The Ternary Manifesto
by Douglas W. Jones
THE UNIVERSITY OF IOWA Department of Computer Science
Posted to the web April 1, 2012.
http://homepage.cs.uiowa.edu/~dwjones/ternary/
# To install this software on a Unix, Linux or MacOS system:
# 1) create a directory (e.g. with the shell command mkdir libternary)
# 2) change to that directory (e.g. with the command cd libternary),
# 3) direct the remainder of this text to sh (e.g. sh < thistext).
# This will make sh create files in the new directory; it will do
# nothing else (if you're paranoid, you should scan the following text
# to verify this before you follow these directions). Then read README
# in the new directory for additional instructions.
cat > README «\xxxxxFILEMARKxxxxx
README libternary source code distribution
Version 1.001, Jan 5, 2016
Author: Douglas W. Jones
douglas-w-jones@uiowa.edu
This file Copyright 2015: CC0, equivalent to public domain
See the Copyrights section below for more information.
Archive has ternary library libternary.shar
The Ternary Manifesto, The Trillium Architecture.
askfind
Re: The Ternary Manifesto, The Trillium Architecture.
Changed language to English (it's Ternary (ENG)) and also removed private information from screenshot
askfind
Library libternary.shar
The archive has a ternary ternary library. The link is not downloaded.
To download the archive, make a "mirror" of the site:
List of files in the libternary directory:
Testing
Build в Linux
TEST of the speed of ternary calculations
Tests implemented by the author of the library:
>$ wget -m http://homepage.cs.uiowa.edu/~dwjones/ternary
# You may have to edit this file to delete header lines produced by
# mailers or news systems from this file (all lines before these shell
# comments you are currently reading).
# Shell archive made by Douglas W. Jones on Wed Dec 30 14:02:41 CST 2015
cat > README <<\xxxxxFILEMARKxxxxx
$ tree -L 1
├── libter27.c
├── libter27.h
├── libter27io.c
├── libter27io.h
├── libter9.c
├── libter9.h
├── libter9io.c
├── libter9io.h
├── Makefile
├── README
├── terconst.c
├── test27.c
├── test27io.c
├── test927.c
├── test9.c
└── test9io.c
0 directories, 16 filesTesting
Build в Linux
$ make
cc -c libter9.c
cc -c libter27.c
cc -c libter9io.c
cc -c libter27io.c
ar rc libternary.a libter9.o libter27.o libter9io.o libter27io.o
ranlib libternary.a
$ make test27io
cc test27io.c -L. -lternary
./a.out
Generate uter27_t test data
addition with Fibonacci numbers
up to 6557470319842
Generate bter27_t test data
Addition with Fibonacci numbers
up to 2504730781960
Consume uter27_t test data
success
Consume bter27_t test data
success
rm a.out
test27 test927
libter27io.h libter9io.h libternary.a test27io test9io
libter27io.o libter9io.o terconst test9
askfind
For the first time, as far as I remember, links to the Douglas W. Jones's resource were mentionedaskfind wrote:The Ternary Manifesto
by Douglas W. Jones
on our forum on Feb 14, 2016 here:
viewtopic.php?p=121644#p121644
So I don't see any special reason for such a solemn pathos of this post.
Usually in such cases, we comment such a post with the word "BAYAN" ("accordion" in Russian)
or with the sign "[:|||||:]"
And I think that topic starters should use the "forum search" before posting well-known things so solemnly.
This one is 1st mention in English
And that one was in Russian...
Truly, this post was translated from Russian ...
