Atom Feed | View unanswered posts | View active topics It is currently 24 Apr 2024 06:04
Reply to topic  [ 7 posts ]
FFUUTT-code
I will shortly be adding FFUUTT-coding to tunguska. I just want to share the convention with you guys, see if you have any feedback or so.
It is a numbering system for commutative bivalent ternary operations. You simply set up a truth table in the following order
F F X5
F U X4 (= U F)
U U X3
U T X2 (= T U)
T T X1
T F X0 (= F T)
Where X5-X0 is the results of the operation, and then, to get the number of the operation, you simply treat them as a regular terary number.
N = 243*X5 + 81 * X4 + 27 * X3 + 9*X2 + 3*X1 + X0
So, AND would be given N = -322, XOR would be given N = 241, etc.
05 Aug 2008 05:25
Actually ANY ternary operation may not be commutative, so true operation table should have 9 trits, not 6 - see my 3niti alpha instruction set for operation OPB ;)
But if your idea was to put most possible operations to 1 tryte it's OK to think of only commutative ones
06 Aug 2008 18:15
The idea I had was to catalog the commutative operations, since non-commutative operations really don't make that much sense in a tritwise operator.
It is a subset of ternary operations that is more "usable" than non-commutative ones, not just because they're easier to understand, but they are a lot fewer than the just under 20,000 operations possible.
07 Aug 2008 09:58
I will think about hardware implementation of your "FFUUTT-code" to see if it's really simpler than full 9-trit "any binary op"
08 Aug 2008 18:29
If you have cheap ternary OR and AND gates it should reduce pretty nicely. Since
in1 AND in2 is min(in1, in2)
and
in1 OR in2 is max(in1, in2)
You could use that fact (and commutativity) to reduce the problem pretty significantly.
09 Aug 2008 02:06
For convenience, I made a FFUUTT-code calculator here:
http://nedopc.org/ternary/tunguska/ffuutt.html
12 Aug 2008 12:15
I just put this file on our web-site to make it available
11 Nov 2012 18:00
