Milkymist - аудиовизуализатор на ПЛИС (линуксявый микроЭВМ)
antsnark
Post by antsnark »
http://www.milkymist.org/
The project develops a stand-alone device in a small form factor that is capable of rendering MilkDrop-esque visuals effects in real time, with a high level of interaction with many sensors and using live audio and video streams as a base.
Milkymist One
This is the first dedicated board for the Milkymist project. It is currently in development and not available yet. Specifications and schematics here are DRAFT, they might change over time.
Features:
- XC6SLX45 Spartan-6 FPGA
- 128MB 32-bit DDR400 SDRAM
- 32MB parallel flash
- VGA output, 24bpp, up to 140MHz pixel clock
- Multi-standard video input (PAL/SECAM/NTSC)
- AC'97 audio
- 10/100 Ethernet
- Memory card reader that accepts microSD cards
- Two connectors that accept USB peripherals
- Two DMX512 ports
- MIDI IN and MIDI OUT ports
- RC5-compatible infrared receiver
- RS232 debug port
Open-Source
