Atom Feed | View unanswered posts | View active topics It is currently 18 Apr 2024 17:43
Reply to topic  [ 1 post ]
Визуальный симулятор ARM1
http://www.righto.com/2015/12/reverse-engineering-arm1-ancestor-of.html
Almost every smartphone uses a processor based on the ARM1 chip created in 1985... The ARM1 chip is built from functional blocks, each with a different purpose. Registers store data, the ALU (arithmetic-logic unit) performs simple arithmetic, instruction decoders determine how to handle each instruction, and so forth. Compared to most processors, the layout of the chip is simple, with each functional block clearly visible. (In comparison, the layout of chips such as the 6502 or Z-80 is highly hand-optimized to avoid any wasted space. In these chips, the functional blocks are squished together, making it harder to pick out the pieces)... The ARM1 was designed in 1985 by engineers Sophie Wilson (formerly Roger Wilson) and Steve Furber of Acorn Computers. The chip was originally named the Acorn RISC Machine and intended as a coprocessor for the BBC Micro home/educational computer to improve its performance. Only a few hundred ARM1 processors were fabricated, so you might expect ARM to be a forgotten microprocessor, a historical footnote of the 1980s. However, the original ARM1 chip led to the amazingly successful ARM architecture with more than 50 billion ARM chips produced...
http://blog.visual6502.org/2015/11/the-visual-arm1.html
http://visual6502.org/sim/varm/armgl.html
06 Jan 2016 13:03
