Sprinter video out
mabbypoo
- Junior
Sprinter video out
How do you get the Sprinter to output to VGA monitor or RGB SCART - I have a Sprinter and would like to get it going again with VGA out or RGB but no luck so far - Thanks in advance
Re: Sprinter video out
VGA - not possible (you need a scandoubler to turn 15 kHz to 30 kHz lines)
SCART is possible if it's PAL/SECAM TV with SCART RGB input
17 years ago I used it like this on my Sprinter:
Official SCART cable from authors (a little bit more complicated):
Sprinter - SCART (Name)
1 - 18 & 5 (GND)
2 -
3 -
4 -
5 -
6 - 4 (Sound Left if needed)
7 - 2 (Sound Right if needed)
8 -
9 - 7 (Blue)
10 - 11 (Green)
11 - 15 (Red)
12 -
13 - 20 (Sync)
14 -
15 - 16 (+5V to RGB mode)
Sayman
Sprinter can out screen via VGA output, but not any monitor`s can work with Sprinter output.mabbypoo wrote:How do you get the Sprinter to output to VGA monitor or RGB SCART - I have a Sprinter and would like to get it going again with VGA out or RGB but no luck so far - Thanks in advance
http://15khz.wikidot.com/
This link with 15khz compatible monitors (and with Sprinter too).
I have Benq 912BL worked with Sprinter. Connected via VGA.
but when you assemble the cable, you need to lay a ground through each signal to protect it from interference. Like: R,GND, B, GND, G, GND, etc...
Another SCART pinout diagram:
