Atom Feed | View unanswered posts | View active topics It is currently 28 Apr 2024 05:32
Reply to topic  [ 11 posts ]
Algorithm for division by 2
I don't know if similar algorithms have been published before, but I've developed a linear time complexity division-by-two algorithm for balanced ternary numbers.
It's based on the recursive relation that
1/2 = 1/3 + (1/3)*(1/2)
(and division by 3 is achievable by shifting)
So, to divide some number ABCD, you do the following
A B C D / 2
  A B C . D
    A B . C D
 +    A . B C D
[0, A, A+B, A+B+C].[B + C + D, C+D, D]
Where the right half is the residual (add the carry of that to the result to fix rounding errors)
void bw_bisect(word target) {
   register int i;
   register int tmp = 0, sum = 0;
   register int residual = 0;
   register int power = 1;
   for(i = 0; i < WORD_DIGITS-1; i++, power*=3) {
      tmp += target[i];
      residual += power * tmp;
   for(i = WORD_DIGITS-1; i >= 0; i--) {
      tmp = target[i];
      target[i] = sum;
      sum += tmp;
   if(residual > 0) {
      target[0] += (residual + (NBWORD_MAX/3)/2) / (NBWORD_MAX/3);
   } else {
      target[0] += (residual - (NBWORD_MAX/3)/2) / (NBWORD_MAX/3);
   bw_ripple(target);
/* Helper function. "smears" out a number so that
 * individual digits hold numbers that are in the
 * range -1,...,1 */
int bw_ripple(word target) {
   register int i;
   register int carry = 0;
   for(i = 0; i < WORD_DIGITS; i++) {
      target[i] += carry;
      if(target[i] > 0)
         carry = (target[i] + 1) / 3;
      else
         carry = (target[i] - 1) / 3;
      target[i] -= 3 * carry;
   return carry;
11 Jun 2009 12:49
Great! In one Russian topic here we discussed ternary algorithms of multiplication and division by 10. See automatic translation of that topic:
http://translate.google.com/translate?j ... ry_state0=
13 Jun 2009 12:04
Interesting...
I think it is probably possible to re-write my algorithm in a more efficient form. Looking over my code, it feels a bit awkward.
13 Jun 2009 15:34
Incredible! It is very interesting thing indeed :)
14 Jun 2009 15:16
It seems possible to express any integer division as repeated shifting, addition and multiplication.
The method for finding how to do it is taking
1/n = 1/3 + (3 - n)/3 * (1/n)
So, you get
1/2 = 1/3 + 1/9 + 1/27 + 1/81 ...
1/4 = 1/3 - 1/9 + 1/27 - 1/81 ...
1/5 = 2/3 - 2/9 + 2/27 - 2/81 ...
1/7 = 4/3 - 4/9 + 4/27 - 4/81 ...
etc.
14 Jun 2009 15:39
What about x/10?
15 Jun 2009 20:38
1/10 = 7/3 - 7/9 + 7/27 - 7/81 ...
You could express multiplication by 7 as multiplication by 9 and subtracting twice I guess.
But I think it's smarter to express division by 10 as repeated division by 9:
1/10 = 1/9 - 1/9 * 1/10 =>
1/10 = 1/9 - 1/81 + 1/729 - 1/6561 ...
You get much fewer terms, and don't need to worry about multiplication by 7.
If consideration is taken to the carry of the sum of the decimal part, this will produce exact results.
In it's most general form, division by some number n in terms of division by some other number b can be expressed like this:
The relationship is derived by evaluating 1/n - 1/b and finding that
1/n - 1/b = (b-n)/nb = (b-n)(1/b)(1/n)
Then shifting over 1/b to the right side
1/n = 1/b + (b-n)(1/b)(1/n)
Then you simply replace the (1/n) in the right hand part of the equation with the right hand equation (over and over again)
1/n = 1/b + (b-n)(1/b)(1/b + (b-n)(1/b)(1/b + (b-n)(1/b)(1/b + (b-n)(1/b)([...]))))
If you clean that mess up, you get the pretty relationship above.
16 Jun 2009 06:55
Finally I got first part. Because of
Image where |q|<1
and if we have q=1/3 then 1/(1-q)=1/(1-1/3)=1/(2/3)=3/2
It means we should dived by 3 both sides or
1/3*sum(1/3^n)=1/2 (sum from n=0)
or
sum(1/3^n)=1/2 (sum from n=1)
#!/usr/local/bin/hopeless -f
dec round : num -> num;
--- round(x) <= if x-f < 0.5 then f
                else f+1 where f==floor(x);
dec tri10b : num -> num;
--- tri10b(x) <= round((x-round((x-round(x/9))/9))/9);
dec tri2b : num -> num;
--- tri2b(xx) <= let x==xx+1 in round((x+round((x+round((x+round((x+round((x+round(x/3))/3))/3))/3))/3))/3);
dec try : num # list(num # num) -> list(num # num);
--- try(x,l) <= let fx==tri10b(x) in
                if round(x/10) = fx then try(x+1,ll)
                else ll where ll==(x,fx)::l;
dec try2 : num # list(num # num) -> list(num # num);
--- try2(x,l) <= let fx==tri2b(x) in
                if round(x/2) = fx then try2(x+1,ll)
try2(0,nil);
algorithm tri2b is correct for values up to 729 (tri10b - up to 734)
P.S. correction +1 for argument x required in tri2b for "round-like" results (1/2=1, 3/2=2 etc), without it result will be "floor-like" (1/2=0, 3/2=1 etc)
16 Jun 2009 18:25
That's pretty neat :-)
I've cleaned up the derivation of a more general case, I hope it's easier to follow.
17 Jun 2009 13:45
It's brilliant
Thanks!
17 Jun 2009 17:50
again, no images :(
P.S. fixed :)
10 Nov 2012 08:58
Users browsing this forum: No registered users and 24 guests
