eudoxie
Joined: 17 Sep 2012 13:36 Posts: 277 Location: 81.170.128.52
I'm all done with the source package now.
I've uploaded the manual here --> http://tunguska.sourceforge.net/The_Fine_Manual.pdf
I've also uploaded the source package here for now (I'll upload it to sourceforge when the windows package is ready for release) --> http://nedopc.org/ternary/tunguska/tunguska-0.5.tar.bz2
18 Nov 2008 10:20 |
Joined: 08 Jan 2003 23:22 Posts: 22591 Location: Silicon Valley
Wow, you use GPL v3 now?...
Your COPYING says version 3
But version of GPL for CYGWIN is 2 ONLY!
And we can't mix GPL v2 and GPL v3 in one package...
See http://nedopc.org/ternary/tunguska/tunguska-0_5-win.zip (2.7Mb)
I added my stuff to separate folder and COPYING.txt is GPLv2
Also check correctness of README.txt
18 Nov 2008 17:38 |
eudoxie
The license of Tunguska is strictly speaking "GPL2 or later", so you can distribute it with a GPL2 or GPL3 license.
3CC accidentally used a GPL3 only copyright notice, but I've changed that to 2 or later in the CVS now (and will do the same to the package).
As for the package, the README.txt looks good, but I think it would make sense to rename "ram" to "ram_asm"
19 Nov 2008 11:05 |
But not with CYGWIN stuff - it requires GPL v2 around If you put COPYING that says GPLv3 then we can take it and mix with CYGWIN because of it's GPLv2, so COPYING in sources must be GPLv2 rigth?
OK, I made this change: http://nedopc.org/ternary/tunguska/tunguska-0_5-win.zip (2.7Mb)
P.S. I again have problems with mouse in pong. Could you please check this build on your available Windows?
19 Nov 2008 17:55 |
eudoxie
I don't have access to a windows box right now, so I'll try it tomorrow when I do.
20 Nov 2008 15:29 |
eudoxie
I can't get the mouse to work in Pong in the windows port either, though it works in the brownian motion demo for the assembly image. The mouse works in pong in Linux when I checked last night.
But there is another problem, cpp tries to run "cc1.exe", which isn't present, so building the 3cc image fails. I think it could perhaps be a better idea to make MinGW a requirement for the windows port, instead of shipping the specific parts of GCC.
21 Nov 2008 07:23 |
Yes, you're right - I never tried run it on other machine before...
So now I'm trying to write "quick and dirty" mini cpp that will be enough to process your 3CC files in this release...
P.S. I think the best solution will be to add limited preprocessor functionality directly to your 3CC application
21 Nov 2008 19:49 |
OK, it's ready: http://nedopc.org/ternary/tunguska/tunguska-0_5-win.zip (2.0Mb)
No more cpp.exe! My minicpp is very simple program - 236 lines of program itself and 762 lines of my old (back to 1996) string/text library - all is kind of public domain. One thing that I did in your sources, I removed TEST(TEST) macro definition from MAIN.C, because I do not have time to support macros with arguments
P.S. Result is identical to standard cpp (in case of current 3CC source code). Enjoy
21 Nov 2008 22:40 |
eudoxie
Great! Unless you have any last minute changes, I think it's ready for release.
23 Nov 2008 10:55 |
No changes - it's ready
25 Nov 2008 15:53 |
eudoxie
Ok, good. I'll probably release it on SF tonight then.
28 Nov 2008 07:39 |
eudoxie
... and now it's released
28 Nov 2008 17:34 |
Great! What about news? It still says "0.0.3"...
29 Nov 2008 17:54 |
eudoxie
Hmm, I think I'll fix that tomorrow. Freshmeat.net isn't updated either, so it's no hurry.
29 Nov 2008 19:47 |
eudoxie
Freshmeat is still not updated. I think my update request was lost somewhere in transit. I've resubmitted.
I've been thinking about what stuff to work on for the next version of tunguska. So far, I've come up with the following things:
* UI changes (probably a move to GTK, possibly also OpenGL)
* New character table (the current one is so limited it's painful and I really like the one Shaos designed)
02 Dec 2008 10:23 |
