Rokl
Joined: 16 May 2007 01:01 Posts: 93 Location: 212.5.73.205
Да переименовать файл не трудно, только куда его девать? Куда засылать?
22 Jun 2008 23:05 |
micko
Извините. Ошибка при использовании в режиме он-лайн переводчик.
Я хочу сказать, что BIN, что хорошо для меня.
Вы можете отправить его прямо мне на mmicko@gmail.com
22 Jun 2008 23:21 |
Так, хорош тусовать под столом! Выложи на обменник и все заберут.
2 micko: You can talk in english here.
22 Jun 2008 23:51 |
micko
Rokl: If you could also make a ROM dump of your main ROM of Radio86RK it would be nice, since that one is probably different since it has support to ROM disk. If it is a problematic for you it is not a problem since code changes are small and I have them in Radio magazine.
23 Jun 2008 00:00 |
micko
These are the changes that needs to be made on original Radio86 bios.
F88C: FE 55
F88E: CA 73 FF
FA6D: C3 82 FF
FF73: 21 00 7E
FF76: 11 FF 7F
FF79: 01 00 74
FF7C: C5
FF7D: CD 68 FA
FF80: E1
FF81: E9
FF82: 3E 80
FF84: B4
FF85: 32 02 A0
FF88: 22 01 A0
FF8B: C3 70 FA
Command U will boot ROM disk.
If there is a way to upload file here I could place a binary file so rest of you can use it.
23 Jun 2008 02:09 |
Joined: 08 Jan 2003 23:22 Posts: 22828 Location: Silicon Valley
I can attach file here - send it to me also
23 Jun 2008 02:22 |
micko
Check your email.
23 Jun 2008 02:30 |
http://www.nedopc.org/nedopc/upload/radiorom.rom (2K)
P.S. If I remember correctly original ROM also supports external ROM-disk by R command...
23 Jun 2008 02:43 |
micko
Well this is thing published in Radio magazine number 10 from 1991, which loads code from ROM disk with menu and loader for rest of utilities.
However there is some initial support for ROM disk there but very simple think it's X command (R is used on Micro-80 and UT-88)
23 Jun 2008 02:56 |
Монитор - это хорошо, но я спрашивал за:
Как быть с ней?
23 Jun 2008 08:14 |
fifan
Joined: 06 Oct 2006 03:17 Posts: 858 Location: г.Лянтор,Сургутского р-на,ХМАО
Всем привет! Ну что за проблемы с переводом текста. Я брал Fine Reader, сканировал изображение в текст, потом текстовым редактором (название не помню, могу поискать) превращал в коды для прошивки. Так я набирал тестовый файл к брошюрке по Спецу МХ.
23 Jun 2008 08:56 |
Error404
Joined: 05 Oct 2006 04:45 Posts: 269 Location: Moscow
А ORDOS на РК-86 это было тоже самое, что и на Орионе?
_________________ Всем добра!
23 Jun 2008 08:57 |
micko
I have retyped a loader part from 10/1991. And with already posted ROM it is possible to boot it.
Here is preview.
I have sent a mail with romdisk content to Shaos to upload it.
It is however possible that there is som error, but for now looks fine.
23 Jun 2008 09:44 |
Rokl
Да, ОRDOS 2.4 Работает на РК подобном компе без проблем только от РК осталась архитектура, часть стандартного монитора и отсутствие графики соответственно.
Все, отправил.
23 Jun 2008 09:56 |
micko
Rokl: I have received file now. Thanks a lot.
23 Jun 2008 10:07 |
