Atom Feed | View unanswered posts | View active topics It is currently 22 May 2019 10:44
Reply to topic  [ 12 posts ]
XORLib - игровая либа для старой школы ;)
По итогам экспериментов с PIC32 решил вот начать писать опенсорцную игровую либу для PIC32 и DOS PC под лицензией MIT:
https://gitlab.com/shaos/xorlib
Wiki-документация (буду потихоньку заполнять):
https://gitlab.com/shaos/xorlib/wikis/home
Заголовочный файл со всеми константами и функциям:
XORLib - old school game library licensed under the MIT License
See for more info: http://www.xorlib.com
#ifndef _XORLIB_H_
#define _XORLIB_H_
#define XORLIB_VERSION 0x0002 /* v0.2 */
/* Available external macros:
   PIC32NTSC - for PIC32MX with 8 MHz crystal and NTSC timings (black and white modes)
   PIC32NTSCQ - for PIC32MX with 14.31818 MHz crystal (with possible color burst mode)
   PIC32PAL - for PIC32MX with 8 MHz crystal and PAL timings (black and white modes)
   PIC32VGA - experimental mode for PIC32MX connected to VGA monitor (future)
   DOS32 - for 32-bit DOS
   DOS16 - for 16-bit DOS
   TERM - emulation of some basic functions through terminal (ncurses)
   DECODEGIF - compiled with GIF decoder (xdec_gif.c)
   DECODEJPG - compiled with JPEG decoder (xdec_jpg.c)
/* NTSC compatible video modes - 320 bits per line */
#define XOMODE_320x200_MONO    0 /* Black and white 320x200 */
#define XOMODE_160x100_GRAY5   1 /* Pseudo mode on top of mode 0 with 5 shades of gray */
/* NTSC compatible video modes - 640 bits per line */
#define XOMODE_640x200_MONO    2 /* Black and white 640x200 */
#define XOMODE_213x200_GRAY4   3 /* Pseudo mode on top of mode 2 with 4 shades of gray */
#define XOMODE_160x200_COL15   4 /* Color burst mode over 640x200 with 15 unique colors (4 pallets) */
#define XOMODE_160x100_COL120  5 /* Pseudo mode on top of mode 4 with about 120 unique dithered colors */
/* NTSC compatible video modes with additional hardware - 640 bits per line */
#define XOMODE_320x200_COL4    6 /* CGA-like mode with configurable 4-color palette */
#define XOMODE_160x200_COL16   7 /* Color mode with standard 16-color palette */
/* NTSC compatible video modes with additional hardware - 1280 bits per line */
#define XOMODE_320x200_COL16   8 /* EGA-like mode with standard 16-color palette */
#define XOMODE_160x200_COL256  9 /* Predefined 256-color RGB-palette (including 64 shades of gray) */
/* NTSC compatible video modes with additional hardware - 2560 bits per line */
#define XOMODE_640x200_COL16  10 /* EGA-like mode with standard 16-color palette */
#define XOMODE_320x200_COL256 11 /* Predefined 256-color RGB-palette (including 64 shades of gray) */
/* VGA compatible video modes (just a placeholder for future) */
#define XOMODE_640x350_COL16  12 /* EGA-like mode with standard 16-color palette */
#define XOMODE_640x480_COL16  13 /* VGA-like mode with standard 16-color palette */
#define XOMODE_800x600_COL16  14 /* SVGA-like mode with standard 16-color palette */
#define XOMODE_ENHANCED_VGA   15 /* Placeholder for other VGA modes */
/* Standard colors (directly supported only in modes >=7 and simulated in mode 5) */
#define XOCOLOR_BLACK           0
#define XOCOLOR_BLUE            1
#define XOCOLOR_GREEN           2
#define XOCOLOR_CYAN            3
#define XOCOLOR_RED             4
#define XOCOLOR_MAGENTA         5
#define XOCOLOR_BROWN           6
#define XOCOLOR_WHITE           7
#define XOCOLOR_GRAY            8
#define XOCOLOR_BRIGHT_BLUE     9
#define XOCOLOR_BRIGHT_GREEN   10
#define XOCOLOR_BRIGHT_CYAN    11
#define XOCOLOR_BRIGHT_RED     12
#define XOCOLOR_BRIGHT_MAGENTA 13
#define XOCOLOR_BRIGHT_YELLOW  14
#define XOCOLOR_BRIGHT_WHITE   15
#define XOCOLOR_INVERT         -1
/* Configuration flags (bits 0..15 for supported graphics modes) */
#define XOCONFIG_BIGENDIAN 0x00010000 /* bit 16 */
#define XOCONFIG_32BITINT  0x00020000 /* bit 17 */
#define XOCONFIG_NTSCTV    0x00040000 /* bit 18 */
