Ктонить в FPGA/VHDL разбирается ?
imsushka
Post by imsushka »
Дуремарствую помаленьку. Делаю видеокарточку VGA 1024*768 текстовую.
вылезла бяка. почему то происходит сдвиг пикселей.
при SCALE_x1 (пиксел в пиксел) сдвига нет
при удвоении пикселлов ( SCALE_x2 ) сдвиг на 2 пикселя ( в знакоместе )
при учетверении - сдвиг на 4 пикселя
COLss <= COLs(4 DOWNTO 0) WHEN ( SCALE_x1 = '1' ) ELSE
         COLs(5 DOWNTO 1) WHEN ( SCALE_x2 = '1' ) ELSE
         COLs(6 DOWNTO 2);
PROCESS(CLK)
BEGIN
    IF (RISING_EDGE(CLK)) THEN
      CASE COLs(2 DOWNTO 0) IS
      WHEN "000" =>
        VA <= MEM_SCR;
      WHEN "001" =>
      WHEN "010" =>
        FONT  <= VDi(7 DOWNTO 0);
        COLOR <= VDi(15 DOWNTO 8);
      WHEN "011" =>
        VA <= MEM_FONT;
      WHEN "100" =>
        VA <= MEM_SEL;
      WHEN "101" =>
        FONT_ROW2 <= VDi;
        eCOLOR <= VDi(15 DOWNTO 8);
      WHEN "110" =>
        COLOR0 <= VDi(15 DOWNTO 12);
        COLOR1 <= VDi(11 DOWNTO  8);
        COLOR2 <= VDi( 7 DOWNTO  4);
        COLOR3 <= VDi( 3 DOWNTO  0);
        FONT_ROW1 <= VDi;
      WHEN "111" =>
        IF ( FONT_ColL = '1' ) THEN
          bCOLOR <= eCOLOR;
        ELSE
          bCOLOR <= COLOR;
        END IF;
        IF ( FONT_none = '1' ) THEN
          FONT_ROW0 <= COLOR & FONT;
        ELSE
          FONT_ROW0 <= FONT_ROW2;
        END IF;
        COLs0 <= COLs(3 DOWNTO 0);
      END CASE;
      CASE COLss(2 DOWNTO 0) IS
      WHEN "000" =>
        IF ( FONT_8Pix = '0' AND COLs0(3) = '0' ) THEN
          PIXEL1 <= FONT_ROW0(15);
        ELSE
          PIXEL1 <= FONT_ROW0(7);
        END IF;
        PIXEL2   <= FONT_ROW0(11 DOWNTO 10);
        PIXEL4   <= FONT_ROW0(7 DOWNTO 4);
      WHEN "001" =>
          PIXEL1 <= FONT_ROW0(14);
        ELSE
          PIXEL1 <= FONT_ROW0(6);
        END IF;
        PIXEL2   <= FONT_ROW0(9 DOWNTO 8);
        PIXEL4   <= FONT_ROW0(3 DOWNTO 0);
      WHEN "010" =>
          PIXEL1 <= FONT_ROW0(13);
        ELSE
          PIXEL1 <= FONT_ROW0(5);
        END IF;
        PIXEL2   <= FONT_ROW0(7 DOWNTO 6);
        PIXEL4   <= FONT_ROW1(15 DOWNTO 12);
      WHEN "011" =>
          PIXEL1 <= FONT_ROW0(12);
        ELSE
          PIXEL1 <= FONT_ROW0(4);
        END IF;
        PIXEL2   <= FONT_ROW0(5 DOWNTO 4);
        PIXEL4   <= FONT_ROW1(11 DOWNTO 8);
      WHEN "100" =>
          PIXEL1 <= FONT_ROW0(11);
        ELSE
          PIXEL1 <= FONT_ROW0(3);
        END IF;
        PIXEL2   <= FONT_ROW0(3 DOWNTO 2);
        PIXEL4   <= FONT_ROW1(7 DOWNTO 4);
      WHEN "101" =>
          PIXEL1 <= FONT_ROW0(10);
        ELSE
          PIXEL1 <= FONT_ROW0(2);
        END IF;
        PIXEL2   <= FONT_ROW0(1 DOWNTO 0);
        PIXEL4   <= FONT_ROW1(3 DOWNTO 0);
      WHEN "110" =>
          PIXEL1 <= FONT_ROW0(9);
        ELSE
          PIXEL1 <= FONT_ROW0(1);
        END IF;
        PIXEL2   <= FONT_ROW0(15 DOWNTO 14);
        PIXEL4   <= FONT_ROW0(15 DOWNTO 12);
      WHEN "111" =>
          PIXEL1 <= FONT_ROW0(8);
        ELSE
          PIXEL1 <= FONT_ROW0(0);
        END IF;
        PIXEL2   <= FONT_ROW0(13 DOWNTO 12);
        PIXEL4   <= FONT_ROW0(11 DOWNTO 8);
      END CASE;
    END IF;
END PROCESS;
fifan
Re: Ктонить в FPGA/VHDL разбирается ?
Post by fifan »
В этой абракадабре может разобраться только сам автор. Никакого описания переменных я не вижу.
imsushka
Post by imsushka »
fifan wrote:В этой абракадабре может разобраться только сам автор. Никакого описания переменных я не вижу.
я ужо сделал. или не савсем сделал. но вроде работает.
если я выложу файлы, то лучше не станет. там столько мусора от переделок.....
вот начал очередную переделку. хотелось скрола добавить, плавного
imsushka
Post by imsushka »
Решил выложить на гитхаб.
https://github.com/imsushka/TangNano20K-VIDEO.git
оказыцца в 2011 зарегался там.
azesmbog
Post by azesmbog »
imsushka wrote:Решил выложить на гитхаб.
Авот для совсем чайников, можно ли ПОЛНЫЙ проект, который собирается, и не ругается на отсутствующие файлы counta, fontRom, shift, etc...? Ну чтобы на экране увидеть хоть что-то, что задумал автор??
И еще.. В этом проекте конечно задействован RAM Controller.
Так вот, не могли бы Вы помочь прицеплить его же в известный проект Radio-86RK ? У меня честно не хватает скиллов на это, уж очень кЕтайцы замороченно сделали работу с SDRAM :((
imsushka
Post by imsushka »
полный архив лежит выше на 2 сообщения
и он компилицца
и вроде эти файлы не нужны.
да, квартус сам подключает файлы и отключает, а говин ручками надо.
исправлю / исправил !!!
sdram - я смог запустить только на 66 мгц. 166 как обещано не смог
использовать файл sdram.v задержка на 4 такта.
imsushka
Post by imsushka »
z80 счас отключен, так как не могу доделать скалер. и хочу видеть все режимы.
если кто захочет
файл video_top.v
vga u_vga(
    .clk		(CLK_65MHz    ),//pixel clock
    .RESET_n		(rst_n        ),//low active
//    .CSMEM (wr_vga),
//    .CSREG (io_vga),
    .CSMEM		(1'b1),
    .CSREG		(1'b1),
поменять местами закоменнтированное
о sdram
есть еще файл ram.vhd и он просто обертка к sdram.v зачем не знаю
сам кусок вырвал из какой то реализации синклера
вот гитхаб tang20k-speccy
azesmbog
Post by azesmbog »
и он компилицца
да, слона то я и не заметил. Так да, компилиЦЦа, красивые цветные полосочки из бувк.
знаю этот гитхаб, Карпова. Этот проект так и не запустил, скорее всего не понимаю, надо бы ром-файлы во флеш загрузить, но там в описании этого нет, ну и на экране соответственно ничего нет, и esxdos соответственно не могу попробовать. какая жаль.
я обертку для SDRAM из другого проекта пробовал. На экране даже иногда что-то ВГ75 изображала, но заветной надписи так и не добился :( Ну не умею я готовить я эту памИть, там то два сигнала управления, или в них запутался, или одно из двух.
Ладно, жить еще долго, может и разберусь когда :)
imsushka
Post by imsushka »
azesmbog wrote: да, слона то я и не заметил. Так да, компилиЦЦа, красивые цветные полосочки из бувк.
я тоже замучился и использовал BRAM
мне sdram по таймингам не подходють, или я готовить не умею
буквы нужны шо б понять работает или нет.
а так можно z80 подключить и там тестовая прошивка запускается
проверяет доступ к sdram и выводит так же букофки, но чуть по проще
и цветом задаю есть sdram или нет и работает ли мапер или нет
imsushka
Post by imsushka »
обновил все
вроде работает
включил Z80 - програмка типа демо запускается
остался одын глюк
почему то цвет знакоместа берется от следующего знакоместа. мозг сломал.
на асме разучился писать
копи-паст - зло, но лень всегда побеждает зло !
imsushka
Post by imsushka »
балуюсь с дипсиком и чатжпт
дипсик код выдает получше и не забывает что было парой ответов раньше
жпт может выдавать идеи. ну или просто говорить что моя фигня похжа на фигню которая уже гдето была сделана.
и вот жпт предложил добавить animation bloсk - аппаратную анимацию
Tile index указывает на первый кадр. Далее используются:
4 кадра (AnSiz = 0)
8 кадров (AnSiz = 1)
в фонтах можно нарисовать несколько кадров и железяка будет сама их менять. типа огонь горящий или вода.
кароч обновил гитхаб
еще пытал жпт на предмет сделать железную версию прошивки (на 74 серии), но пока не срослось
а мне самому чой то лень рисовать схему
а вот сам чат
https://chatgpt.com/share/697b5159-5430-8000-abd5-717a861cd20e
