Page 1 of 1
[ 14 posts ] |
DDT - free software for ternary circuits design
Joined: 08 Jan 2003 23:22 Posts: 22580 Location: Silicon Valley
http://www.nedopc.org/ternary/ddt_0_4_win.zip (109K) | | | | Code: all ternary functions of one argument: NNN = N NNO = SHD(x) = E21(x,N,O) NNP = E21(x,N,P) NON = MUX(x,N,O,N) = E12(x,N,E21(x,O,N)) NOO = BLP(x) = E12(x,N,O) // analog of reverse diode NOP = x // or buffer MUX(x,N,O,P) = E12(x,N,E21(x,O,P)) NPN = MUX(x,N,P,N) = E12(x,N,E21(x,P,N)) NPO = MUX(x,N,P,O) = E12(x,N,E21(x,P,O)) NPP = E12(x,N,P) ONN = NHI(x) = E12(x,O,N) ONO = MUX(x,O,N,O) = E12(x,O,E21(x,N,O)) ONP = MUX(x,O,N,P) = E12(x,O,E21(x,N,P)) OON = E21(x,O,N) OOO = O OOP = BLN(x) = E21(x,O,P) // analog of forward diode OPN = ROU(x) = MUX(x,O,P,N) = E12(x,O,E21(x,P,N)) OPO = MUX(x,O,P,O) = E12(x,O,E21(x,P,O)) OPP = SHU(x) = E12(x,O,P) PNN = NTI(x) = E12(x,P,N) PNO = ROD(x) = MUX(x,P,N,O) = E12(x,P,E21(x,N,O)) PNP = MUX(x,P,N,P) = E12(x,P,E21(x,N,P)) PON = NOT(x) = MUX(x,P,O,N) = E12(x,P,E21(x,O,N)) POO = E12(x,P,O) POP = MUX(x,P,O,P) = E12(x,P,E21(x,O,P)) PPN = PTI(x) = E21(x,P,N) PPO = PHI(x) = E21(x,P,O) PPP = P
Currently DDT (Decision Diagrams for Ternary) source code is located on GitLab: https://gitlab.com/ternary/ddt
01 Aug 2010 21:22 |
It is a free software covered by GPL v3, so source code is available on SourceForge:
http://nedopc.cvs.sourceforge.net/viewv ... c/src/ddt/
To get full sources of all NedoPC SDK do this:
cvs -z3 -d:pserver:anonymous@nedopc.cvs.sourceforge.net:/cvsroot/nedopc checkout -P src
01 Aug 2010 21:24 |
Latest release for Windows:
There is no visualization yet...
01 Aug 2010 21:25 |
Example of "reinvented" full ternary adder (SUM.ddt - i3,i2,i1=o2,o1):
ddtc SUM.ddt generates this c-source: | | | | Code: /* Generated by DDTc v0.4 See www.ternary.info */
#include "ddt.h"
int ddt_sum(int f, DDT i1, DDT i2, DDT i3, DDT* o1, DDT* o2) { DDT r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14; int f1,f2,f3,f4,f5,f6,f7,f8,f9,f10,f11,f12,f13,f14; f1 = ddt_rou(f,i1,&r1); if(f1 < 0) return f1; f2 = ddt_rod(f,i1,&r2); if(f2 < 0) return f2; f3 = ddt_mux(f,i2,r1,r2,i1,&r3); if(f3 < 0) return f3; f4 = ddt_mux(f,i2,r2,i1,r1,&r4); if(f4 < 0) return f4; f5 = ddt_mux(f,i2,i1,r1,r2,&r5); if(f5 < 0) return f5; f6 = ddt_mux(f,i3,r3,r4,r5,&r6); if(f6 < 0) return f6; f7 = ddt_shd(f,i1,&r7); if(f7 < 0) return f7; f8 = ddt_blp(f,i1,&r8); if(f8 < 0) return f8; f9 = ddt_bln(f,i1,&r9); if(f9 < 0) return f9; f10 = ddt_shu(f,i1,&r10); if(f10 < 0) return f10; f11 = ddt_mux(f,i2,r7,r8,O,&r11); if(f11 < 0) return f11; f12 = ddt_mux(f,i2,r8,O,r9,&r12); if(f12 < 0) return f12; f13 = ddt_mux(f,i2,O,r9,r10,&r13); if(f13 < 0) return f13; f14 = ddt_mux(f,i3,r11,r12,r13,&r14); if(f14 < 0) return f14; if(o1) *o1 = r6; if(o2) *o2 = r14; return f1+f2+f3+f4+f5+f6+f7+f8+f9+f10+f11+f12+f13+f14; }
Testing results:
It requires 12 chips DG403
P.S. Interesting thing about this solution is that it's identical to the article from 1993:
http://www.hindawi.com/journals/vlsi/19 ... 6.abs.html
Actually DDT's automatic design made some improvements by changing 4 multiplexers to simpler devices (E12 and E21) - and because of that we need just 12 chips to implement 14 functions (each DG403 may be connected as two E12s or two E21s).
