Electronics
1 Arduino Mini Pro 328 - 3.3V/8MHz available at SparkFun
1 FTDI Basic Breakout (if you don't have one) available at SparkFun
1 4D Systems OLED Module 1.5" (128x128 pixels) available at SparkFun
1 Blackberry Trackballer Breakout available at SparkFun (I'm sensing a theme of the supplier)
1 3.7V 1000mAh Li-Polymer battery available at SparkFun
1 LiPoly Fast Charger available at SparkFun
1 DS1307 Real-time clock available at Digi-Key
1 Crystal 32kHz available at SparkFun
Arduino Mini Pro 328 - можно ли заменить на Freeduino Nano v5 ? Где купить подешевше?
FTDI Basic Breakout - это что? где взять в мск и сколько стоит?
4D Systems OLED Module 1.5" (128x128 pixels) - где взять в мск и сколько стоит?
Blackberry Trackballer Breakout - где взять в мск и сколько стоит?
3.7V 1000mAh Li-Polymer battery - где взять в мск и сколько стоит?
LiPoly Fast Charger
DS1307 Real-time clock - где взять в мск и сколько стоит?
кварц 32kHz
Nuts and Bolts available at local hardware stores
2 #4 bolts 3/8" long
2 #4 bolts 1/4" long
4 #4 bolts 3/4" long
8 #4 nuts
(for the nuts and bolts I found the brass ones at Ace and the zinc ones at Home Depot)
Watch Band
~13" x 1 5/8" leather band for the outer layer (I used a wide leather belt)
~8" x 1 7/8" elastic band for the inner layer (I used another belt)
Misc
1/4" OD copper tube available at Home Depot
1/2" thick piece of wood for screen case, I usually use poplar wood.
6 right angle header pins available at MarVac
1 Connector Housing 6 pin housing (if you can find a 5 pin housing get that) available at MarVac
2 Connector Housings 1 pin housing
7 female pins available at MarVac
1 IDE ribbon cable (dig it out of that pile of cables you never use)
Alternate parts
1 4D Systems OLED Module 0.96" (96x64 pixels) available at SparkFun will also work since I originally programmed the watch for that display until I accidentally broke mine and everyone was out of stock so I had to move to the next size up.
1 3.7V 900mAh Li-Polymer battery available at SparkFun smaller cheaper battery almost as much power.
1 Real-time clock module available at SparkFun or at RobotShop these modules would replace the real-time clock chip and the 32kHz crystal and give you a backup battery.
