Atom Feed | View unanswered posts | View active topics It is currently 26 Apr 2024 10:05
Reply to topic  [ 273 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 19  Next
Tunguska the ternary emulator
eudoxie wrote:
Done.
Great!
25 Feb 2008 07:30
I've also written a short documentation of the new assembler
http://nedopc.org/ternary/tunguska/assembler.html
And uploaded an updated version of the specifications
http://nedopc.org/ternary/tunguska/specsdraft-cvs.pdf
25 Feb 2008 07:36
To test out the new floppy disk system, I put together a small pong clone using vector graphics and mouse steering.
It's nice because it illustrates pretty much every change from alpha-1 to soon-to-be-alpha-2. It's a bit sphagetti-code at the moment. It's also a nice indicator of how fast Tunguska really is. I had to put 8 calls to random (which effectively is a wait for next clock interrupt) just to get it slow enough to be playable. That's just south of 3000 idle instructions. :D
;  Small (completely unbeatable) pong clone. It is not loaded as an operating
;  system, but rather through the LOADSUB function.
;  Assemble into pong.ternobj
;  Run 'tunguska image.ternobj -F pong.ternobj'
;  Type 'LOADSUB'
@EQU   mouse.y      %444C12
@ORG   %DDD000
   ; Bootstrap function
   ; Read page 2 from disk into page 2 in memory
   LDA   #2
   LDY   #2
   JSR   (jumpvector.fl_read_block)
        ; ... and page 3
   LDA   #3
   LDY   #3
   JMP   pongish
; These won't be copied. They are also present in the host at the same
; memory location.
@ORG   %001000
jumpvector:
.getstring:   @DW   0
.feedscreen:   @DW   0
.putchar:   @DW   0
.putnon:   @DW   0
.puts:      @DW   0
.strcmp:   @DW   0
.strlen:   @DW   0
.index:      @DW   0
.strspn:   @DW   0
.strcspn:   @DW   0
.memset6:   @DW   0
.random:   @DW   0
.between:   @DW   0
.repaint:   @DW   0
.fl_read_block: @DW   0
.fl_write_block: @DW   0
@ORG   %002000
pongish:
      ; Clear the screen
      LDX   #%DDB
      LDY   #%DDD
      LDA   #0
.clearloop:
      STA   X,Y
      INY
      JVC   .clearloop
      ; Enable vector mode
      LDA   #%003
      STA   %DDDDDB
.loop:
      LDA   mouse.y
      LDX   #-121+paddle.height/2
      LDY   #121-paddle.height/2
      JSR   (jumpvector.between)
      STA   paddle.pos
      STA   mouse.y
      JSR   paddle.draw
      JSR   enemy.draw
      JSR   ball.draw
      JSR   ball.move
      JSR   enemy.move
      JMP   .loop
.txt:      @DT   'PONGISH', 0
paddle:
.pos:      @DT   0
@EQU      .vectors   %DDBDDD      ; Length 4*3
@EQU      .height      27
@EQU      .width      3
.draw:
      LDA   #%DDD
      STA    .vectors
      LDA   #%444
      STA    .vectors+3
      STA    .vectors+6
      STA    .vectors+9
      STA    .vectors+12
      LDA   #121-.width
      STA   .vectors+1
      STA   .vectors+3+1
      STA   .vectors+12+1
      LDA   #121
      STA   .vectors+6+1
      STA   .vectors+9+1
      LDA   .pos
      CLC
      ADD   #0-.height/2
      STA   .vectors+2
      STA   .vectors+9+2
      STA   .vectors+12+2
      LDA   .pos
      CLC
      ADD   #.height/2
      STA   .vectors+3+2
      STA   .vectors+6+2
      RST
enemy:
.pos:      @DT   0
@EQU      .vectors   %DDBDDD+15   ; Length 4*3
@EQU      .height      27
@EQU      .width      3
.draw:
      LDA   #%DDD
      STA    .vectors
      LDA   #%444
      STA    .vectors+3
      STA    .vectors+6
      STA    .vectors+9
      STA    .vectors+12
      LDA   #-121+.width
      STA   .vectors+1
      STA   .vectors+3+1
      STA   .vectors+12+1
      LDA   #-121
      STA   .vectors+6+1