#define XOCONFIG_PALTV     0x00080000 /* bit 19 */
#define XOCONFIG_NETWORK   0x00100000 /* bit 20 */
#define XOCONFIG_KEYBOARD  0x00200000 /* bit 21 */
#define XOCONFIG_MOUSE     0x00400000 /* bit 22 */
#define XOCONFIG_SDCARD    0x00800000 /* bit 23 */
#define XOCONFIG_CDROM     0x01000000 /* bit 24 */
/* Control bits */
#define XOCONTROL_LEFT1  0x0001 /* bit 0 */
#define XOCONTROL_RIGHT1 0x0002 /* bit 1 */
#define XOCONTROL_UP1    0x0004 /* bit 2 */
#define XOCONTROL_DOWN1  0x0008 /* bit 3 */
#define XOCONTROL_LEFT2  0x0010 /* bit 4 */
#define XOCONTROL_RIGHT2 0x0020 /* bit 5 */
#define XOCONTROL_UP2    0x0040 /* bit 6 */
#define XOCONTROL_DOWN2  0x0080 /* bit 7 */
/* Some control aliases */
#define XOCONTROL_FIRE   XOCONTROL_LEFT2
#define XOCONTROL_X      XOCONTROL_UP2
#define XOCONTROL_Y      XOCONTROL_LEFT2
#define XOCONTROL_A      XOCONTROL_RIGHT2
#define XOCONTROL_B      XOCONTROL_DOWN2
#define XOCONTROL_UP     XOCONTROL_UP1
#define XOCONTROL_LEFT   XOCONTROL_LEFT1
#define XOCONTROL_RIGHT  XOCONTROL_RIGHT1
#define XOCONTROL_DOWN   XOCONTROL_DOWN1
/* Optional control bits */
#define XOCONTROL_LSHOULDER 0x0100 /* bit 8 */
#define XOCONTROL_RSHOULDER 0x0200 /* bit 9 */
#define XOCONTROL_KEYREADY  0x1000 /* bit 12 - keyboard buffer is not empty */
struct xoimage
 short width, height;     /* width and height of the image in pixels */
 unsigned char pitch;     /* pitch in bytes (to calculate vertical offset) */
 signed char bpp;         /* bits per pixel (negative for grayscale) */
 unsigned char *data;     /* pointer to the image data */
 unsigned char *mask;     /* optional pointer to the mask */
/* Some macros */
#define VIDEOSCREEN (struct xoimage*)0
#define TEXTNORMAL xotextattr(XOCOLOR_BRIGHT_WHITE,XOCOLOR_BLACK)
#define TEXTINVERT xotextattr(XOCOLOR_BLACK,XOCOLOR_BRIGHT_WHITE)
#ifdef __cplusplus
extern "C" {
#endif
/* System functions */
unsigned long xoconfig(void);                   /* return configuration bits (see above) */
unsigned long xocontrols(void);                 /* return state of controls (see above) */
unsigned long xoframes(void);                   /* return frames counter */
unsigned long xoseconds(void);                  /* return seconds counter */
int xocurline(void);                            /* return current line of the frame (0 is 1st line of the video) */
void xowaitretrace(void);                       /* wait for vertical retrace interval */
void xodelay(int ms);                           /* delay in milliseconds */
int xokeyboard(int *scancode);                  /* return ASCII code from keyboard */
int xomouse(int *px, int *py);                  /* return mouse state (bit 0 - left button, bit 1 - right button) */
/* Graphics functions */
int xoinit(short m);                                    /* set graphics mode -> 0 if failed */
int xopalette(short p);                                 /* set predefined palette (for color modes) -> 0 if invalid id */
int xomode(void);                                       /* get graphics mode -> -1 if not yet set */
int xowidth(void);                                      /* return width of the screen */
int xoheight(void);                                     /* return height of the screen */
int xocls(void);                                        /* clear the screen */
int xopixel(short x, short y, char c);                  /* draw a pixel (-1 means inversion) -> 0 if invalid args */
int xoget(short x, short y);                            /* get state of the pixel (actual value) -> -1 if not supported */
int xoline(short x1, short y1, short x2, short y2, char c); /* draw a line with a color (-1 means inversion) */
int xorect(short x, short y, short w, short h, char c); /* draw a rectangular with a color (-1 means inversion) */
int xobar(short x, short y, short w, short h, char c);  /* draw a solid rectangular with a color (-1 means inversion) */
