RISC-V и реализация функций работы с тритами
askfind
Joined: 04 Jan 2016 09:15 Posts: 657 Location: Russia, S.- Peterburg
TODO Emulator-Setun-1958-Assembler ver.0.10
### 3.7. Операции над троичными числами TRS_t
``` TRS_t tests(...) : a0=0xAAAA, a1=0xBBBB; clean_trs(a0,a1)->0 0 ts1=0x1, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=0; get_trit(ts1,ts0,pos)->0 ts1=0x4, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=2; get_trit(ts1,ts0,pos)->0 ts1=0x0000, ts0=0x0000, pos=5, val=-1; set_trit(ts1,ts0,pos,val)->32 0 ts1=0x0000, ts0=0x0000, pos=5, val=0; set_trit(ts1,ts0,pos,val)->0 0 ts1=0x0000, ts0=0x0000, pos=5, val=+1; set_trit(ts1,ts0,pos,val)->32 32 ts1=0x0080, ts0=0x0080, shift=+2; shift_trs_t11(ts1,ts0, shift)->128 128 ts1=0x0080, ts0=0x0080, shift=-3; shift_trs_t11(ts1,ts0, shift)->16 16 ```
_________________ "Ученье свет, а неученье — тьма. Дело мастера боится, и коль крестьянин не умеет сохою владеть — хлеб не родится." (С)
09 Mar 2024 08:56 |
askfind
TODO Emulator-Setun-1958-Assembler ver.0.11
``` TRS_t tests(...) : a0=0xAAAA, a1=0xBBBB; clean_trs(a0,a1)->0 0 ts1=0x1, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=0; get_trit(ts1,ts0,pos)->0 ts1=0x4, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=2; get_trit(ts1,ts0,pos)->0 ts1=0x0000, ts0=0x0000, pos=5, val=-1; set_trit(ts1,ts0,pos,val)->32 0 ts1=0x0000, ts0=0x0000, pos=5, val=0; set_trit(ts1,ts0,pos,val)->0 0 ts1=0x0000, ts0=0x0000, pos=5, val=+1; set_trit(ts1,ts0,pos,val)->32 32 ts1=0x0080, ts0=0x0080, shift=+2; shift_trs(ts1,ts0, shift)->128 128 ts1=0x0080, ts0=0x0080, shift=-3; shift_trs(ts1,ts0, shift)->16 16 ts1=0x0100, ts0=0x0100, pos1=8,pos2=4; slice_trs ($ts1,$ts0,$pos1,$pos2)->16 16 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; and_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; and_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; or_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; or_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; xor_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 0 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; xor_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 0 ```
09 Mar 2024 13:06 |
askfind
Re: RISC-V и реализация функций работы с тритами TODO Emulator-Setun-1958-Assembler ver.0.12### 3.7. Операции над троичными числами TRS_t ``` TRS_t tests(...) : a0=0xAAAA, a1=0xBBBB; clean_trs(a0,a1)->0 0 ts1=0x1, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x1,pos=0; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=0; get_trit(ts1,ts0,pos)->0 ts1=0x4, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->1 ts1=0x0, ts0=0x4,pos=2; get_trit(ts1,ts0,pos)->-1 ts1=0x0, ts0=0x0,pos=2; get_trit(ts1,ts0,pos)->0 ts1=0x0000, ts0=0x0000, pos=5, val=-1; set_trit(ts1,ts0,pos,val)->32 0 ts1=0x0000, ts0=0x0000, pos=5, val=0; set_trit(ts1,ts0,pos,val)->0 0 ts1=0x0000, ts0=0x0000, pos=5, val=+1; set_trit(ts1,ts0,pos,val)->32 32 ts1=0x0080, ts0=0x0080, shift=+2; shift_trs(ts1,ts0, shift)->128 128 ts1=0x0080, ts0=0x0080, shift=-3; shift_trs(ts1,ts0, shift)->16 16 ts1=0x0100, ts0=0x0100, pos1=8,pos2=4; slice_trs ($ts1,$ts0,$pos1,$pos2)->16 16 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; and_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; and_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; or_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; or_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 32 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x00FF, tryte2.0=0xFFFF; xor_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 0 tryte1.1=0xFF00, tryte1.0=0xFFFF, tryte2.1=0x0000, tryte2.0=0x0000; xor_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->32 0 tryte1.1=0x0000, tryte1.0=0x00FF; not_trs ($tryte1_1,$tryte1_0)->255 -1 tryte1.1=0x0001, tryte1.0=0x0001, tryte2.1=0x0001, tryte2.0=0x0001; add_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->3 2 tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; add_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->1 1 tryte1.1=0x0002, tryte1.0=0x0002, tryte2.1=0x0001, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->3 0 tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->0 0 tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->1 1 tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->1 0 ```
10 Mar 2024 03:51 |
askfind
Эмулятор троичной машины 'СЕТУНЬ' SETUN-1958 VM на языке Assembler Ссылка: https://github.com/askfind/Emulator-Set ... embler.gitEmulator-Setun-1958-Assembler ver.0.13TEST Ok' Макросы работы с полем тритов: TRITS-32 = [t31...t0] - обозначение позиции тритов в числе Операции с тритами:and_t or_t xor_t not_t sum_half_t sum_t
Операции с трайтами:get_trit set_trit shift_trs slice_trs and_trs or_trs xor_trs not_trs add_trs sub_trs inc_trs dec_trs
10 Mar 2024 08:02 |
askfind
Re: RISC-V и реализация функций работы с тритами TODO Emulator-Setun-1958-Assembler ver.0.14 Вывод троичного числа в тестах. | | | | Code: tryte1.1=0x0001, tryte1.0=0x0001, tryte2.1=0x0001, tryte2.0=0x0001; add_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->trs : [000000000000000000000000000000+-] tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; add_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->trs : [000000000000000000000000000000-+] tryte1.1=0x0002, tryte1.0=0x0002, tryte2.1=0x0001, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->trs : [000000000000000000000000000000--] tryte1.1=0x0000, tryte1.0=0x0001, tryte2.1=0x0000, tryte2.0=0x0001; sub_trs ($tryte1_1,$tryte1_0,$tryte2_1,$tryte2_0)->trs : [00000000000000000000000000000000] tryte1.1=0x0004, tryte1.0=0x0004; inc_trs ($tryte1_1,$tryte1_0)->trs : [00000000000000000000000000000-0+] tryte1.1=0x0004, tryte1.0=0x0004; dec_trs ($tryte1_1,$tryte1_0)->trs : [00000000000000000000000000000-0-] SETUN_trs tests(...) : | | | | |
10 Mar 2024 13:04 |
askfind
Re: RISC-V и реализация функций работы с тритами TODO Emulator-Setun-1958-Assembler ver.0.15
10 Mar 2024 14:19 |
askfind
ОНЛАЙН ТРАНСЛЯЦИЯ в группе Telegram "SETUN" Доклад на тему: "Троичные операции на ассемблере для архитектуре RISC-V. Эмуляция троичной машины "СЕТУНЬ". Место: г.С-Петербург, Failover Bar (4-ая Советская, д. 7) Дата: 6 апреля 2024 года.Время: 17-00 мск.Докладчик: Владимир Васильев.Приглашение от мобильных разработчиков: Ссылка: Канал с анонсами — https://t.me/mobile_broadcast_newsПо вопросам сообщества: @packovv, @CLTanuki
01 Apr 2024 11:38 |
Users browsing this forum: No registered users and 41 guests |
