Real i8085 + Xilinx CPLDs + 2 * SIMM30 = Orionix :)
Joined: 08 Jan 2003 23:22 Posts: 22625 Location: Silicon Valley
Пренёс Хардваремановско-Альтеровский Орион с одним симмом в отдельный топик
http://www.nedopc.org/forum/viewtopic.php?t=10522
03 Dec 2013 15:14 |
03 Dec 2013 19:22 |
Вот чего из твоего Верилога нагенерилось для XC9572XL:
| | | | Code: ************************* Mapped Resource Summary **************************
Macrocells Product Terms Function Block Registers Pins Used/Tot Used/Tot Inps Used/Tot Used/Tot Used/Tot 7 /72 ( 10%) 13 /360 ( 4%) 11 /216 ( 5%) 7 /72 ( 10%) 5 /34 ( 15%)
** Function Block Resources **
Function Mcells FB Inps Pterms IO Block Used/Tot Used/Tot Used/Tot Used/Tot FB1 4/18 3/54 3/90 2/ 9 FB2 2/18 4/54 6/90 2/ 9 FB3 1/18 4/54 4/90 1/ 9 FB4 0/18 0/54 0/90 0/ 7 ----- ----- ----- ----- 7/72 11/216 13/360 5/34
* - Resource is exhausted
** Global Control Resources **
Signal 'MClk' mapped onto global clock net GCK1. Global output enable net(s) unused. Global set/reset net(s) unused.
** Pin Resources **
Signal Type Required Mapped | Pin Type Used Total ------------------------------------|------------------------------------ Input : 0 0 | I/O : 4 28 Output : 4 4 | GCK/IO : 1 3 Bidirectional : 0 0 | GTS/IO : 0 2 GCK : 1 1 | GSR/IO : 0 1 GTS : 0 0 | GSR : 0 0 | ---- ---- Total 5 5
************************* Summary of Mapped Logic ************************
** 4 Outputs **
Signal Total Total Loc Pin Pin Pin Pwr Slew Reg Init Name Pts Inps No. Type Use Mode Rate State CpuClk 1 2 FB1_2 1 I/O O STD FAST SET nCAS 4 4 FB2_2 35 I/O O STD FAST RESET PixClk 2 2 FB2_8 38 I/O O STD FAST RESET nRAS 4 4 FB3_2 11 I/O O STD FAST RESET
** 3 Buried Nodes **
Signal Total Total Loc Pwr Reg Init Name Pts Inps Mode State State<3> 1 3 FB1_16 STD RESET State<1> 1 1 FB1_17 STD RESET State<0> 0 0 FB1_18 STD RESET
** 1 Inputs **
Signal Loc Pin Pin Pin Name No. Type Use MClk FB1_9 5~ GCK/I/O GCK
********** Mapped Logic **********
FTCPE_CpuClk: FTCPE port map (CpuClk,CpuClk_T,MClk,'0','0'); CpuClk_T <= (State(0) AND State(1));
FDCPE_PixClk: FDCPE port map (PixClk,PixClk_D,MClk,'0','0'); PixClk_D <= State(0) XOR PixClk_D <= State(1);
FTCPE_State0: FTCPE port map (State(0),'1',MClk,'0','0');
FTCPE_State1: FTCPE port map (State(1),State(0),MClk,'0','0');
FTCPE_State3: FTCPE port map (State(3),State_T(3),MClk,'0','0'); State_T(3) <= (State(0) AND State(1) AND NOT CpuClk);
FDCPE_nCAS: FDCPE port map (nCAS,nCAS_D,MClk,'0','0'); nCAS_D <= ((NOT State(0) AND State(1)) OR (State(1) AND NOT State(3)) OR (State(1) AND NOT CpuClk) OR (State(0) AND NOT State(1) AND State(3) AND CpuClk));
FDCPE_nRAS: FDCPE port map (nRAS,nRAS_D,MClk,'0','0'); nRAS_D <= ((NOT State(0) AND NOT State(1)) OR (State(0) AND State(1) AND NOT State(3)) OR (State(0) AND State(1) AND NOT CpuClk) OR (NOT State(1) AND State(3) AND CpuClk));
Register Legend: FDCPE (Q,D,C,CLR,PRE,CE); FTCPE (Q,D,C,CLR,PRE,CE); LDCP (Q,D,G,CLR,PRE);
03 Dec 2013 22:19 |
Error404
Joined: 05 Oct 2006 04:45 Posts: 269 Location: Moscow
Все клево конечно, но встает вопрос, а чо не на i4004?
_________________ Всем добра!
05 Dec 2013 00:22 |
ЖЫР
05 Dec 2013 00:26 |
vinxru
Joined: 27 Mar 2013 04:55 Posts: 587 Location: 62.192.229.16
Почему то все думают, что СИМЫ у всех есть. Все равно заказывать детальки, так что можно использовать все что легкодоставаемо через ebay (и аналоги)
05 Dec 2013 01:22 |
Ну если бы оригинал был на i4004...
ИМХО: Оспектрумовливание советских компов (путём приклеивания Z80-проца соплями с 50 Гц прерыванием) было ошибкой - я строю свою альтернативную историю!
