Atom Feed | View unanswered posts | View active topics It is currently 27 Apr 2024 00:32
Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
Троичный конвертер онлайн
Online
Конвертер между четырмя системами счисления на джаве:
<applet code=TriCon width=640 height=160>
</applet>
 TriCon.java
// TriCon.java - Alexander Shabarshin  08-Feb-2006
// See http://ternary.info
import java.applet.*;
import java.awt.*;
public class TriCon extends Applet
 TextField text2;
 TextField text3;
 TextField text10;
 TextField text16;
 int number;
 public void init()
  setLayout(new GridLayout(4,2));
  add(new Label("Ternary (N,O,P):"));
  text3 = new TextField(24);
  add(text3);
  add(new Label("Decimal (0-9):"));
  text10 = new TextField(16);
  add(text10);
  add(new Label("Hexadecimal (0-9,A-F):"));
  text16 = new TextField(8);
  add(text16);
  add(new Label("Binary (0,1):"));
  text2 = new TextField(32);
  add(text2);
 public boolean action(Event event, Object object)
  if(text2.equals((TextField)event.target))
    number = Integer.parseInt(text2.getText(),2);
    text3.setText(toTernary(number));
    text10.setText(Integer.toString(number));
    text16.setText(Integer.toHexString(number).toUpperCase());
  if(text3.equals((TextField)event.target))
    number = fromTernary(text3.getText());
    text2.setText(Integer.toBinaryString(number));
  if(text10.equals((TextField)event.target))
    number = Integer.parseInt(text10.getText(),10);
  if(text16.equals((TextField)event.target))
    number = Integer.parseInt(text16.getText(),16);
  return true;
 public static String toTernary(int num)
    int n,m,k;
    String s = null;
    k = 387420489;
    for(int i=0;i<=18;i++)
      n = num/k;
      num -= n*k;
      m = k/2;
      if(num>+m){n++;num-=k;}
      if(num<-m){n--;num+=k;}
      if(n!=0 && s==null) s="";
      if(n==-1) s+="N";
      if(n==0 && s!=null) s+="O";
      if(n==1) s+="P";
      k /= 3;
    return s;
 public static int fromTernary(String s)
    int n = 0;
    int k = 1;
    for(int i=s.length()-1;i>=0;i--)
      char c = s.charAt(i);
      if(c!='N'&&c!='O'&&c!='P') return 0;
      if(c=='N') n-=k;
      if(c=='P') n+=k;
      k *= 3;
    return n;
08 Feb 2006 22:04
Online
Адрес апплета на ternary.info:
http://ternary.info/ternary/java.php?applet=2
P.S. Репа с этими и другими исходниками:
https://gitlab.com/ternary/ternary/-/tree/master/obsolete
Результат запуска без браузера: appletviewer TriCon.html
08 Feb 2006 22:08
Хорошая штука!!! Я и сам хотел себе написать - а тут вдруг и есть!!!
Только вот куда нажимать, чтобы вычислять начала? :o
Вводил в разные поля... и Enter нажимал, и мышю - тыкал...
Не вычисляет - нифига... Мож сломалось че? :-?
Странно... а на http://ternary.info/ternary/java.php?applet=2
по Enter работает... :roll:
22 Sep 2012 16:59
Online
Дык просто вводишь в нужное поле и жмёшь Enter - оно выводится в разных форматах в другие поля...
22 Sep 2012 17:02
Для полного кайфа нехватает девятиричной :)
23 Sep 2012 03:14
Online
Ну тогда уж и восьмиричную надо добавить ;)
23 Sep 2012 08:35
Блин... а она была популярна в старых отечественных машинах!...
У меня есть старая документация - там всё пестрит этими 65123о...
Очень тяжело читать с непривычки... :-?
PS. Хмм... "Троичный конвертер на Java"... Ну что бы мы делали
без этой дохлятины Джаббы...
:( (лопата)
23 Sep 2012 09:27
Надо же! Вроде пошутили... а восьмиричную - надо добавить! :o
Этот оригинальный EDUC-8 весь усыпан октальной системой... :(
Я сначала не мог понять - чего этого JAMIESON-а ROWE распёрло на октальную... :-?
Наконец понял - дислей он сподобился сделать октальный! (а точнее - десятичный)
вот у него и hex-числа на дисплей не лезут... :(
Shaos, а нельзя заодно добавить и кнопочку "Вычислить" ?
А то "Enter" в поле ввода не всегда уверенно срабатывает... :-?
08 Oct 2012 20:58
Online
Всё можно. Только я это уже не на джаве писать буду, а на JS...
08 Oct 2012 21:41
Shaos, я тут в целях совместить полезное с приятным решил добавить
твоему калькулятору GUI и всякие кнопочки, которые мне бы хотелось.
И всё получилось довольно неплохо:
И даже случился такой бонус, что Java сама приделывает к GUI-окну Status Bar
и пишет в нём по старту: Java Applet Window
Вот только я нигде не нашел, как мне самому что-то вывести полезное в этот Status Bar,
раз уж он есть...
Ты не знаешь, как это делают?
01 Dec 2017 17:21
Online
Метод showStatus("...") вроде как есть у апплета
01 Dec 2017 17:25
Есть такой метод, это находится быстро... но выводит он в строку статуса броузера.
Я уже попробовал.
А это Status Bar GUI-окна.
P.S. Наверное, в этот Status Bar GUI-окна класса Frame ничего не выводят никак.
Не нашел я таких методов... :-?
Если скомпилировать в автономное GUI-приожение, то, видимо, этого Status Bar
просто не будет.
01 Dec 2017 17:37
Online
да - для окна незнаю как
не нравились мне джавовские окна никогда...
01 Dec 2017 18:41
А я ещё когда писал «Специалист» на Java, хотел открывать его, как GUI-окно.
Но что-то в тот раз не случилось... А тут решил это попробовать! :wink:
Кстати, если юзать JFrame из JFC/Swing, то окна и вовсе приятные,
причем выглядят своеобразно:
Но чего это я раскудахтался? :lol: Джаба скоро помрёт! Всем повторять: помрёт Джабба! :mrgreen:
01 Dec 2017 18:48
Если скомпилировать в автономное GUI-приожение, то, видимо, этого Status Bar просто не будет.
Да, так и вышло:
Видимо, этот Status Bar с надписью Java Applet Window Джаба приделывает
своему GUI-окну, если оно развертывается из страницы браузера.
Наверное, чтобы юзер не пугался - откуда это окно такое всплыло... :wink:
02 Dec 2017 04:04
Users browsing this forum: No registered users and 44 guests