      STA   .vectors+9+1
      LDA   .pos
      CLC
      ADD   #0-.height/2
      STA   .vectors+2
      STA   .vectors+9+2
      STA   .vectors+12+2
      LDA   .pos
      CLC
      ADD   #.height/2
      STA   .vectors+3+2
      STA   .vectors+6+2
      RST
.move:
      LDA   .pos
      LDX   #-120+.height/2
      LDY   #120-.height/2
      STA   .pos
      LDA   .pos
      CMP   ball.y
      JLT   .inc
      JGT   .dec
      RST
.inc:
      INC   .pos
      RST
.dec:
      DEC   .pos
      RST
ball:
.x:      @DT   0
.y:      @DT   0
.vx:      @DT   2
.vy:      @DT   1
      @EQU   .width 4
      @EQU   .height 4
      @EQU   .vectors   %DDBDDD+30   ; Length 4*3
.draw:
      LDA   #%DDD
      STA    .vectors
      LDA   #%444
      STA    .vectors+3
      STA    .vectors+6
      STA    .vectors+9
      STA    .vectors+12
      LDA   .x
      CLC
      ADD   #0-.width/2
      STA   .vectors+1
      STA   .vectors+3+1
      STA   .vectors+12+1
      LDA   .x
      CLC
      ADD   #0+.width/2
      STA   .vectors+6+1
      STA   .vectors+9+1
      LDA   .y
      CLC
      ADD   #0-.height/2
      STA   .vectors+2
      STA   .vectors+9+2
      STA   .vectors+12+2
      LDA   .y
      CLC
      ADD   #.height/2
      STA   .vectors+3+2
      STA   .vectors+6+2
      RST
.move:
      LDA   .x
      ADD   .vx
      STA   .x
      LDA   .y
      ADD   .vy
      STA   .y
      ; Flip y if floor/ceiling collision
      LDA   .y
      CMP   #121-.height/2
      JGT   .flipy
      CMP   #{.height/2 - 121}
      JLT   .flipy
      ; Don't perform collision detection if not close to
      ; user paddle, x-wise
      LDA   .x
      CMP   #121-paddle.width/2
      JLT   .enemytest
      ; If paddle position - height/2 > y, reset
      LDA   paddle.pos
      ADD   #0-paddle.height/2
      CMP   .y
      JGT   .reset
      LDA   paddle.pos
      ADD   #paddle.height/2
      CMP   .y
      JLT   .reset
      JMP   .flipx
.enemytest:
      LDA   .x
      CMP   #-121+paddle.width/2
      JGT   .mdone
      LDA   enemy.pos
      ADD   #0-enemy.height/2
      CMP   .y
      JGT   .reset
      LDA   enemy.pos
      ADD   #enemy.height/2
      CMP   .y
      JLT   .reset
      JMP   .flipx
      LDA   .x
      CMP   #121-.width/2
      JGT   .flipx
      CMP   #-121 + .width/2
      JLT   .flipx
.mdone:
      JSR   (jumpvector.random)
      RST
.reset:
      LDA   #0
      STA   .x
      STA   .y
      RST
.flipy:
      LDA   .vy
      EOR   #%444
      STA   .vy
      LDA   .y
      LDX   #-121+.height/2
      LDY   #121-.height/2
      STA   .y
      RST
.flipx:
      LDA   .vx
      EOR   #%444
      STA   .vx
      LDA   .x
      LDX   #-121+.width/2
      LDY   #121-.width/2
      STA   .x
      RST
25 Feb 2008 11:14
It's almost uncontrollable by mouse :(
Also it looks slow on my Linux...
P.S. After removing "random" calls it became much faster :)
but still impossible to control something by mouse...
25 Feb 2008 19:36
Yeah, I know, the mouse has issues. I havn't been able to pinpoint exactly what's going wrong though.
As for the speed thing, I've got a dual-core computer, that probably has a huge speed effect (since it's dual threaded now adays).
--edit--
I tinkered with the mouse interrupts. They -may- be less buggy now. Not completely though.
26 Feb 2008 01:59
--edit--
If you add API to read "real-time clock" with 1 ms precision from Tunguska programs then it will become possible to write "self adjustable" programs that will work similar on computers with different computational power.
