Atom Feed | View unanswered posts | View active topics It is currently 28 Apr 2024 09:31
Reply to topic  [ 5 posts ]
портативный дебаггер для Arduino / AVR
:D
всётаки умные мысли посещают отдельных индивидов!
сделали наконец-то "безкомпьютерную ардуину" :kruto:
портативный девайс (стоит меньше 50$ : экран за $30 и клон ардуины за 20) следит за состоянием портов, и выводит их на экран. С помощью 5-кнопочной клавы значения можно менять. :rotate:
вот видюха - http://vimeo.com/20620134
The Computerless Arduino consists of two major components; an Arduino-compatible microcontroller loaded with a realtime code interpreter, and a stand-alone 5 button LCD display to display port values and manipulate code. The display can be connected to the Arduino via a 4-pin port at any time to peek at In/Out values, view the current code, and make changes as desired.
By keeping the display separate, it’s possible to have many dedicated Arduino modules (we’re using one of the smallest, cheapest, and most-capable Arduino clones, the Teensy2.0 for $18), without needing to spend much on each additional device. For the display we’re using the super small uLCD-144 (by 4D Systems for $29), and the system could easily be modified to use a larger display or computer if desired.
The programming instruction set for the Computerless Arduino is quite small, making it easy for novices to get started while still working with real code. Navigating the user interface is a bit tedious on such a tiny display, but it’s easy to learn and provides everything you need — a basic multichannel signal scope, a code page for the setup() function which runs once at startup, and 8 pages of code for the loop() function which provides the main functionality and runs over-and-over forever.
страница проекта: http://labs.teague.com/?p=933
08 Mar 2011 03:07
Что-то я не понял, как 3-кнопочный пульт справляется с программированием на ассемблере для AVR?
Но идея очень здравая. Я уже давно хочу сделать подобную вещь на JAVA для
программирования на ассемблере для 580ВМ80...
Почему на JAVA - а чтобы заюзать можно было старый ненужный сотик.
Тогда заливать софт можно через последовательный интерфейс прямо в эмуляторы
или в сами компьютеры.
Вот только опыта на JAVA у меня немного..
Есть у нас спецы по JAVA? Может возьмёмся? Идея-то очень интересная и чисто
софтверная ...
PS. А еще я очень не люблю соревнования, где устаревший сотовый надо кидануть
на дальность как гранату. На мой взгляд - современное варварство...
12 Mar 2011 13:04
не 3-х а 5-кнопчатый
там МК дисплея имеет какую-то прошивку, которая и обеспечивает всю графику, взаимодействие с ардуиной... :roll:
13 Mar 2011 01:04
Так вроде у ардуины собственный интерпретируемый макроязык? Нет? Видимо как-то на это дело завязано. По ардуине есть сайтик "по-русски", надо на нем посмотреть чего оно там на самом деле.
P.S. Насчет соревнований поддержу, ибо действительно варварство.
15 Mar 2011 01:54
У "Ардуины" обычный C++ с чуть поправленным препроцессором и загрузчиком через последовательный порт.
15 Mar 2011 12:41
