Pentagon/Scorpion 1024k Compatible
Sprinter Computer http://sprinter.nedopc.org
b00mzi11a
Post by b00mzi11a »
Hi, I have tried asking Peters Plus as well, but no reply yet. Does anyone here think there is a chance of the Sprinter having 1024k spectrum compatability? If the answer is yes then I will order my Motherboard straight away : ) !
cr0acker
Re: Pentagon/Scorpion 1024k Compatible
Post by cr0acker »
b00mzi11a wrote:Hi, I have tried asking Peters Plus as well, but no reply yet. Does anyone here think there is a chance of the Sprinter having 1024k spectrum compatability? If the answer is yes then I will order my Motherboard straight away : ) !
Well the problem witn 1024 is that it do not have any standart! Like pentagon and scorpion have different ports. in ZX SPrinter mode, sprinter computer have acces to all 4096Kb, but there is NO spftware that is using it. Even IS-DOS CHIC 2000 is using 256Kb only.
b00mzi11a
Walker
Post by b00mzi11a »
Thanks for the reply :) The main reason I ask is because I want to play "Walker" game on the sprinter. This game says either Pentagon or Scorpion 1024k required, so I think it detects which one you have. Does much software apart from Walker need 1024k? Do you think it might work on Sprinter?
cr0acker
Re: Walker
Post by cr0acker »
b00mzi11a wrote:Thanks for the reply :) The main reason I ask is because I want to play "Walker" game on the sprinter. This game says either Pentagon or Scorpion 1024k required, so I think it detects which one you have. Does much software apart from Walker need 1024k? Do you think it might work on Sprinter?
I have not seen fell relese of Walker& Where di you got it? Maybe i can test is on my sprinter?
b00mzi11a
Walker SCL file
Post by b00mzi11a »
can't remember exact location, but I have posted it here:
http://www.aonz38.dsl.pipex.com/WALKER.SCL
cr0acker
Re: Walker SCL file
Post by cr0acker »
b00mzi11a wrote:can't remember exact location, but I have posted it here:
No this do not run on sprinter, but becaouse of RAM, infact this game runs on 256Kb machine. It dose not run because o Sprinter's CPU. Z84 Cpu series(including Z80H), have equal comnsd out (c),FF and out (c),0 opcodes^)
b00mzi11a
Is this a normal problem?
Post by b00mzi11a »
Hi :) thanks so much for testing it - Does the sprinter have many problems like this with pentagon/scorpion spectrum software? I know it is *not* a spectrum , but what i want it for is mainly Spectrum hardware emulator..
thanks!
cr0acker
Re: Is this a normal problem?
Post by cr0acker »
b00mzi11a wrote:Hi :) thanks so much for testing it - Does the sprinter have many problems like this with pentagon/scorpion spectrum software? I know it is *not* a spectrum , but what i want it for is mainly Spectrum hardware emulator..
thanks!
Wel, NO! he only problem so far is Z84C15 difference from clssical NMOS Z80A/B.
cr0acker
Post by cr0acker »
thanks!
In fact sprinter is spectrum. The only differences are extended mode. And that TLL logick chip/ULA is inside PLD/Altera.
