Atom Feed | View unanswered posts | View active topics It is currently 28 Apr 2024 13:26
Reply to topic  [ 273 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19  Next
Tunguska the ternary emulator
Everything but gtkui should build properly. You could either install gtksourceview, or change
all: tunguska tg_assembler tunguska-gtk
to
in the tunguska_sources Makefile.
I haven't really worked on the GTK UI since last winter, though, and it's not really a lot to see. And between Tunguska II and various other stuff I'm working on, the GTK avenue is pretty much on ice at the moment.
Heh, that server is less than a kilometer from where I live...
08 Aug 2009 17:24
First fix for tunguska_3cc:
diff -r1.7 Makefile
13a14,15
> lex.yy.o: dosp
>    $(CXX) $(CXXFLAGS)   -c -o $@ lex.yy.cc
08 Aug 2009 17:32
Looks fine.
I really don't have the time to maintain the main Tunguska branch at the moment, so if you want to upload smaller patches to the CVS, you can do so without asking.
08 Aug 2009 17:36
eudoxie wrote:
Looks fine.
OK, thanks again!
08 Aug 2009 20:07
That's funny :)
I got there from http://gtksourceview.sourceforge.net/downloads.html where it's named "GNOME FTP server" :)
P.S. This is my "black little-endian/big-endian combine" where PC (Intel Core 2 Duo 2.6 GHz with Slackware-12.2) and Mac (PowerPC G4 450 MHz with Debian 5.0) are connected to one monitor and one keyboard/mouse (through KVM) to make porting process easier:
08 Aug 2009 20:13
eudoxie wrote:
Looks fine.
I did a few small changes to unify working with Tunguska apps (common share_dir.h for tunguska and tunguska_gtk, some appnames changed in Makefiles as tunguska_3cc instead of 3cc and path to apps)
P.S. Also I may suggest to add file version.h with version number of Tunguska to share it between applications to display.
P.P.S. I don't like hardcoded paths to asm like "../../tunguska_image_memory_sources" in tunguska_gtk, but I don't know better solution yet...
08 Aug 2009 21:20
Last change (Added event based peripheral updating as opposed to checking if memory registers have changed after every single instruction) was done after releasing version 0.5. Do you plan to release version 0.6?
09 Aug 2009 07:45
I wanted to wait for more changes until release, since there really isn't a terribly big difference between current CVS and 0.5. The main benefit from event driven peripherals is to makes programming easier. The end user won't benefit from it a whole lot.
I suppose we could push these new additions as 0.5.1 or something.
What I've been meaning to do is merge the new Tunguska II algorithms back into the Tunguska I implementation, to clean that up a bit (it's full of premature optimizations and ugliness at the moment). But that's quite a lot of work, and would most likely entail an overhaul of the entire tryte and trit classes.
--edit--
Another outstanding issue is the inconsistent speed at which Tunguska runs. There should be a delay somewhere that makes it pause for some time every 1,000 or 10,000 or so instructions so that on average, it runs at a consistent speed.
09 Aug 2009 09:50
For now I plan to clean compilation warnings and to try make it working on big-endian systems...
09 Aug 2009 12:29
Don't you think GTK debugger is a BIG change? ;)
09 Aug 2009 14:34
Sure it's big, but it isn't any where near ready. Large chunks of the functionality are still missing, and it's broken outside of Slackware.
09 Aug 2009 14:53
Really? Do you have some kind of TODO/BUGS list to look at?
09 Aug 2009 15:17
I managed to fix gtkui to build properly on my system. It turned out it was my system that wasn't configured properly
No formal TODO/BUGS list, but I guess it would be a good idea to start one now that I'm not working alone.
Of the top of my head, the outstanding issues to deal with are the following:
* Complete GTK+ UI:
  o A build system is partially implemented and necessary.
    The partial implementation is insecure as well. Since
    there is no configuration utility, it needs to launch
    the assembler/compiler using $PATH, which clearly is
    a terrible security practice.
  o File management (is the user editing an assembly file,
    a 3cc file; what syntax highlighting to use?) is
     missing.
  o Create syntax files for the gtksourceview.
  o [d]The memory inspector doesn't always use fixed width fonts.[/d]
  o More?
* Tunguska:
  o The uneven run-speed need to be fixed with scheduled delays.
  o The tryte and trit classes needs an overhaul. The design is appalling.
  o [d]symbols.bmp has an error in it, so "Z" is backwards.[/d] It hasn't been fixed because:
  o the whole text system is in need of an overhaul.
    A better character map is necessary than the current
    one. Should probably move to use SDL_gfx and it's built
    in bitmap fonts instead (that way I don't have to
    painstakingly hand-draw any more symbols).
  o Portability issues.
  o There's always bit rot where newer versions of gcc/glib/whatever doesn't compile properly.
* 3cc:
  o If the character map in tunguska is updated, this need to be changed too.
* Aassembler:
I [d]striked[/d] some stuff. I know what the problem is, and I'll fix them as soon as I have access to a computer I trust.
I think this can roughly be thought of a roadmap to Tunguska 1.0.
09 Aug 2009 16:00
Final location:
20 Aug 2009 22:13
Nice :-)
21 Aug 2009 01:55
Users browsing this forum: No registered users and 33 guests
