Galaksija
Re: Galaksija
Post by fifan »
Luciano wrote:To mount a homemade Galaksija which schematic do you suggest?
I suggest to collect Galaksija by Voja Antonich (see bottom of web page - http://www.spetsialist-mx.ru/Galaksija/index.html).
PVV makes a new computer Galaksija Plus.
Luciano
Re: Galaksija
Post by Luciano »
Hi Fifan and PVV
Tested the zx97_9.pdsprj (zx80) and the gal6(Galaksija) both are working on proteus 8.3
(sometimes proteus Suddenly Crashes after a few minutes of simulation.. sometimes not.. maybe my computer is slow.. :econfused: using 65% cpu during simulation)
Using the x80_v11.dll instead of x80.dll.. that is correct?
How can i load a program using the emulator?
Do you have a Galaksija Plus simulation files too?
(My version here is gal6)
Thank you very much!! :no:
PVV
Re: Galaksija
Post by PVV »
Luciano wrote: (sometimes proteus Suddenly Crashes after a few minutes of simulation.. sometimes not.. maybe my computer is slow.. :econfused: using 65% cpu during simulation)
It is happend with old version display.dll, I add new version in last archive, use it.
Luciano wrote: Using the x80_v11.dll instead of x80.dll.. that is correct?
I not tested new x80_v11.dll with zx97, so it's time for testing it :)
Luciano wrote: How can i load a program using the emulator?
It is difficult question. For this time there is two ways for it. First is use ROM disk for simulated's computer. Of course it is needed software support in such computer. (For example RK-86 have it, and I used this way in the beginning). Second way is new - adding support for SD card. All last projects I use this way. Hardware part of SD support are known and not change, and software part modified as needed.
Luciano wrote: Do you have a Galaksija Plus simulation files too?
I include Galaksija Plus schematic in pdf, or you need Proteus project file?
PS: to moderators - ничего, что мы по английски тут общаемся? мы ничего не нарушаем? или давать и русский перевод?
Luciano
Re: Galaksija
Post by Luciano »
Hi PVV
Yes, if possible, please send me the simulation project files for Galaksija
and rom disk for RK-86 too.. i want to test all. :idea:
Thanks a lot!! :rotate:
PVV
Re: Galaksija
Post by PVV »
about RK-86 in PROTEUS:
viewtopic.php?f=93&t=16296#p130761
Galaxy will be bit late, tomorrow, I make common archive.
Re: Galaksija
Guys, should we move conversation in English to proper place?
http://www.nedopc.org/forum/viewforum.php?f=62
I can split the topic (I'm an admin ; )
Re: Galaksija
Post by fifan »
Да, что это мы. Давайте всё по русски здесь писать.
Вопрос к PVV: возможно как-то сделать алтернативный видеовыход к Галаксии Плюс? Не через композит. Почему спрашиваю. Оказывается новые телевизоры очень капризны к видеосигналам подаваемым на композит. У меня два телевизора и оба ну никак не хотят нормально показывать. Убедился в этом подключив после Галаксии Плюс Специалист - практически отсутствие изображения, хотя осциллограф показывает наличие сигналов.
PVV
Re: Galaksija
Post by PVV »
fifan wrote:Да, что это мы. Давайте всё по русски здесь писать.
Просто не русскоговорящий любитель ретро пк задавал вопросы, которые мы уже здесь обсуждали, по тому ответы на них и были по английски.
Сделал в Протеусе схему ГалаксииПлюс, с одной МС памяти на 32КБ, с чип селектом для SD интерфейса, с 'вытаскиванием' скрытых за портами 2КБ памяти и использованием ее для переменных SD интерфейса, плюс тактирование схемы идет от 12.288, а не 6.144Мгц. Файл GALP_SD4.zip. <- Last working GalaxyPlus's Proteus project.
Вот только с использованием 12.288 кварца вижу одну проблему - для тактирования звукового чипа нужна частота 1.5..Мгц, которая при этом кварце не получается... что делать? оставлять 6.144 как это изначально было или при использовании AY чипа на внешней плате ставить еще и ТМ2 для деления процессорного клока в 3..Мгц, там то все равно еще будет как минимум корпус ЛЕ1?
fifan wrote: Вопрос к PVV: возможно как-то сделать алтернативный видеовыход к Галаксии Плюс? Не через композит.
