Hello Sprinter friends,
I still have problems with the CMOS RAM DS12887. Every now and then the CMOS RAM loses the BIOS settings. I tested different types. DS 12887, DS 12887A, DS 12887+, DS 12C887. I built another Sprinter. Again, the same phenomenon?
Anyone have a tip?
Regards
Sprinter Version 2016s, Replica
mwlay
- Writer
Re: Sprinter Version 2016s, Replica
Yes, sometimes it's reset itself on my Sp2000 - not know why yet
Good thing time is staying
But shift coordinates of the screen are needed to be setup again from time to time
mwlay
- Writer
Shaos, thanks for replay.
I tested a Bechmarq bq32887 CMOS. This one has never forgotten its contents!
I got the DS12887+ new from CN. With 3 pieces the battery was already empty. So here too conversion to external battery.
mwlay
- Writer
I have a hint about the problem of data loss in CMOS RAM. Data loss does not occur if Fex Navigator (FN) is exited before power off.
The FN constantly accesses the CMOS (signal play on AS, DS, R/W).
When the FN is terminated, no access to the CMOS can be seen.
The signal play in connection with switching off must probably trigger an erasure process in the RAM.
The problem can also be aggravated by the chip select being permanently on GND.
Does it make sense to change the circuit diagram here?
mwlay
- Writer
Hello Sprinter Fans,
who can help me. I'm looking for the circuit diagram and the PCB assembly for the Sprinter 2022s.
Regards
Regards
mwlay
- Writer
Here is a picture of my Sprinter 2022s.
Who has a circuit diagram and an assembly plan for this PCB?
Many thanks to all Sprinter fans.
regards
Matthias
regards
Matthias
It looks like update of Sp2021sp board (with 3 ISA slots) - not sure what was added in Sp2022s, but I think it should be minor changes
mwlay
- Writer
Hello Sprinter - Fan's,
the Sprinterversion 2022s works fine.
The RomanRom2 documentation was helpful.
Thanks to you.
Thanks to you.
Porcupint
- Junior
Thanks for clarifying the partition/formatting tools earlier. The external FORMAT.EXE tip is very useful for anyone new setting up CF cards.https://rabbitroad-casino.org https://berjeuxlan.org https://casp-acsp.org
