How can I connect a joystick to the Sprinter 2000? The connector is X1. But what means JK0-JK4?
Normal is:
1 Forward
2 Back
3 Left
4 Right
5 NC
6 Button 1
7 +5V
8 GND
9 NC
Micky
How can I connect a joystick?
- Novelist
Try these mapping:
JK0 - right
JK1 - left
JK2 - down
JK3 - up
JK4 - fire
P.S. I found scheme of converter from you 9-pin joystick to Kempston interface:
http://8bit.yarek.pl/hardware/zx.joystick/kjschem.gif
JK0 - right
JK1 - left
JK2 - down
JK3 - up
JK4 - fire
- Novelist
- Novelist
See http://www.guildserver.co.uk/tempfiles/sjs-atari.jpg
It looks like what you described in your first post is "Atari" interface, so you need to have Atari joystick to work as a Kempston for this mapping
For old ZX joystick schematic is different
- Novelist
- Novelist
- Novelist
check this schematics:
http://www.epanorama.net/documents/joys ... stick.html
it looks like atari's GND is actually "common" wire, but in case of Kemptson interface (at least in Sp2000 schematics) "common" is +5V, not GND, so this is the reason why Kempston +5V should be connected to atari's "GND" (all JK pulled down to real GND through 1K resistors)