26 Feb 2008 06:25
Hm, something like that could be doable. Something like a call that simply takes the host RTC, and stores it in a register. It would only be good for differentials since it wraps around to %DDD after %444, but it could be very useful to gague stuff like "how much time does it take to do this", and then adapt the program accordingly.
I'll tinker with that later.
--edit--
I need an opinion on an idea I had: Implementing some trigonometric functions on machine level, primarily sine and cosine. It would calculate the product of sine or cosine of the accumulator with a memory address, and store it in accumulator.
And the angle argument would be in degrees (it's a hard urge to resist with 364 being so close to 360.)
It would be very useful to have fast sine and cosine functionality with vector graphics and whatnot.
26 Feb 2008 06:49
Is it possible to load raw binary data to memory of Tunguska without encoding to balanced ternary code ? I mean that after loading data should take as many trits as number of bits in original binary file. Binary 0s must be left as ternary 0s, and binary 1s should be left as ternary +1s (or it could be converted to ternary -1s).
26 Feb 2008 13:46
sin/cos may be implemented with values -364...+364 instead of -1.0...+1.0 and input may be degrees (0...360)
P.S. I tried to compile last version for Windows. First problem - using of option "-o" in tg_assembler does stack dump. Also "pong" is not working for some reason...
27 Feb 2008 04:35
Not by design, but there shouldn't be any problem writing a converter. The file format is just a gzipped series of signed shorts with values in the range [-364,364]. So, if you wanted to convert a "plain binary" file into a file that would effectively be loaded as you describe, you could write a function like this
short bin2tern(unsigned char c) {
  return (c&1) + 3*(c&2) + 9*(c&4) + 27*(c&8) + 81*(c&16) + 243*(c&32);
and iterate through all the bytes in the file, and write the output of bin2tern as an array of unsigned short to a file.
Hm, that could work...
That's strange. I can't think of anything I have touched since the last version you ported. Maybe it's zlib-related somehow. (that's a dependency now)
Beyond that, I really can't help you. I haven't got any experience in cross-OS porting at all.
27 Feb 2008 11:31
Actually I tried to use options for a first time just in latest Windows version, so probably it was broken since first version...
27 Feb 2008 17:12
Ok, the next "unofficial" build of Tunguska for Windows:
http://nedopc.org/ternary/tunguska/tung ... _2-win.zip (1.1M)
P.S. Demo program pong.asm and pong.ternobj are included (with build_pong.bat and launch_pong.bat)
P.P.S. For CYGWIN version the order of arguments is important:
tg_assembler pong.asm -o pong.ternobj crashes, but
tg_assembler -o pong.ternobj pong.asm works and
tunguska out.ternobj -F pong.ternobj does nothing by LOADSUB, but
tunguska -F pong.ternobj out.ternobj runs the demo...
27 Feb 2008 18:21
I think that's how it is supposed to behave in Linux as well, strictly speaking from how 'getopt' is specified. So the problem is that Linux libc does it's work better than it's supposed to.
I'm considering changing the default file extension away from .ternobj to something more manageable. I haven't made up my mind as to what to replace it with. I've got the following ideas:
.tto, as in ternary/tunguska object.
.tti, as in ternary/tunguska image.
.tmi as in ternary/tunguska memory image.
.tmo as in ternary/tunguska memory object.
.img as in image. Problem with this one is that the extension also is used for CD images and whatnot, and it could cause confusion as to what sort of file it is.
I'd also be glad to hear other suggestions.
I put up a test build of tunguska just now. If you can get it to build without any problems (it's using automake instead of that homemade makefile system I used with alpha-1), I'm going to release version 0.0.2 within a few days.
http://nedopc.org/ternary/tunguska/tung ... st.tar.bz2
28 Feb 2008 08:44
It's compiled successfully, but make install tried to install binaries to /usr/bin that is not good I think, because by default it should be /usr/local/bin, right?
P.S. What if extension will be simply .tg? tg_assembler will create tg-files :lol:
28 Feb 2008 17:21
That's peculiar. Could you try compile some other automake-based package and see if it does the same? It attempts to install to /usr/local/bin on my system.
--edit--
I just released version 0.0.2.
28 Feb 2008 23:40
