Tunguska the ternary emulator
eudoxie
Re: Tunguska the ternary emulator
The problem was actually very silly. I used to have these constructions like
memref("DAD", "DBC");
in the code. But that always resolves to the same numerical address, and converting from two strings, to two trytes, to one integer was pretty slow. In fact, so slow it was a major bottleneck. So, instead, I just statically compute the integer value of "DADDBC", and use it as an argument for memref instead.
I checked out last version and it does not look working...
P.S. What is operation CAD?
eudoxie
That's strange. I re-checked-out the entire source tree, it compiled and ran just fine. Could be an issue with the new UI I guess, try copying share/bg.png to /usr/local/share/tunguska/bg.png
CAD is Compare ADdress. It sets the G flag according to the difference between X,Y and the specified address. Example:
LAD some_address
CAD some_other_address
JEQ some_label ; some_address is equal to some_other_address
JNE some_other_label ; not equal
LAD some_address
Background is loaded fine. Then it prints border and HELP message, but no prompt - I can't enter anything!eudoxie wrote: That's strange. I re-checked-out the entire source tree, it compiled and ran just fine. Could be an issue with the new UI I guess, try copying share/bg.png to /usr/local/share/tunguska/bg.png
I tried to build it under Linux (GCC 3.4.6 and SDL 1.2.11) and under Windows (using CYGWIN) - the same results.
eudoxie
Odd. I've added a testcase in the latest CVS version. Run "tunguska -e", and see if you get any unexpected values.
If that doesn't work, try commenting out
floppy->heartbeat() at line 113 in tunguska.cc
or
agd->heartbeat(*m) at line 115 in tunguska.cc
And see if that does anything...
or
It doesn't help...
> tunguska -e
'bg.bmp' not found in '/usr/local/share/tunguska/'
Falling back to 'share/bg.bmp' ... success!
Tunguska loaded null memory, basically
rendering it a drooling vegetable :-(
It's a lot more fun with something in the
memory to execute...Running testcase
't = 10' => 10 (expect 10)
't = t+10' => 20 (expect 20)
't = -365' => 364 (expect 364)
't = 365' => -364 (expect -364)
't = 5; t = t * 2' => 10 (expect 10)
't = 5; t = t / 2' => 2 (expect 2)
't = 5; t = t % 3' => 2 (expect 2)
'm.memref(25) = 10; m.memref(0, 25) += 5' => 15 (expect 15)
'm.memref("DDD", "DDD") = 10; m.memref(-729*729/2) += 5' => 15 (expect 15)
't = 1000; t.to_int();' => 271 (expect 271)
't = -1000; t.to_int();' => -271 (expect -271)
Initial benchmark: 67.935 thousand operations per second
eudoxie
Hm. I have an idea, try isolating when the problem occurred by running cvs with the "-D" parameter.
Like this:
cvs [the usual sourceforge stuff] -D "4 days ago" co tunguska_sources
Like this:
I checked out both sources folders with different -D and found thateudoxie wrote: Hm. I have an idea, try isolating when the problem occurred by running cvs with the "-D" parameter.
Like this:
-D "2008-03-05 13:00" returns working code
-D "2008-03-05 14:00" returns NOT working code
P.S. time is probably shifted to my time zone -0500
eudoxie
Could you run
cvs [... sourceforge stuff ...] co -D "2008-03-05 14:00" -P tunguska_sources
cd tunguska_sources
cvs diff -D "2008-03-05 13:00"
And paste the results here?
