Atom Feed | View unanswered posts | View active topics It is currently 28 Mar 2024 04:16
Reply to topic  [ 5 posts ]
[Soft] Beta testing Fuse 1.1.0 beta 2
I hope Fred won't mind me reposting this here:
Hello everyone,
We are still preparing Fuse for a new release soon and would appreciate
help in testing that all the new features and all the old features are
working properly.
The key new features are:
* Spectranet emulation
* SpecDrum emulation
* Disciple emulation
* Movie recording to FMF files
* SpeccyBoot emulation
* GTK+ 3 Support
* Many Win32 enhancements
* POK file support
* PZX file read support
* Plus lots of bug fixes
The fixes since the last release are:
Fuse:
* Split SNET block into SNET, SNEF and SNER so that flash could
theoretically be saved separately - Spectranet SZX files from the
previous beta are now invalid
* Correct video timing for +2A/+3 etc machines
* Implement Spectranet's "suppress NMI" flipflop
* Fix inverted DISCiPLE printer busy logic
* Empty sound buffer when emulation is paused using a shortcut key on
Win32 UI (thanks, Lee Tonks)
* Add DISCiPLE ROM with EPSON printer support
* Correct restore of pentagon 1024 memory ports from snapshots
* Spectranet emulation bugfixes
* Make sure that SE RAM variables are initialised before they are
referenced
* Add separate switch to enable ZX Printer emulation
* Fix SE writing dock and exrom pages to snapshots
* Update SE ROMs to v4.04
* Reset machine when significant interfaces are connected/disconnected
* Fix in-memory disk image becoming corrupted after saving the disk file
* Update to v1.38 of the +3e ROMs (thanks, Guesser)
* Fix loading of EDSK files with redundant sector images
* Many manual updates
* Add support for storing ZX Printer state in SZX files
* Allow up to 15 joystick buttons to be defined to accommodate e.g.
XBox 360 ABXY button use
* Support setting late timings from SZX snapshots
* Support the binutils gold linker.
* Minor bugfixes
fuse-utils:
audio2tape:
* Print flag byte (thanks, Ivan Shmakov).
* Include read and computed checksum (thanks, Ivan Shmakov).
* Fix incomplete byte warning (thanks, Ivan Shmakov).
fmfconv:
* Force mpeg4 video encoder for youtube profile and don't force AAC
audio encoder for ipod profile.
* Fix a crash when converting PCM stereo samples to mono.
* Fix the build on Debian stable and fix a crash when encoding H.264
* Fix a crash when input file does not exist
* Support ffmpeg 1.0.1 API
* Improve addition of annotation field to au format files
If you'd like to help you can find the second beta binaries for various
systems at:
Debian (and hopefully Ubuntu):
http://people.igalia.com/berto/files/debian/fuse-beta/
There's packages for Debian 6 ("squeeze") and 7 ("wheezy"). Wheezy
packages use GTK+ 3, Squeeze uses GTK+ 2.
You need to install libspectrum8, fuse-emulator-common and either
fuse-emulator-gtk or fuse-emulator-sdl.
Windows:
Fuse (zipped)
http://www.mediafire.com/?8x30c5p9b7m4b2p
sha1sum: b2b30ac3e81740969e044361611f1c99ac1cdc28
Fuse (setup)
http://www.mediafire.com/?udy808t5978yeb7
sha1sum: 6f025b6d73490bd16c222930c89d99d77e84f13e
Fuse-utils (zipped)
http://www.mediafire.com/?xm8108b3536mvhc
sha1sum: 27b778b19e4292cea13c701d1801373390ad5a82
Mac OS X:
http://sourceforge.net/projects/fuse-fo ... p/download
Mac specific changes are:
* Support OS X 10.7
* Movie recording file selection should be for writing rather than
reading (thanks, deKay)
* Fix fullscreen modes (thanks, Adam Meath)
* Don't poll for joystick axes that do not exist to avoid going into a
loop when exiting the pref pane with non-existent joystick axes
selected
* Add documentation of External sound interfaces, add more hyperlinks
(thanks, Paul van der Laan).
Source code to build for other platforms:
https://fuse-emulator.svn.sourceforge.n ... ator/trunk
28 Apr 2013 07:31
Great news! :)
28 Apr 2013 10:13
I downloaded official sources for 1.1.0 from SF:
http://sourceforge.net/projects/fuse-em ... rce=navbar
It's compiled successfully in my Slackware 13
23 May 2013 16:55
Hello everyone,
working properly.
* GTK+ 3 Support
* POK file support
Fuse:
referenced
* Minor bugfixes
fuse-utils:
audio2tape:
fmfconv:
systems at:
Windows:
Fuse (zipped)
Fuse (setup)
Fuse-utils (zipped)
Mac OS X:
* Support OS X 10.7
selected
Amazing!!! i will try too...
epson printer error code 0x97 :rotate:
17 Oct 2018 02:58
Is this a new kind of spam?...
20 Oct 2018 16:18
