hemuman
Yes, below is the list:
1). Devnagri (From -364 to -109)
2). GREEK Symbols (From -108 to -1)
3). Ascii Chars (From 0 to 255)
4). CYRILLIC (From 256 to 321)
5). CYRILLIC Extention (322 to 341)
6). EMPTY for future use (342 to 362)
7). Filler Values (363 to 364)
02 Sep 2008 00:10 |
Joined: 08 Jan 2003 23:22 Posts: 22769 Location: Silicon Valley
I thought "ASCII" is only first 128 characters
Next 128...255 is probably from some European code page
02 Sep 2008 06:32 |
hemuman
from 128 to 255 it is Extended ASCII Codes
Below link can be referd:
http://www.asciitable.com/
Thanks,
02 Sep 2008 07:35 |
hemuman
Finally I started with TVM, for now i can just post the image.
05 Sep 2008 01:36 |
Mac Buster
Well, it looks like a terminal window What can it do now ?
P.S. Why do you use that "Load Program" button instead of menu item ?
05 Sep 2008 14:50 |
hemuman
For now it can
1). Display tryte value of char
2). perform addition using command "add 1,0,0 1,1,1"
3). Perform multiplication using command "mul 1,0,0 1,1,1"
To quickly load the instruction written in any file.
Next i am going to add something like registers to store the values.
06 Sep 2008 07:33 |
hemuman
Here is some more fancy screen shot,
08 Sep 2008 12:28 |
hemuman
Hello All,
In TVM i am going to assign first 729 trits to the Tryte Chars.
Below is the test image:
11 Sep 2008 03:30 |
hemuman
Hello All,
Finally i am able to release the first draft for the Ternary Virtual Machine (TVM)
Following is the link:
http://tvm.manojky.net/VM/TVM_V1.zip
Following are the instructions:
IMPORTANT:
After extracting the TVM_V1.zip COPY Directory TVM which is present in TVM_V1 directory to c drive.
Open command prompt and change your working directory to TVM_V1 and then Run the program using:
java -jar "TVM_V_1.jar"
Please post your views.
25 Sep 2008 05:27 |
Mac Buster
I am unable to start your application on all three machines where I tried.
27 Sep 2008 01:03 |
Yes, directly it's not working:
To launch it I unzipped it to C: then copied C:\TVM\TVM to C:\TVM
27 Sep 2008 03:22 |
hemuman
Hmm...
Please follow this:
1). Unzip it to Desktop
2). Copy the TVM directory which contains only two files(csv and properties) to C:,actually the program searches for c:\TVM\3t2.csv and the properties file.
3). Launch the application from desktop itself using (java -jar TVM_V_1.jar)
it should work.
28 Sep 2008 04:01 |
hemuman
Hello All,
Did any one try this, as the same error one of friend was facing, later on he followed the above mentioned process and he success fully used it.
Please try.
29 Sep 2008 08:37 |
Mac Buster
Now I can start TVM, thanks!
29 Sep 2008 10:07 |
hemuman
Waw..thats a relief to me. thanks.
01 Oct 2008 00:54 |
