SE Basic IV 4.0 Anya
English forum about Speccy
cheveron
Post by cheveron »
Shaos wrote:But what is "Var" thing anyway?...
Sorry for the late reply. It's just a copy of whatever is in the variables area after the program. I'm making good progress on SE Basic 4.1 now and have added the TRACE, SCROLL, and SPEED commands. The latter replaces two commands (FAST and SLOW).
cheveron
SE Basiv IV Buffy v4.1 developer preview 3
Post by cheveron »
I have now fully commented the source to SE Basiv IV 4.1 and updated the documentation. There are some bugs. Bug reports with steps to reproduce would be appreciated. http://cheveron.github.io/sebasic4/
cheveron
Post by cheveron »
Small update to version 4.0. I've backported the new keyboard mode from 4.1 and juggled a few characters around to support the Chloe 280SE's keyboard.
sebasic405.zip
cheveron
Post by cheveron »
Updated to v4.0.7 with experimental Kempston mouse support...
Num Lock
Re: [ZX] SE Basic IV 4.0 Anya
Post by Num Lock »
Somehow missed this topic, found it only today. Despite already knowing about OpenSE Basic, didn't know about this fork. Seems to be a great project. And it supports 8-bit encoding, just like OpenSE Basic does. Good luck in continuing developing it.
Playing with SE Basic IV v4.0 on my TS2068 (in normal mode):
Machine boots as TS2068, but after OUT 244,3 command it switches to SE Basic IV ;)
I didn't know that I can enter hexadecimal numbers here :)
Like poke &ff00,&ff
Nice :)
cheveron wrote:Updated to v4.0.7 with experimental Kempston mouse support
Interesting, but I'll stay with v4.0.4 :roll:
https://gitlab.com/shaos/sebasic404 (moved in Oct 2025)
P.S. I want to build simplifyed "ZX Spectrum SE" clone with v4.0.4 onboard and I understand that most likely it's a decade long jorney :rotate:
P.P.S. Links to all major versions - Anya 4.0.7: https://github.com/cheveron/sebasic4/blob/SE-Basic-IV-Anya/
v4.1 Buffy: https://github.com/cheveron/sebasic4/tree/SE-Basic-IV-Buffy
v4.2 Cordelia: https://github.com/cheveron/sebasic4/tree/SE-Basic-IV-Cordelia
P.P.P.S. Modern repo (2025) with v4.2 of SE Basic IV: https://github.com/source-solutions/sebasic4/
cheveron
Re: Re:
Post by cheveron »
Some clarification on which version of SE Basic to use for what.
If you want maximum Spectrum compatibility, use SE Basic 3.2 (https://zx.itch.io/sebasic3)
If you want a high degree of Spectrum compatibility, plus an 80 column mode, use SE Basic 4.0 (link above).
Version 4.1 was a failed attempt to refactor the code base that introduced a number of bugs. It's really best to avoid it.
If you think you might be interested in developing for the Chloe 280SE microcomputer, use SE Basic 4.2. It has no Spectrum compatibility. It also requires an esxDOS compatible OS kernel (https://zx.itch.io/sebasic4)
Good to know. Thank you!
cheveron
Post by cheveron »
You're welcome. It's also probably worth noting that SE Basic 4.2 is entirely disk based and it *might* be possible to get it to use TR-DOS instead of esxDOS. It avoids all the TR-DOS address traps (because the divMMC emulates TR-DOS). It depends on if TR-DOS will work with the SE Basic 4.2 ROM, which is radically different from the Spectrum ROM.
Shaos wrote: 26 May 2013 23:17
Shaos wrote:In order to run BasicSE I implemented your memory mapping scheme with ports #7FFD and #FF and now I'm working on keyboard emulation...
Done! :)
My updated emulator can still do SE Basic IV 4.0 Anya 12 years later ;)
Re: SE Basic IV 4.0 Anya
Moved my fork to a new location (and renamed to sebasic404 to avoid any confusion with original sebasic4 that already was developed too far from "Anya"):
Wiki:
https://gitlab.com/shaos/sebasic404/wikis/home
2025-10-25  Alexander Shabarshin <me@shaos.net>
        * SE Basic IV update 4.0.4.1 released!
        * Starting prompt changed to [SE Basic IV "Anya" v4.0.4.1]
        * Replaced PEN command with INK to make it consistent with ZX
        * Replaced IN token with ON (temporarely?) to allow INK to work
        * Universal port number for ay_reg changed from 0xc0f5 to 0xfff5
https://gitlab.com/shaos/sebasic404/-/tree/v4.0.4.1
Video of running updated SE Basic IV in my emulator SprintEm that now partially supports ZX Spectrum SE:
