Posts: 24011 Joined: 08 Jan 2003 23:22
by Shaos » 10 Oct 2009 01:09
Recently I created first "hard-copy" version of ternary computer
3niti alpha . Actually it is not TRUE ternary computer, but stand-alone emulator of ternary computer based on binary microcontroller (here PIC16F870) with TRUE ternary controls (15 "ternary" slide switches) and TRUE ternary visualization (15 "ternary" red-green LEDs). This quasi ternary computer is named "3niti alpha simu1" and you can see almost all commands and rules of 3niti directly on its board:
Design of this PCB (127 x 95 mm) is "hobbyist-friendly" (only through-hole components are used): in 4 hours you can solder everything in to make it working similarly to
3niti alpha in java
P.S. Schematics, PCB design and all software will be totally open-source under GPLv3
P.P.S.
You can buy "3niti alpha simu1" Rev.B (PCB or KIT) here:
https://www.tindie.com/products/TRC/3niti-alpha-simu1/
by Shaos » 10 Oct 2009 01:30
Schematics and PCB design for Eagle v5.6.0 with pregenerated Gerber files (Rev.B):
http://nedopc.org/nedopc/16/nedo16v1t-eagle.zip (180K)
Schematics and PCB layout as graphics (images are clickable):
by Shaos » 26 Nov 2009 17:52
Today I finished design of "bug free" revision B (all links and images above were changed already):
by Shaos » 14 Mar 2010 19:14
Prices for revision B board until end of 2011:
PCB only - $49
Kit (PCB & components) - $89
by Shaos » 25 Mar 2010 16:23
by Shaos » 17 Oct 2011 17:01
A number of boards will be produced soon - if you need one please contact me - ashabarshin at gmail dot com
by Shaos » 27 Nov 2011 20:50
Bill of materials:
component where to buy quantity
PIC16F870 jameco.com 246895 1
socket DIP-28 jameco.com 114412 1
tactile switch jameco.com 153251 1
4-pin header(RA) digikey.com S5479-ND 1
20MHz crystal mouser.com 815-AB-20-B2 1
v-reg 7805 jameco.com 51262 1
red LED 5mm mouser.com 78-TLHR5400 1
yellow LED 3mm mouser.com 604-WP7104LYD 1
power terminal jameco.com 152347 1
transistor BC557 mouser.com 512-BC557BTF 5
serial mem 24c32 jameco.com 200563 1
socket DIP-8 jameco.com 51626 1
red-green LED CA mouser.com 604-WP59EGW/CA 15
diode 1N914 jameco.com 179207 15
switch SP3T digikey.com CKN9553-ND or mouser.com 611-OS103012MU2QP1 15
resistor 10K jameco.com 691104 3
resistor 330 jameco.com 690742 8
resistor 3K3 jameco.com 690988 6
capacitor 22pF jameco.com 15405 2
capacitor 100uF jameco.com 29962 1
capacitor 10uF jameco.com 1946359 1
capacitor 0.1uF jameco.com 33488 2 (not 33486!)
by Shaos » 10 Nov 2012 09:07
you still can buy it...
by Shaos » 12 Jun 2018 19:22
