luck! :)
26 Aug 2008 04:26
Profile
Hi,
Its not possible to save space more or less than 25%,
its a constant value, b'coz,
1 char = 8 bits (1 Byte)
= 6 trits(1 Tryte),
so every time you add a char, you will save only
(1-6/8) ie. .25 = 25%, i am not sure if the application you mentioned works on ternary representation.
please varify.
btw it looks better than mine :-)
Thanks,
26 Aug 2008 09:47
Hi!
It is possible :)
2^8 = 256 variations, аnd 3^6 = 729 variations, when you code 8 bits into 6 trits 729-256 = 473 variations are not used.
It is too much.
In our coder we code every 3 bits into 2 trits.
In this case only one variation is not used (3^2 - 2^3 = 9-8 = 1).
That's why we have 33% economy (1-2/3).
What do you think about it?
26 Aug 2008 12:27
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
Designed by ST Software.