Можно. Я сам с этим столкнулся, и этот вопрос уже прорабатываю... вот здесь обсуждался вариант скалера на VGA, я его начал делать, но с дисплеем пока не могу своим разобраться (странный интерфейс у него). Однако эту схему можно модифицировать под наши нужды и организовать вывод на стандартный монитор, ну или телевизор с VGA входом. Проблема только с кадровой разверткой в 50Гц, как ее монитор и телевизор примут?
Пока наброски этой схемы, файл ...16_vga...
SD4.zip (all Galaxy and GalaxyPlus software, known for this moment) набор всех программ для Галаксии и ГалаксииПлюс, что я нашел, надо проверять.Там что-то со звуком есть, но я свою макетку переделываю в части подключения SD и одного чипа на 32КБ, по тому еще не проверил звук.
Re: Galaksija
Post by fifan »
PVV wrote:вот здесь обсуждался вариант скалера на VGA, я его начал делать
Очень уж сложно. Ещё по микросхемам один компьютер, узконаправлено на конкретный монитор. Нужно что-то универсальное. Вот не плохая задумка была (ZX Kit1), я под неё на своём Специалисте 48 SRAM делан выход, но - не пошло, там картинка указана - http://zx-pk.ru/threads/23487-spetsiali ... post713404.
Luciano
Re: Galaksija
Post by Luciano »
Я проверю файлы, спасибо за вашу помощь! (thank you) :D
PVV
Re: Galaksija
Post by PVV »
sd_dos с поддержкой Галаксии
добавлено: в версии 7_4 введен define для 'старого' типа SD интерфейса(msx)
PVV
Re: Galaksija
Post by PVV »
fifan wrote:По схеме:
А как вообще слышатся звуки? Удалось услышать с какой-нибудь игры?
Звук запустил, нашел одну программку(GalaksijaMusicAY.gtp) которая выводит мелодию на AY чип, все играет. AY подключена по схеме Плюса.
А вот еще одна програмка Sintesajzer (19xx)(Vujkov, Dragan)(YU).gtp у меня не заработала, при старте на экране проскакивает изображение музыкальной клавиатуры и после этого черный экран ( те развертка есть) на клавиатуру не реагирует звуков не издает.
Проверил эту программу в эмуляторах b2m и GalaxyWin, поведение похожее, хотя стартовую заставку показывает до нажатия на клавиатуре, но при нажатии любой клавиши - черный экран...
PVV
Re: Galaksija
Post by PVV »
Разобрался с этим Sintesajzer , все похоже, что так и задумано и синтезатор работает, но не через AY чип, а через выход на магнитофон. Экран же гаснет то-же правильно, в коде стоит команда отключить прерывания, вот отрисовка экрана и не происходит. Подключил динамик к магнитофонному выходу и там звучат разные ноты в зависимости от нажатой кнопки.
Re: Galaksija
PVV wrote:Экран же гаснет то-же правильно, в коде стоит команда отключить прерывания, вот отрисовка экрана и не происходит. Подключил динамик к магнитофонному выходу и там звучат разные ноты в зависимости от нажатой кнопки.
Ну правильно - с прерываниями звук будет хриплый прерывистый.
Раз уж звук генерируют чисто программным путём.
Видимо, у Galaksija и при записи/чтении с магнитофона экран гас, как у "РК-86" или "Микроши".
Как-никак "задача реального времени" исполняется... :wink:
PVV
Re: Galaksija
Post by PVV »
PVV wrote: Вообще, касательно печатной платы, мне было бы интересно развести ее в одном слое, как оригинальная плата Галаксии, что бы можно было ее ЛУТом сделать.
вот как я вижу вариант печатной платы для Галаксии, в варианте под LUT:
синие линии это перемычки, я специально между ножек мс дорожки не проводил, а выпускал их перемычками. Размер платы получается 115х210. Поводники\зазоры худшие значения 0.45\0.44, но старался сделать более широкие дорожки где возможно.
Правда есть мысль сразу на эту плату и SD добавить, тк работать без нее будет проблематично. Есть ли смысл? Просто SD контроллер надо будет подключать на дополнительной плате всегда, и к тому же будет разъем соединительный заниматься, а когда все на одной, то все хорошо, и изготовление за один раз все сделать и не мучаться, и разъем свободный, для программатора или тестера микросхем, которые имеются у Галаксии.
Ну и найдутся ли желающие эту плату изготовить?
-ниже есть плата с меньшим габаритом