01 Aug 2010 21:35 |
Mac Buster
Wow, at first reading I came to strange conclusion that you're talking about scheme that can dynamicaly rewire connections and so the processing device can read op-codes from RAM, decode it, rewire DG403s connections, execute the command and return result. That would be just fantastic - small ammount of executional set of DG403 chips (operational matrix) and large "re-wire controller". Crazy idea. I know I am crazy.
03 Aug 2010 04:31 |
No, DDT is for static solutions. Dynamic solution is also possible with DG403s, but it is heavy. 1-output ternary LUT (look-up table) based on DG403s requires D(n)=3*D(n-1)+1 chips, where n - number of inputs and D(1)=1, so:
D(1)=1 (looks like ROM for 3 trits)
D(2)=4 (looks like ROM for 9 trits)
D(3)=13 (looks like ROM for 27 trits)
D(4)=40 (looks like ROM for 81 trits)
D(5)=121 (looks like ROM for 243 trits)
D(6)=364 (looks like ROM for 729 trits)
D(7)=1093 (looks like ROM for 2187 trits)
D(8)=3280 (looks like ROM for 6561 trits)
D(9)=9841 (looks like ROM for 19683 trits)
D(10)=29524 (looks like ROM for 59049 trits)
etc.
Also if we have M outputs we need M*D(N) chips where N - number of inputs.
04 Aug 2010 04:52 |
Now DDT generated these schemes:
NOT = 2 x DG403 (50% of them),
MIN or MAX = 2 x DG403 (75% of them),
Half Adder = 6 x DG403 (83% of them),
Full Adder = 12 x DG403,
Sign of 3-trit digit = 2 x DG403,
Left/Right Shifter of 3-trit digit = 4 x DG403 (75% of them),
Universal Unary Function for 3-trit argument = 4 x DG403 (75% of them),
Universal Binary Function for 3-trit arguments = 12 x DG403,
Converter 1-trit to 2-bit = 2 x DG403 (75% of them),
Converter 2-trit to 4-bit = 8 x DG403,
Converter 3-trit to 5-bit = 18 x DG403,
Converter 4-trit to 7-bit = 39 x DG403,
Converter 5-trit to 8-bit = 83 x DG403,
Converter 6-trit to 10-bit = 162 x DG403,
Converter 2-bit to 1-trit = 1 x DG403,
Converter 4-bit to 2-trit = 11 x DG403,
Converter 5-bit to 3-trit = 32 x DG403,
Converter 7-bit to 4-trit = 80 x DG403,
Converter 8-bit to 5-trit = 154 x DG403,
Converter 10-bit to 6-trit = 309 x DG403 (not optimal),
Increment/Decrement of 1-trit digit = 6 x DG403 (83% of them),
Increment/Decrement of 2-trit digit = 10 x DG403,
Increment/Decrement of 3-trit digit = 16 x DG403,
Increment/Decrement of 4-trit digit = 22 x DG403,
Increment/Decrement of 5-trit digit = 28 x DG403,
Increment/Decrement of 6-trit digit = 34 x DG403,
Increment/Decrement of 7-trit digit = 40 x DG403,
Increment/Decrement of 8-trit digit = 46 x DG403,
Increment/Decrement of 9-trit digit = 52 x DG403 (48 manually),
Comparison 1-trit digits = 2 x DG403,
Comparison 2-trit digits = 6 x DG403,
Comparison 3-trit digits = 8 x DG403,
Comparison 4-trit digits = 12 x DG403,
Comparison 5-trit digits = 44 x DG403 (not optimal),
Adder for 1-trit digits = 12 x DG403 (delay 3) - the same as Full Adder above,
Adder for 2-trit digits = 28 x DG403 (delay 5) versus sequential version, created manually - 24 x DG403 with delay 6,
Adder for 3-trit digits = 50 x DG403 (delay 7) versus sequential version, created manually - 36 x DG403 with delay 9,
Adder for 4-trit digits = 76 x DG403 (delay 9) versus sequential version, created manually - 48 x DG403 with delay 12,
Adder for 5-trit digits = 106 x DG403 (delay 11) versus sequential version, created manually - 60 x DG403 with delay 15,
1-trit Multiplier = 2 x DG403,
2-trit Multiplier = 30 x DG403,
3-trit Multiplier = 188 x DG403,
4-trit Multiplier = 1088 x DG403
07 Dec 2010 05:04 |
jay4th
For addition, beyond 3 to 5 trits, you may need to look at higher level architecture such as carry-predict, or (my favorite) carry-select adders. The Select part of carry-select can be done with about 2/3 chip delays and about #trits/4 chips. (About because you are actually selecting not only the sum, but also the carry out).
