Tunguska the ternary emulator
Re: Tunguska the ternary emulator
eudoxie wrote: I don't think there's any benefit from implementing it with hardware, you could simply add a few lines to the painting function, something like
LDA .color
CMP #transparentvalue
JNE $$+4
RST
Hardware "blitting" with color key is always better than software copying pixel by pixel
Mac Buster
Post by Mac Buster »
Yes, I mean support for hardware blitting with transparrent colour.
eudoxie
Post by eudoxie »
Hm, I'll consider it.
I've done some reworking of the assembler, so if it starts acting up do keep me appraised.
eudoxie
Post by eudoxie »
I'm getting ready to prepare for another alpha release (I'm thinking I'll release it sometime next week). Though I'm probably going to disable the floating point functionality in the release. I'm not fond of how it's turned out. I'll either rework it in a future release, or scrap it entirely.
eudoxie
Post by eudoxie »
Added some new instructions...
XAM (Swap A with memory value), XAX (Swap A with X) , XAY (Swap A with Y), XYX (Swap X with Y), PAUSE (software induced pause, acts like a breakpoint in a debugger)
I also re-enabled the floating point operations.
eudoxie
Post by eudoxie »
Indirect Y addressing had somehow managed to be broken all this time. Anyways, it's fixed now, and works like it should.
Mac Buster
Great news, I'm waiting for new release :)
eudoxie
Post by eudoxie »
It probably will be released within a day or two. I'm doing release testing right now.
I've been putting together a manual for Tunguska. So far it consists of documentation for the assembler and emulator, a guide to ternary numeral systems and logic, and the specifications. It's gotten quite big, I think it's almost 30 pages long:
http://tunguska.sourceforge.net/The_Fine_Manual.pdf
Shaos: copy located here: http://nedopc.org/ternary/tunguska/The_Fine_Manual.pdf
eudoxie
Post by eudoxie »
I'd appreciate it if you could try build this pre-release package and see if there is any issues with it on your system.
http://nedopc.org/ternary/tunguska/tung ... se.tar.bz2
eudoxie wrote: I'd appreciate it if you could try build this pre-release package and see if there is any issues with it on your system.
flex 2.5.4
bison 2.1
lex.yy.cc: In member function `virtual int yyFlexLexer::yylex()':
lex.yy.cc:647: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:647: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:648: error: `yyensure_buffer_stack' was not declared in this scope
lex.yy.cc:909: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:909: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:932: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:932: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In constructor `yyFlexLexer::yyFlexLexer(std::istream*, std::ostream*)':
lex.yy.cc:1049: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1050: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1051: error: `yy_buffer_stack_max' was not declared in this scope
lex.yy.cc: In destructor `virtual yyFlexLexer::~yyFlexLexer()':
lex.yy.cc:1061: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1061: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `virtual void yyFlexLexer::switch_streams(std::istream*, std::ostream*)':
lex.yy.cc:1068: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1068: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `int yyFlexLexer::yy_get_next_buffer()':
lex.yy.cc:1120: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1120: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `void yyFlexLexer::yyunput(int, char*)':
lex.yy.cc:1308: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1308: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `int yyFlexLexer::yyinput()':
lex.yy.cc:1352: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1352: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `virtual void yyFlexLexer::yyrestart(std::istream*)':
lex.yy.cc:1420: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1420: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1421: error: `yyensure_buffer_stack' was not declared in this scope
lex.yy.cc:1426: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1426: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `virtual void yyFlexLexer::yy_switch_to_buffer(yy_buffer_state*)':
lex.yy.cc:1442: error: `yyensure_buffer_stack' was not declared in this scope
lex.yy.cc:1443: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1443: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1446: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1446: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1454: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1454: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `void yyFlexLexer::yy_load_buffer_state()':
lex.yy.cc:1467: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1467: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)':
lex.yy.cc:1513: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1513: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `void yyFlexLexer::yy_init_buffer(yy_buffer_state*, std::istream*)':
lex.yy.cc:1542: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1542: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: In member function `void yyFlexLexer::yy_flush_buffer(yy_buffer_state*)':
lex.yy.cc:1574: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1574: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc: At global scope:
lex.yy.cc:1585: error: no `void yyFlexLexer::yypush_buffer_state(yy_buffer_state*)' member function declared in class `yyFlexLexer'
lex.yy.cc: In member function `void yyFlexLexer::yypush_buffer_state(yy_buffer_state*)':
lex.yy.cc:1589: error: `yyensure_buffer_stack' was not declared in this scope
lex.yy.cc:1592: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1592: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1601: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1601: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1603: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1603: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1615: error: no `void yyFlexLexer::yypop_buffer_state()' member function declared in class `yyFlexLexer'
lex.yy.cc: In member function `void yyFlexLexer::yypop_buffer_state()':
lex.yy.cc:1616: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1616: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1619: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1619: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1634: error: no `void yyFlexLexer::yyensure_buffer_stack()' member function declared in class `yyFlexLexer'
lex.yy.cc: In member function `void yyFlexLexer::yyensure_buffer_stack()':
lex.yy.cc:1637: error: `yy_buffer_stack' was not declared in this scope
lex.yy.cc:1650: error: `yy_buffer_stack_max' was not declared in this scope
lex.yy.cc:1651: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1655: error: `yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:1655: error: `yy_buffer_stack_max' was not declared in this scope
lex.yy.cc:1661: error: `yy_buffer_stack' was not declared in this scope
make[3]: *** [lex.yy.o] Ошибка 1
make[2]: *** [all] Ошибка 2
make[1]: *** [all-recursive] Ошибка 1
make: *** [all] Ошибка 2
eudoxie
Post by eudoxie »
eudoxie
Post by eudoxie »
Oh, wait, here's an even better version. Compiled without a hitch on FreeBSD.
http://nedopc.org/ternary/tunguska/tung ... e3.tar.bz2
eudoxie wrote: Oh, wait, here's an even better version. Compiled without a hitch on FreeBSD.
The same thing :(
P.S. Pregenerated scanner.cc and parser.cc MUST be removed from archive!
eudoxie
Post by eudoxie »
It's working
Mouse works also! :)
