MESS эмулирует советские компьютеры
micko
- Novelist
cr0acker
- God
Eric SUX, it does not even have INT generatos.micko wrote:Please take a look, idea is to support as much as possible ROMs.
Meanwhile I will work on Erik, I have already booted machine, and have video out work. Need to map ports now.
(с) Путин
If you use machine translator on my message, it's might be totally incorrect. So, I said this:micko wrote:Please take a look, idea is to support as much as possible ROMs.
Hmm... Quite incompatible code. Where is usual jump tables?
But font is still on his own place. Perhaps standard loader (basic routines a still there, i.e. $C037 & $C337), but monitor is fully incompatible.
Well, in the evening at home I'll take a look closer.
micko
- Novelist
@cr0acker
Idea of MESS is to implement emulation of all machine same are realy bad design, have some bugs in ROM, but idea is to support as much as possible.
@HardWareMan
I agree that it is incompatible code since none of games/applications for Specialist works on it. they are all using direct memory access to write on screen, so in this case when video memory start is on different location it just can't work.
@HardWareMan
cr0acker
- God
Screen offset = 0x8000 --> Screen width = 512?
micko
- Novelist
Все правильно не нужно использовать в эмуляторе ПЗУ от Эрика (кстати не совместимого со Специалистом МХ). Вот можно взять ПЗУ предложенного HardWareMan'ом:
http://www.nedopc.org/nedopc/upload/Ramfos.rar
micko
- Novelist
I have used Erik.bin from Shaos and using PDF documentation I was able to make it run fine.
@fifan
Can you please explain more where to map this in Erik memory map.
Since if I place ROMDISK.BIN instead of ROM it can't work.
Guess this is placed as extension but my question where and how to make it book.
@fifan
Documentation (on russian):micko wrote:Can you please explain more where to map this in Erik memory map.
http://nedopc.org/nedopc/upload/PK_Erik.pdf
Memory and screen map:
http://www.nedopc.org/nedopc/upload/memory.RAR
Erick is don't working clone of Spetsialist. See topic (on russian) for detal:viewtopic.php?t=8766&postdays=0&postorder=asc&start=60micko wrote:Since if I place ROMDISK.BIN instead of ROM it can't work
micko
- Novelist
I guess not. This ROMDISK.BIN is a image of external ROM disk for NC for Specialist (attached to VV55 - 8255). And this image is NOT BOOTABLE. Here is bootable ROM (and internal ROM disk) for Specialist MX:micko wrote:My question is: Is Romdisk.bin you have sent me for Erik ?
http://www.nedopc.org/nedopc/upload/bootableNC.rar
micko
- Novelist
Shure, but not under NC. Some of applications must run under old monitor "MAGIC.COM". You must just load this program and then run MAGIC. Then use standard command "G<ADR>".micko wrote:@hardwareman
I have booted NC and it works (used only romdisk image).
Are all programs from it working on real machine?
That is my compilation of ROM disk and I did not have enough time to test it.micko wrote:I have error running ED7000.COM,DISS.COM,ASMHQ.COM and ASSM.COM
Well, I have some separate applications, and original NC boot ROM. Man, who did this NC has died (Could be just hearsay. I heard it from the head of radiotech hobby group I used to attend. That's where I was using the "Specialist"), so no possible get more info and apps for NC.micko wrote:If you have other rom disks please upload them.