int xocircle(short x, short y, short r, char c);        /* draw a circle with a color (-1 means inversion) */
int xoellipse(short x, short y, short rx, short ry, char c); /* draw an oval with a color (-1 means inversion) */
int xoarc(short x, short y, short rx, short ry, short a1, short a2, char c); /* draw an arc of oval (-1 means inversion) */
int xopie(short x, short y, short rx, short ry, short a1, short a2, char c); /* draw a solid piece of oval (-1 means inversion) */
int xofill(short x, short y, char c);                   /* fill a region with a color (inversion is not applicable) */
int xopoly(char c, short n, short *a);                  /* draw a polygon from array {x,y, x,y, etc. } */
int xotextattr(char i, char p);                         /* set text color attributes (ink, paper) */
int xochar(unsigned char x, unsigned char y, char c);   /* print character using text location */
int xostring(unsigned char x, unsigned char y, char* s);/* print string using text location */
int xoprintf(char* s, ...);                             /* print string to current position with a possible scroll */
int xouserchar(char c, unsigned char* p);               /* add user character with code 0...31 using 8 bytes -> 0 if error */
int xotextwidth(void);                                  /* return text screen width */
int xotextheight(void);                                 /* return text screen height */
int xogray5(int i);                                     /* 5 shades of gray function (0,1,2,3,4) returns ASCII code */
int xoswitchscreens(void);                              /* switch primary and secondary screens (in case of double buffering) */
int xouseprimary(void);                                 /* use primary screen (default) */
int xousesecondary(void);                               /* use secondary screen (in case of double buffering) */
unsigned char* xodirectline(short y);                   /* return pointer to video line for direct access */
unsigned char* xoprevline(unsigned char *p);            /* return pointer to the previous video line for direct access */
unsigned char* xonextline(unsigned char *p);            /* return pointer to the next video line for direct access */
int xocopy(struct xoimage* d, struct xoimage* s);       /* copy one image into another with mask if presented */
int xorcopy(struct xoimage* d, struct xoimage* s);      /* copy one image into another with xor -> 0 if not supported */
int xopcopy(struct xoimage* d, struct xoimage* s, short x, short y, short w, short h); /* partial copy without mask */
int xopcopyk(struct xoimage* d, struct xoimage* s, short x, short y, short w, short h, char c); /* partial copy with a key color */
int xocopytxt(struct xoimage* d, const char* s, short x, short y); /* render text to image coordinates x,y */
int xocopyxbm(struct xoimage* d, const unsigned char* s, short w, short h);  /* copy image from XBM */
int xocopyeta(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from ETA frame */
int xocopymyg(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from MYG frame */
int xocopygif(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from GIF frame (if GIF decoder is enabled) */
int xocopyjpg(struct xoimage* d, const unsigned char* s); /* copy image from JPEG (if JPEG decoder is enabled) */
#ifdef __cplusplus
#endif
#endif
04 Apr 2015 20:46
Для декодера JPEG подтянул "публикдомайную" целочисленную либу picojpeg:
https://code.google.com/p/picojpeg/
а для декода GIF-ов (в том числе анимированных) - либу libnsgif, которая распостраняется под лиценизей MIT:
http://www.netsurf-browser.org/projects/libnsgif/
04 Apr 2015 20:54
Научил libnsgif декодить GIF не только в 32-битные пикселы, но и в 8-битные, 4-битные, 2-битные и 1-битные ;)
Пока правда ограничение есть - по ширине картинка должна умещаться в 32-битных целых числах, т.е.
- при декоде в 8-битный буфер, ширина оригинальной картинки должна быть кратна 4 пикселам;
- при декоде в 4-битный буфер, ширина оригинальной картинки должна быть кратна 8 пикселам;
- при декоде в 2-битный буфер, ширина оригинальной картинки должна быть кратна 16 пикселам;
- при декоде в 1-битный буфер, ширина оригинальной картинки должна быть кратна 32 пикселам.
Возможно позже уберу это ограничение...
P.S. Также в первом посте топика поправил описание графических режимов в соответствии с последними результатами экспериментов
06 Apr 2015 16:43
Благодаря блогу опасных прототипов попал на 3 первых места в поисковиках по запросу "xorlib" ;)
P.S. nedopc.org чегой-то плохо стал индексироваться поисковиками...
13 Apr 2015 08:55
Сегодня в список функций запланированных к реализации добавилось копирование из MYG-формата (MYG = MY Graphics):
int xocopymyg(struct xoimage* d, unsigned char* s, int f); /* copy image from MYG frame */
Этот формат представления 16-цветных и 256-цветных картинок я придумал на 5 курсе универа в 1995 году, когда делал всякие практические лабы по хаосу и фракталам на 386DX компах - формат использовал RLE и сжимал лучше PCX, а на некоторых картинках даже лучше GIF, плюс давал возможность делать анимацию (надо чтоли на ютюб выложить эти лабы - было прикольно для того времени)...
P.S. Выложил видео программки тех времён (май 1995) с хаотично сгенерённой луной :dj:
https://youtu.be/1-XwFXB843A
14 Apr 2015 21:58
Начал потихоньку городить XORLib wiki:
github.com/shaos/xorlib/wiki
P.S. Туда сейчас перекидывает xorlib.com
16 Apr 2015 19:45
Версия v0.2 теперь работает и на PC с CGA, правда с 32-битным процом ;)
P.S. Вот батник для сборки XORLib-приложений для PC с помощью OpenWatcom-1.9:
SET WATCOM=C:\SYSTEM\WATCOM19
SET INCLUDE=%WATCOM%\H
SET WATBIN=%WATCOM%\BINW
SET PATH=%WATBIN%;%PATH%
%WATBIN%\wpp386 /onatx /oh /oi+ /ei /3 /fp3 /dDOS32 %1.c xorlib.c nedofont.c
%WATBIN%\wlink system pmodew option stack=64k file %1,xorlib,nedofont name %1
24 Apr 2015 20:21
А не портировать ли мне XORLib ещё и вот сюда?
https://www.pjrc.com/store/teensy31.html
Тут тоже 256К флеша, 64К озу и куча ио...
16 May 2015 19:59
Т.е. если я правильно понял, то 256 цветов уже можно? :)
Да такая библиотечка нужна везде, портируй! :rotate:
26 Jun 2015 05:13
только в версии для PC можно - на PIC32 пока нельзя...
26 Jun 2015 15:38
Попробую найти в продаже PIC32, и попробую накатать смещения палитры.
28 Jun 2015 09:04
Приближающуюся Луну отсюда задействовал в своей "супердеме", перекодировав в новый формат v57 :)
https://youtu.be/xI5DuTKPWsA?t=4m (линк сразу перематывает к нужному месту)
19 Nov 2016 20:26