07 Dec 2010 06:14 |
Do you have a picture describing this approach?
07 Dec 2010 17:40 |
jay4th
http://en.wikipedia.org/wiki/Carry-select_adder has a good presentation for the binary case. For trinary obviously the select stages must choose between three 'speculativly' calculated sums: Ahi + Bhi + -1, Ahi + Bhi + 0, Ahi + Bhi + 1.
The chip count then is 3x(chips for multiply) + chips for 3:1 mux. And additional chips for adding the low part. Obvious extensions for more than two parts.
Right now it is believed that the fastest adders that can be built use a carry predict portion and then a sum select portion. The "carry-select" adder is a hybrid, doing ripple carry between select stages.
That is, if you are adding Alo Amed Ahi to Blo Bmed Bhi, then which of the three computations of Bhi + Ahi + C depends on the result of which of the choices of Bmed + Amed you made.
The pictures make it much clearer I think.
Jay
07 Dec 2010 19:05 |
I just finished some visualization for full adder:
| | | | Code: /* Generated by DDTc v0.5 Solution is 12 x DG403 See www.ternary.info */
#include "ddt.h"
int ddt_sum(int f, DDT i1, DDT i2, DDT i3, DDT* o1, DDT* o2) { DDT r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14; int f1,f2,f3,f4,f5,f6,f7,f8,f9,f10,f11,f12,f13,f14; f1 = ddt_mux(f,i1,O,P,N,&r1); if(f1 < 0) return f1; f2 = ddt_mux(f,i1,P,N,O,&r2); if(f2 < 0) return f2; f3 = ddt_mux(f,i2,r1,r2,i1,&r3); if(f3 < 0) return f3; f4 = ddt_mux(f,i2,r2,i1,r1,&r4); if(f4 < 0) return f4; f5 = ddt_mux(f,i2,i1,r1,r2,&r5); if(f5 < 0) return f5; f6 = ddt_mux(f,i3,r3,r4,r5,&r6); if(f6 < 0) return f6; f7 = ddt_e21(f,i1,N,O,&r7); if(f7 < 0) return f7; f8 = ddt_e12(f,i1,N,O,&r8); if(f8 < 0) return f8; f9 = ddt_e21(f,i1,O,P,&r9); if(f9 < 0) return f9; f10 = ddt_e12(f,i1,O,P,&r10); if(f10 < 0) return f10; f11 = ddt_mux(f,i2,r7,r8,O,&r11); if(f11 < 0) return f11; f12 = ddt_mux(f,i2,r8,O,r9,&r12); if(f12 < 0) return f12; f13 = ddt_mux(f,i2,O,r9,r10,&r13); if(f13 < 0) return f13; f14 = ddt_mux(f,i3,r11,r12,r13,&r14); if(f14 < 0) return f14; if(o1) *o1 = r6; if(o2) *o2 = r14; return f1+f2+f3+f4+f5+f6+f7+f8+f9+f10+f11+f12+f13+f14; }
Schematics were created in Logisim - "x2" means "ternary input/output"
P.S. Image creation is not yet automatic...
02 Jan 2011 20:43 |
1-trit half-adder (or 1-trit increment/decrement scheme):
| | | | Code: /* Generated by DDTc v0.5 Solution is 6 x DG403 See www.ternary.info */
#include "ddt.h"
int ddt_inde1_(int f, DDT i1, DDT i2, DDT* o1, DDT* o2) { DDT r1,r2,r3,r4,r5,r6; int f1,f2,f3,f4,f5,f6; f1 = ddt_mux(f,i1,P,N,O,&r1); if(f1 < 0) return f1; f2 = ddt_mux(f,i1,O,P,N,&r2); if(f2 < 0) return f2; f3 = ddt_mux(f,i2,r1,i1,r2,&r3); if(f3 < 0) return f3; f4 = ddt_e12(f,i1,N,O,&r4); if(f4 < 0) return f4; f5 = ddt_e21(f,i1,O,P,&r5); if(f5 < 0) return f5; f6 = ddt_mux(f,i2,r4,O,r5,&r6); if(f6 < 0) return f6; if(o1) *o1 = r3; if(o2) *o2 = r6; return f1+f2+f3+f4+f5+f6; }
Manually created 3-trit increment/decrement scheme (3 half-adders are used):
07 Jan 2011 07:50 |
Interesting, but I just found DDT approach described in the book from 1975: S.Thelliez "Introduction to the study of ternary switching structures (Information and systems theory, Volume 4)". In this book ternary multiplexer named "T operator".
10 Aug 2011 20:48 |
currently working on visualization...
10 Nov 2012 09:04 |
Page 1 of 1
[ 14 posts ] |
Users browsing this forum: No registered users and 4 guests |