05 Dec 2013 04:39 |
Симы тоже вполне доставаемы через ebay
05 Dec 2013 05:01 |
Блиттер можно сделать опциональным (в виде отдельно стоящего XC9572XL) и по идее можно копировать не только в пределах экранных областей, но и вообще в пределах всех симов (для этого правда нужно будет задавать уже не 16, а 22 бита адреса), и не только симов, но и скажем и из ПЗУ-картриджа (который вставляется в общую память по биту P7 порта управления страницами памяти):
0000 0001 - копируем в пределах первого сима
0000 0010 - копируем в пределах второго сима
0000 0011 - копируем в обоих симах (16 бит за раз)
0001 0001 - копируем из ПЗУ в первый симм
0001 0010 - копируем из ПЗУ во второй симм
Биты 2 и 3 оставляем про запас на будущее (если вдруг дойдут руки сделать 4 сима для 16-цветного режима), а бит 7 в будущем сможет задавать копирование в пределах симов с накладыванием маски (тоже на будущее)...
P.S. Бит 5 можно заставить переключать приёмник при копировании:
0010 0001 - читаем из первого сима, но пишем во второй
0010 0010 - читаем из второго сима, но пишем в первый
0010 0011 - меняем байты в симах местами?
P.P.S. А в случае ПЗУ этот бит может выбирать вторую половинку ПЗУ-картриджа:
0011 0001 - копируем из второй половинки ПЗУ в певый сим
0011 0010 - копируем из второй половинки ПЗУ во второй сим
Хотя наверное это тоже на будущее...
P.P.P.S. А факт окончания копирования можно вводить через бит последовательного порта либо через одно из новых прерываний 8085 (которые вроде как можно читать программно без непосредственно самого прерывания).
05 Dec 2013 07:45 |
Z80 много где применялся и прерывания по КСИ тоже.
05 Dec 2013 16:02 |
ARM ещё больше где применяется, но это ведь не повод?
05 Dec 2013 16:46 |
| | | | Shaos wrote: Пока прикидываю неразогнанный двухсимовый вариант для 5 МГц: Как я понимаю за 4 такта процессора (и 8 тактов пиксельклока) нам надо успеть прочитать один раз из видеопамяти и один-два раза прочитать-записать данные по требованию процессора, ну и может один раз сделать CAS-before-RAS рефреш - так? Процессор всегда пишет-читает через такт после ALE. У нас может быть четыре состояния s0,s1,s2,s3, в первых трёх из которых по умолчанию будет читаться видеопамять и сохранять видеоданные в регистре, из которого в состоянии s3 видеоданные будут уходить в сдвиговый регистр и ALE может попасть на любое из этих состояний: ALE попало на s0 - значит общение процессора с памятью будет во время состояния s2 и мы точно знаем, что регистр с видеоданными уже будет записан в текущем такте (s0), значит следующий такт s1 можно посвятить рефрешу CAS-before-RAS, а на s3 снова может выпасть ALE. ALE попало на s1 - значит общение процессора с памятью будет во время состояния s3 и мы точно знаем, что регистр с видеоданными уже будет записан в текущем такте (s1), значит следующий такт s2 можно посвятить рефрешу CAS-before-RAS. ALE попало на s2 - значит общение процессора с памятью будет во время состояния s0, а в следующем состоянии s3 регистр с данными уже должен быть записан, значит в текущем такте (s2) пишем регистр с видеоданными и больше ничего не делаем (CAS-before-RAS не заказывается). ALE попало на s3 - значит общение процессора с памятью будет во время состояния s1 и следующий такт (s0) надо посвятить записи видеорегистра, значит CAS-before-RAS также не заказывается. P.S. RD и WR надо попросту укоротить, откусив их начала и оставив только кусок, попадающий на T3? | | | | |
Наверное надо на полтакта сдвинуть формирование RAS/CAS, причём удлиннив RAS и укоротив CAS:
P.S. Пока прикидки такие - имеем 2 обязательных CPLD чипа:
Orionix Chip1 - дешифратор адресов и почти все порты (см. VHDL код выше)
Orionix Chip2 - видеоконтроллер, перебирающий адреса видеопамяти (PAL и NTSC)
и 2 опциональных:
Orionix ChipX - гибкий доступ к видеопамяти с шагом в 256 байт вместо 16К (горизонтальный скролл)
Orionix ChipY - блиттер (пока в базовом варианте с копированием без прозрачности)
плюс некоторое небольшое количество мелкой логики (регистры, мультиплексоры и т.д.)
P.P.S. По идее можно шаг сдвига видеопамяти и в 1 байт сделать - в этом случае можно будет вертикальный скролл поддержать, правда с минимальной софтверной поддержкой (программно придётся стирать перехлестнувшиеся пикселы), но этоу же мелочи...
P.P.P.S. С другой стороны в качестве мультиплексоров можно тот же Xilinx заюзать - дешевле будет (один XC9572XL-10 стоит $2.26, один XC9536XL-10 стоит $1.18, а шесть 74LS153 - уже $4.50) - тогда обязательными будут 3 CPLD-чипа...
05 Dec 2013 21:48 |
не надо путать божий дар с яичницей
06 Dec 2013 02:03 |
Error404
i8080 в поделках времен 89-90г.г. это дань предельной бедности тогдашних сельских радиолюбителей. Тремя годами позже все Орионы уже шли с Z80 "искаропки" (Ташкентский Турбо, Альтаир, Орион-ПРО). Предлагаю пересчитать на форуме предельно бедных радиолюбителей, у которых нет Z80.
06 Dec 2013 08:08 |
А нонче всё идёт "искаробки" с интеловским многоядерным пентиум-совместимым процом
06 Dec 2013 08:22 |
Users browsing this forum: No registered users and 18 guests |
