Vasil Ivanov: RAMDRV.ZIP (4K)
In DOS of the version 1.61 (and is higher) for access to the
created RAM-disk it is not required rebooting of the computer.
The program automatically traces the versions DOS.
RAMDrive v1.11
RAMDrive v1.11
RAMDRV - utility for creating virtual drives
[!] Important note
[+] New feature
[-] Fixed bug
[*] Changes
Version 1.11 (18.02.2005)
[+] In DOS of the version 1.61 (and is higher) for access to the
Version 1.10 (23.11.2004)
[+] This version may create RAM-drives of any size (below free size
of memory). Only one parameter is needed - size of disk in Kb.
Version 1.04 (06.06.2004)
[-] Changed delay procedure before automative reboot of computer.
Now it does not use CMOS-procedures of system and works correctly
on systems without real-time clock (CMOS).
[!] Important note
[+] New feature
[-] Fixed bug
[*] Changes
RAMdrive
This program may be used to create RAM-disks on Sprinter computer.
RAM-disk is formatted as FAT12 (like MS-DOS floppy). One RAM-disk
may occupy whole Sprinter memory. Minimal size of RAM-disk is 64Kb
(and 47Kb available only). Number of records in root directory is
512. Number of RAM-disks is limited by free memory only. To create
RAM-disk run program with one argument - size of RAM-disk in kilobytes:
ramdrv 1440
For DOS of the version 1.61 (and is higher), the program leaves back
in DOS and to the created RAM-disk access at once is open.
For DOS of the version 1.60 (and is lower), the program will wait 4
seconds and reboot the computer. If you press any key during that 4
seconds, program quit to DOS and user should be reboot computer manu-
ally ("Reset" or "Ctrl+Alt+Del").
During working rogram write table with information about created disk:
Disk size: 1440kB full size of disk
Available space: 1418kB available size of disk
Directory entries: 512 number of records in root
Sector size: 512 bytes number of bytes per sector
Allocation unit: 1 sector number of sectors per cluster
The program uses envirenment variable "LASTDRV". Format of variable
is "LASTDRV=X", where "X" - letter of last drive in system.
ramdrv 1440