cd tunguska_sources
Index: Makefile
RCS file: /cvsroot/tunguska/tunguska_sources/Makefile,v
retrieving revision 1.7
retrieving revision 1.8
diff -r1.7 -r1.8
7,8c7,8
< tunguska: trit.o tryte.o machine.o tunguska.o display.o keyboard.o interrupt.o disk.o coprocessor.o
< g++ trit.o tryte.o machine.o tunguska.o interrupt.o display.o keyboard.o disk.o coprocessor.o -o tunguska ${LDFLAGS}
> tunguska: trit.o tryte.o machine.o tunguska.o display.o keyboard.o interrupt.o disk.o agdp.o
> g++ trit.o tryte.o machine.o tunguska.o interrupt.o display.o keyboard.o disk.o agdp.o -o tunguska ${LDFLAGS}
Index: disk.cc
RCS file: /cvsroot/tunguska/tunguska_sources/disk.cc,v
retrieving revision 1.9
retrieving revision 1.10
diff -r1.9 -r1.10
46c46,47
< tryte &d = m->memref("DDD", "DDA");
> static int offset = tryte::word_to_int("DDD", "DDA");
> tryte &d = m->memref(offset);
Index: display.cc
RCS file: /cvsroot/tunguska/tunguska_sources/display.cc,v
diff -r1.9 -r1.10
101c101,103
< tryte displaytryte = m.memref("DDD", "DDB");
> static int displaymem = tryte::word_to_int("DDD", "DDB");
> tryte displaytryte = m.memref(displaymem);
110c112
< if(refresh == 1) { m.memref("DDD", "DDB")[5] = 0; }
> if(refresh == 1) { m.memref(displaymem)[5] = 0; }
Index: machine.cc
RCS file: /cvsroot/tunguska/tunguska_sources/machine.cc,v
retrieving revision 1.13
retrieving revision 1.15
diff -r1.13 -r1.15
74c74,75
< STRTOOPC(LAD); STRTOOPC(BIT); STRTOOPC(BLT); STRTOOPC(BLS);
> STRTOOPC(LAD); STRTOOPC(BIT); STRTOOPC(PGT); STRTOOPC(PGS);
> STRTOOPC(CAD);
93,94c94,97
< memref("DDD", "DDD") = i->IRQ();
< memref("DDD", "DDC") = i->data();
> static int memirq = tryte::word_to_int("DDD", "DDD");
> static int memirqdata = tryte::word_to_int("DDD", "DDC");
> memref(memirq) = i->IRQ();
> memref(memirqdata) = i->data();
119c122,123
< if((CL > memref("444", "441")) == 1) CL = 0;
> static int moffset = tryte::word_to_int("444", "441");
> if((CL > memref(moffset)) == 1) CL = 0;
261,262c265,267
< case BLT: blt(arg); break;
< case BLS: bls(arg); break;
> case PGT: pgt(arg); break;
> case PGS: pgs(arg); break;
> case CAD: cad(abs1, abs2); break;
455a461,471
> /* Compare ADdress */
> void machine::cad(const tryte* t, const tryte* t2) {
> int V = tryte::word_to_int(*t, *t2);
> int V2 = tryte::word_to_int(X, Y);
> int diff = V - V2;
> if(diff != 0) diff = diff / abs(diff);
> pflag(diff);
464c480
< void machine::blt(const tryte* t) {
> void machine::pgt(const tryte* t) {
474c490
< void machine::bls(const tryte* t) {
> void machine::pgs(const tryte* t) {
Index: machine.h
RCS file: /cvsroot/tunguska/tunguska_sources/machine.h,v
diff -r1.7 -r1.9
61c61
< IVC, PRM, TSH, BUT, LAD, BLT, BLS
> IVC, PRM, TSH, BUT, LAD, PGT, PGS, CAD
167,168c167,170
< void blt(const tryte* t);
< void bls(const tryte* t);
> void cad(const tryte* t, const tryte* t2);
> void pgt(const tryte* t);
> void pgs(const tryte* t);
Index: tunguska.cc
RCS file: /cvsroot/tunguska/tunguska_sources/tunguska.cc,v
diff -r1.13 -r1.15
26c26
< #include "coprocessor.h"
> #include "agdp.h"
35c35
< #define POLL_INTERVAL 5000
> #define POLL_INTERVAL 10000
69c69
< coprocessor* cop) {
> agdp* agd) {
114c114
< cop->heartbeat(*m);
> agd->heartbeat(*m);
117c117
155c155
< coprocessor* cop = new coprocessor();
> agdp* agd= new agdp();
192c192
< cycle(m, disp, floppy, keyboard, cop);
> cycle(m, disp, floppy, keyboard, agd);
204c204
Index: ram.asm
RCS file: /cvsroot/tunguska/tunguska_memory_image_sources/ram.asm,v
retrieving revision 1.20
retrieving revision 1.21
diff -r1.20 -r1.21
236c236
< BLS #%DDD
> PGS #%DDD
277c277
< BLS #%DDD
> PGS #%DDD
Index: stdlib.asm
RCS file: /cvsroot/tunguska/tunguska_memory_image_sources/stdlib.asm,v
retrieving revision 1.6
diff -r1.6 -r1.7
627a628
When I changed in current code
to
it bacames working again!
P.S. Probably you need to put all this kind of constants as class members and initialize them in constructors, because it looks like optimization mistake of compiler (you use -O3) or something like this...
to
eudoxie
Okay, try the latest CVS. I've worked around the static variable approach with compiler macros instead. That should be as fast, or even faster than static variables, since it allows the compiler to "understand" them better.
Also, what sort of speeds does the benchmark give you. I saw you post earlier with a really slow speed. It should be at least in the range 250+ on a reasonably fast computer...
Yes, it's working now!
But scrolling looks strange
And I have benchmark 349 now
eudoxie
Can you elaborate, how does the scrolling look?
Before scrolling:eudoxie wrote: Can you elaborate, how does the scrolling look?
Scrolling in progress:
Result looks fine (except broken lines):
