Joined: 29 Jan 2013 13:43 Posts: 52 Location: 86.182.165.70
But what is "Var" thing anyway?...
Sorry for the late reply. It's just a copy of whatever is in the variables area after the program. I'm making good progress on SE Basic 4.1 now and have added the TRACE, SCROLL, and SPEED commands. The latter replaces two commands (FAST and SLOW).
03 Oct 2013 02:18
cheveron
Small update to version 4.0. I've backported the new keyboard mode from 4.1 and juggled a few characters around to support the Chloe 280SE's keyboard.
Somehow missed this topic, found it only today. Despite already knowing about OpenSE Basic, didn't know about this fork. Seems to be a great project. And it supports 8-bit encoding, just like OpenSE Basic does. Good luck in continuing developing it.
14 Nov 2015 12:29
Joined: 08 Jan 2003 23:22 Posts: 22681 Location: Silicon Valley
If you want a high degree of Spectrum compatibility, plus an 80 column mode, use SE Basic 4.0 (link above).
Version 4.1 was a failed attempt to refactor the code base that introduced a number of bugs. It's really best to avoid it.
If you think you might be interested in developing for the Chloe 280SE microcomputer, use SE Basic 4.2. It has no Spectrum compatibility. It also requires an esxDOS compatible OS kernel (https://zx.itch.io/sebasic4)
23 Jul 2019 05:54
You're welcome. It's also probably worth noting that SE Basic 4.2 is entirely disk based and it *might* be possible to get it to use TR-DOS instead of esxDOS. It avoids all the TR-DOS address traps (because the divMMC emulates TR-DOS). It depends on if TR-DOS will work with the SE Basic 4.2 ROM, which is radically different from the Spectrum ROM.
