FizikS
Joined: 11 Oct 2018 00:52 Posts: 200 Location: г. Клинцы, Брянская обл.
Очередное обновление программы SimulIDE 1.0.0 Tester builds доступно на официальном сайте программы: https://simulide.forumotion.com/t390-si ... ter-builds Список изменений
06 Mar 2023 11:43 |
Joined: 08 Jan 2003 23:22 Posts: 22599 Location: Silicon Valley
А вот trunk у меня не собирается | | | | Code: ... g++ -c -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DREVNO=\"1590\" -DMAINMODULE_EXPORT= -DAPP_VERSION=\"\" -DBUILDDATE=\""07-03-23"\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CONCURRENT_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I. -I../src -I../src/gui -I../src/gui/circuitwidget -I../src/gui/circuitwidget/components -I../src/gui/circuitwidget/components/active -I../src/gui/circuitwidget/components/logic -I../src/gui/circuitwidget/components/micro -I../src/gui/circuitwidget/components/meters -I../src/gui/circuitwidget/components/other -I../src/gui/circuitwidget/components/outputs -I../src/gui/circuitwidget/components/outputs/displays -I../src/gui/circuitwidget/components/outputs/leds -I../src/gui/circuitwidget/components/outputs/motors -I../src/gui/circuitwidget/components/passive -I../src/gui/circuitwidget/components/passive/reactive -I../src/gui/circuitwidget/components/passive/resistors -I../src/gui/circuitwidget/components/passive/resist_sensors -I../src/gui/circuitwidget/components/sources -I../src/gui/circuitwidget/components/switches -I../src/gui/circuitwidget/properties -I../src/gui/circuitwidget/subcircuits -I../src/gui/dataplotwidget -I../src/gui/serial -I../src/gui/componentselector -I../src/gui/filebrowser -I../src/gui/editorwidget -I../src/gui/editorwidget/dialogs -I../src/gui/editorwidget/debuggers -I../src/gui/dialogs -I../src/gui/memory -I../src/simulator -I../src/simulator/elements -I../src/simulator/elements/active -I../src/simulator/elements/outputs -I../src/simulator/elements/passive -I../src/microsim -I../src/microsim/cores -I../src/microsim/cores/avr -I../src/microsim/cores/i51 -I../src/microsim/cores/pic -I../src/microsim/cores/mcs65 -I../src/microsim/cores/z80 -I../src/microsim/cores/scripted -I../src/microsim/cores/intmem -I../src/microsim/modules -I../src/microsim/modules/memory -I../src/microsim/modules/usart -I../src/microsim/modules/twi -I../src/microsim/modules/spi -I../src/angel/include -I../src/angel/JIT -I../src/angel/src -Ibuild/moc -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtMultimedia -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Ibuild/moc -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o build/objects/circuitwidget.o ../src/gui/circuitwidget/circuitwidget.cpp In file included from ../src/gui/dialogs/appdialog.h:8, from ../src/gui/circuitwidget/circuitwidget.cpp:17: ./ui_appdialog.h: In member function ‘void Ui_AppDialog::setupUi(QDialog*)’: ./ui_appdialog.h:159:54: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Active, QPalette::PlaceholderText, brush2); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:164:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush3); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:171:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush5); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:296:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette1.setBrush(QPalette::Active, QPalette::PlaceholderText, brush6); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:301:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette1.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush7); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:306:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette1.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush8); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:382:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette2.setBrush(QPalette::Active, QPalette::PlaceholderText, brush9); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:387:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette2.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush10); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:392:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette2.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush11); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:444:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette3.setBrush(QPalette::Active, QPalette::PlaceholderText, brush12); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:449:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette3.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush13); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:454:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette3.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush14); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:470:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette4.setBrush(QPalette::Active, QPalette::PlaceholderText, brush15); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:475:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette4.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush16); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:480:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette4.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush17); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:595:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette5.setBrush(QPalette::Active, QPalette::PlaceholderText, brush18); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:600:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette5.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush19); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:605:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette5.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush20); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:651:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette6.setBrush(QPalette::Active, QPalette::PlaceholderText, brush21); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:656:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette6.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush22); ^~~~~~~~~~~~~~~ ./ui_appdialog.h:661:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette6.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush23); ^~~~~~~~~~~~~~~ In file included from ../src/gui/dialogs/infowidget.h:11, from ../src/gui/circuitwidget/circuitwidget.cpp:19: ./ui_infowidget.h: In member function ‘void Ui_infoWidget::setupUi(QWidget*)’: ./ui_infowidget.h:51:54: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Active, QPalette::PlaceholderText, brush1); ^~~~~~~~~~~~~~~ ./ui_infowidget.h:56:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush2); ^~~~~~~~~~~~~~~ ./ui_infowidget.h:63:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’ palette.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush4); ^~~~~~~~~~~~~~~ At global scope: cc1plus: warning: unrecognized command line option ‘-Wno-deprecated-copy’ make: *** [Makefile:5930: build/objects/circuitwidget.o] Error 1 shaos@amd64s:~/src/OTHER/SimulIDE/trunk/build_XX$ shaos@amd64s:~/src/OTHER/SimulIDE/trunk$ git status fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
У меня Qt 5.11.3 в дебияне стоит... P.S. Ветки 1.0.0 и 1.0.1 собрались без проблем.
