fifan
Joined: 06 Oct 2006 03:17 Posts: 859 Location: г.Лянтор,Сургутского р-на,ХМАО
I suggest to collect Galaksija by Voja Antonich (see bottom of web page - http://www.spetsialist-mx.ru/Galaksija/index.html). PVV makes a new computer Galaksija Plus.
27 Nov 2017 08:14 |
Luciano
Hi Fifan and PVV Tested the zx97_9.pdsprj (zx80) and the gal6(Galaksija) both are working on proteus 8.3 (sometimes proteus Suddenly Crashes after a few minutes of simulation.. sometimes not.. maybe my computer is slow.. using 65% cpu during simulation) Using the x80_v11.dll instead of x80.dll.. that is correct? How can i load a program using the emulator? Do you have a Galaksija Plus simulation files too? (My version here is gal6) Thank you very much!!
27 Nov 2017 09:43 |
PVV
It is happend with old version display.dll, I add new version in last archive, use it. I not tested new x80_v11.dll with zx97, so it's time for testing it It is difficult question. For this time there is two ways for it. First is use ROM disk for simulated's computer. Of course it is needed software support in such computer. (For example RK-86 have it, and I used this way in the beginning). Second way is new - adding support for SD card. All last projects I use this way. Hardware part of SD support are known and not change, and software part modified as needed. I include Galaksija Plus schematic in pdf, or you need Proteus project file? PS: to moderators - ничего, что мы по английски тут общаемся? мы ничего не нарушаем? или давать и русский перевод?
27 Nov 2017 12:41 |
Luciano
Hi PVV Yes, if possible, please send me the simulation project files for Galaksija and rom disk for RK-86 too.. i want to test all. Thanks a lot!!
27 Nov 2017 13:41 |
PVV
about RK-86 in PROTEUS: viewtopic.php?f=93&t=16296#p130761Galaxy will be bit late, tomorrow, I make common archive.
27 Nov 2017 14:12 |
Joined: 08 Jan 2003 23:22 Posts: 22615 Location: Silicon Valley
Guys, should we move conversation in English to proper place? http://www.nedopc.org/forum/viewforum.php?f=62I can split the topic (I'm an admin ; )
27 Nov 2017 17:41 |
fifan
Да, что это мы. Давайте всё по русски здесь писать.
Вопрос к PVV: возможно как-то сделать алтернативный видеовыход к Галаксии Плюс? Не через композит. Почему спрашиваю. Оказывается новые телевизоры очень капризны к видеосигналам подаваемым на композит. У меня два телевизора и оба ну никак не хотят нормально показывать. Убедился в этом подключив после Галаксии Плюс Специалист - практически отсутствие изображения, хотя осциллограф показывает наличие сигналов.
28 Nov 2017 00:24 |
PVV
Просто не русскоговорящий любитель ретро пк задавал вопросы, которые мы уже здесь обсуждали, по тому ответы на них и были по английски. Сделал в Протеусе схему ГалаксииПлюс, с одной МС памяти на 32КБ, с чип селектом для SD интерфейса, с 'вытаскиванием' скрытых за портами 2КБ памяти и использованием ее для переменных SD интерфейса, плюс тактирование схемы идет от 12.288, а не 6.144Мгц. Файл GALP_SD4.zip. <- Last working GalaxyPlus's Proteus project. Вот только с использованием 12.288 кварца вижу одну проблему - для тактирования звукового чипа нужна частота 1.5..Мгц, которая при этом кварце не получается... что делать? оставлять 6.144 как это изначально было или при использовании AY чипа на внешней плате ставить еще и ТМ2 для деления процессорного клока в 3..Мгц, там то все равно еще будет как минимум корпус ЛЕ1? Можно. Я сам с этим столкнулся, и этот вопрос уже прорабатываю... вот здесь обсуждался вариант скалера на VGA, я его начал делать, но с дисплеем пока не могу своим разобраться (странный интерфейс у него). Однако эту схему можно модифицировать под наши нужды и организовать вывод на стандартный монитор, ну или телевизор с VGA входом. Проблема только с кадровой разверткой в 50Гц, как ее монитор и телевизор примут? Пока наброски этой схемы, файл ...16_vga... SD4.zip (all Galaxy and GalaxyPlus software, known for this moment) набор всех программ для Галаксии и ГалаксииПлюс, что я нашел, надо проверять.Там что-то со звуком есть, но я свою макетку переделываю в части подключения SD и одного чипа на 32КБ, по тому еще не проверил звук.
28 Nov 2017 02:10 |
fifan
Очень уж сложно. Ещё по микросхемам один компьютер, узконаправлено на конкретный монитор. Нужно что-то универсальное. Вот не плохая задумка была (ZX Kit1), я под неё на своём Специалисте 48 SRAM делан выход, но - не пошло, там картинка указана - http://zx-pk.ru/threads/23487-spetsialist-48-sram-spetsialist_mkh-512-sram-zapusk.html?p=713404&viewfull=1#post713404.
28 Nov 2017 04:11 |
Luciano
Я проверю файлы, спасибо за вашу помощь! (thank you)
28 Nov 2017 04:19 |
PVV
sd_dos с поддержкой Галаксии
добавлено: в версии 7_4 введен define для 'старого' типа SD интерфейса(msx)
29 Nov 2017 23:35 |
PVV
Звук запустил, нашел одну программку(GalaksijaMusicAY.gtp) которая выводит мелодию на AY чип, все играет. AY подключена по схеме Плюса. А вот еще одна програмка Sintesajzer (19xx)(Vujkov, Dragan)(YU).gtp у меня не заработала, при старте на экране проскакивает изображение музыкальной клавиатуры и после этого черный экран ( те развертка есть) на клавиатуру не реагирует звуков не издает. Проверил эту программу в эмуляторах b2m и GalaxyWin, поведение похожее, хотя стартовую заставку показывает до нажатия на клавиатуре, но при нажатии любой клавиши - черный экран...
30 Nov 2017 22:28 |
PVV
Разобрался с этим Sintesajzer , все похоже, что так и задумано и синтезатор работает, но не через AY чип, а через выход на магнитофон. Экран же гаснет то-же правильно, в коде стоит команда отключить прерывания, вот отрисовка экрана и не происходит. Подключил динамик к магнитофонному выходу и там звучат разные ноты в зависимости от нажатой кнопки.
01 Dec 2017 13:27 |
Ну правильно - с прерываниями звук будет хриплый прерывистый. Раз уж звук генерируют чисто программным путём. Видимо, у Galaksija и при записи/чтении с магнитофона экран гас, как у "РК-86" или "Микроши". Как-никак "задача реального времени" исполняется...
01 Dec 2017 13:55 |
PVV
вот как я вижу вариант печатной платы для Галаксии, в варианте под LUT: синие линии это перемычки, я специально между ножек мс дорожки не проводил, а выпускал их перемычками. Размер платы получается 115х210. Поводники\зазоры худшие значения 0.45\0.44, но старался сделать более широкие дорожки где возможно. Правда есть мысль сразу на эту плату и SD добавить, тк работать без нее будет проблематично. Есть ли смысл? Просто SD контроллер надо будет подключать на дополнительной плате всегда, и к тому же будет разъем соединительный заниматься, а когда все на одной, то все хорошо, и изготовление за один раз все сделать и не мучаться, и разъем свободный, для программатора или тестера микросхем, которые имеются у Галаксии. Ну и найдутся ли желающие эту плату изготовить? -ниже есть плата с меньшим габаритом
19 Dec 2017 03:28 |
Users browsing this forum: No registered users and 16 guests |