08 Mar 2023 02:07 |
arcachofo
Откройте этот файл в Qt Designer и сохраните его: /src/gui/dialogs/appdialog.ui Затем: make clean, qmake, make -j4
08 Mar 2023 02:42 |
fifan
Joined: 06 Oct 2006 03:17 Posts: 859 Location: г.Лянтор,Сургутского р-на,ХМАО
Сразу схему часов под эту версию. Замечание по схеме: DS1307 на выводе IRQ не генерирует прерывание (используется для индикации десятичной точки). Замечание по версии симулятора: нет 14 выводных PIC микроконтроллеров, например PIC16F630.
08 Mar 2023 06:07 |
Спасибо сделал - помогло Теперь видимо тоже самое надо сделать с другим диалогом: P.S. Теперь вот тут застряло:
08 Mar 2023 09:43 |
arcachofo
О DS1307: Программа на этой веб-странице кажется неправильной (согласно техническому описанию): https://www.electronics-lab.com/project ... s1307-rtc/
Он считывает бит 7 из регистра «секунды», чтобы проверить, разрешен ли вывод. Он должен прочитать бит 7 из регистра «Управление».РЕДАКТИРОВАТЬ: я ошибался, что код правильный. Дай мне взглянуть.О PICs: Pic16F630 и другие были добавлены в более поздних версиях. Попробую попробовать добавить их в 1.0.0. О конфигурационном слове: Я внедрил фреймворк Config Word и добавил его в 16F88x. Он контролирует: Внутренняя тактовая частота. Выход Colck в CLKOUT. Включить/отключить сброс ПИН-кода. Включить/отключить сторожевой таймер.
08 Mar 2023 10:46 |
arcachofo
Это головная боль... Моя версия Qt немного новее. Я постараюсь придумать что-нибудь, чтобы решить эту проблему. В любом случае ствол сейчас довольно нестабилен.
08 Mar 2023 10:50 |
FizikS
Логические символы (УГО) для микропроцессорного комплекта MCS65xx. Какого либо стандарта на УГО я не нашел, поэтому критика приветствуется. Установка: распаковать архив в каталог data программы.
10 Mar 2023 00:10 |
Вроде таки собралось и запустилось Какая версия Qt минимум требуется для транка, чтобы без изменений собиралось? P.S. Это одна из причин, почему я не люблю Qt - они всячески агитируют за скачку самой наипоследнейшей версии, которая на поверку оказывается несовместимой со старыми версиями даже на уровне форм, в которых НИЧЕГО не изменилось - просто пересохранил форму в новом дизайнере и привет - чуть более старые версии уже её не понимают...
10 Mar 2023 00:23 |
FizikS
Вышло очередное обновление программы SimulIDE trunk Tester builds R1617.Доступны версии для Windows x64, x86, Linux x64 Скачать можно здесь: https://simulide.forumotion.com/t550-si ... ter-builds В релизе сделаны серьезные изменения, поэтому программа может быть нестабильной. Логический анализатор теперь расшифровывает состояние шины.
17 Mar 2023 07:29 |
FizikS
Версия SimulIDE 1.0.0 получила статус стабильной.Скачать можно на официальном сайте в разделе загрузок: https://www.simulide.com/p/downloads.htmlДополнительно: 1. Описание настроек 4 канального осциллографа: https://www.simulide.com/p/oscilloscope-100.html2. Описание настроек 8 канального логического анализатора: https://www.simulide.com/p/logic-analyzer-100.html
18 Mar 2023 10:54 |
> Дополнительно: Там текста не так уж и много - не стесняйтесь прям сюда печатать с картинками и по русски
18 Mar 2023 23:07 |
FizikS
Сейчас перевожу хелп к ассемблеру SjASMPlus 1.20.2 (чисто для себя, чтобы немного разобраться), в перерыве сделаю переводы указанных выше материалов. Вообще в планах сделать некое подобие справочного руководства по SimulIDE, т.к. официальное руководство очень сильно запаздывает, кое какая информация по применению новых возможностей программы "размазана" по официальному форуму. Буду постить помаленьку... Да и моим студентам сгодится.
19 Mar 2023 00:03 |
forthuser
Встретился такой сайт по схемотехнике и системе команд X86 http://www.club155.ru/aboutP.S. Может информация с него окажется полезной и в рамках развития местного сабжа. Данный сайт оказался на 31-м месте текущего рейтинга, по числу просмотров, по счётчику Mail-aА, есть ли вообще, подборка каких то i-net ресурсов полезных в деле понимания подходов к симуляции железа и каких то справочных материалов?
19 Mar 2023 01:04 |
fifan
Смешно - оплата с России не возможна, теперь и не скачаешь? Когда программа становится платной, пропадает всякий интерес к её использованию.
19 Mar 2023 07:00 |
Users browsing this forum: No registered users and 77 guests |
