на что годится pic16f74?
7400
7400
новая идея
ммс карта+ выход в интернет+мк
вот исходник сервера (если это можно назвать этим словом ну зато потребление около 25 микроампер
* Project Name:
enc28j60Demo (Ethernet Library demo for ENC28J60 mcu)
* Target Platform:
PIC
* Copyright:
(c) mikroElektronika, 2006.
* Revision History:
20060810:
- Initial release. Author: Bruno Gavand.
* V1.0 : first release
* V1.1 : bad MIME type for / path request, changed to HTML instead of SCRIPT (thanks Srdjan !)
* description :
* this code shows how to use the Spi_Ethernet mini library :
* the board will reply to ARP & ICMP echo requests
* the board will reply to UDP requests on any port :
* returns the request in upper char with a header made of remote host IP & port number
* the board will reply to HTTP requests on port 80, GET method with pathnames :
* / will return the HTML main page
* /s will return board status as text string
* /t0 ... /t7 will toggle RD0 to RD7 bit and return HTML main page
* all other requests return also HTML main page
* target devices :
* any PIC with integrated SPI and more than 4 Kb ROM memory
* 32 to 40 MHz clock is recommended to get from 8 to 10 Mhz SPI clock,
* otherwise PIC should be clocked by ENC clock output due to ENC silicon bug in SPI hardware
* if you try lower PIC clock speed, don't be surprised if the board hang or miss some requests !
* EP settings :
* RA2 & RA3 pots jumper : closed
* PORTA : pull-down (place jumper J1 to lower position) (board specific)
* PORTB : pull-down (place jumper J2 to lower position) (board specific)
* PORTC : pull-up (place jumper J3 to upper position) (board specific)
* BUTTONS : pull-up (place jumper J17 to upper position) (board specific)
* RC0 : !RESET to ENC reset input pin
* RC1 : !CS to ENC chip select input pin
* the ENC28J60 SPI bus CLK, SO, SI must be connected to the corresponding SPI pins of the PIC
* the INT and WOL signals from the ENC are not used
* Test configuration:
MCU: PIC16F887
http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
Dev.Board: EasyPIC6
http://www.mikroe.com/en/tools/easypic6/
Oscillator: HS, 08.000MHz
Ext. Modules: mE Serial Ethernet board
http://www.mikroe.com/en/tools/serialeth/
SW: mikroPascal PRO for PIC
http://www.mikroe.com/en/compilers/mikropascal/pro/pic/
* NOTES:
- Since the ENC28J60 doesn't support auto-negotiation, full-duplex mode is
not compatible with most switches/routers. If a dedicated network is used
where the duplex of the remote node can be manually configured, you may
change this configuration. Otherwise, half duplex should always be used.
- External power supply should be used due to Serial Ethernet Board power consumption.
program enc_ethernet;
* RAM variables
var myMacAddr : array[6] of byte ; // my MAC address
myIpAddr : array[4] of byte ; // my IP address
// mE ehternet NIC pinout
SPI_Ethernet_Rst : sbit at PORTC.B0;
SPI_Ethernet_CS : sbit at PORTC.B1;
SPI_Ethernet_Rst_Direction : sbit at TRISC.B0;
SPI_Ethernet_CS_Direction : sbit at TRISC.B1;
// end ethernet NIC definitions
* ROM constant strings
const httpHeader : string[30] = 'HTTP/1.1 200 OK'+#10+'Content-type: ' ; // HTTP header
const httpMimeTypeHTML : string[11] = 'text/html'+#10+#10 ; // HTML MIME type
const httpMimeTypeScript : string[12] = 'text/plain'+#10+#10 ; // TEXT MIME type
const httpMethod : string[5] = 'GET /';
* web page, splited into 2 parts :
* when coming short of ROM, fragmented data is handled more efficiently by linker
* this HTML page calls the boards to get its status, and builds itself with javascript
const indexPage : string[759] =
'<meta http-equiv="refresh" content="3;url=http://192.168.20.60">' +
'<HTML><HEAD></HEAD><BODY>'+
'<h1>PIC + ENC28J60 Mini Web Server</h1>'+
'<a href=/>Reload</a>'+
'<script src=/s></script>'+
'<table><tr><td valign=top><table border=1 style="font-size:20px ;font-family: terminal ;">'+
'<tr><th colspan=2>ADC</th></tr>'+
'<tr><td>AN2</td><td><script>document.write(AN2)</script></td></tr>'+
'<tr><td>AN3</td><td><script>document.write(AN3)</script></td></tr>'+
'</table></td><td><table border=1 style="font-size:20px ;font-family: terminal ;">'+
'<tr><th colspan=2>PORTB</th></tr>'+
'<script>'+
'var str,i;'+
'str="";'+
'for(i=0;i<8;i++)'+
'{str+="<tr><td bgcolor=pink>BUTTON #"+i+"</td>";'+
'if(PORTB&(1<<i)){str+="<td bgcolor=red>ON";}'+
'else {str+="<td bgcolor=#cccccc>OFF";}'+
'str+="</td></tr>";}'+
'document.write(str) ;'+
'</script>';
const indexPage2 : string[466] =
'</table></td><td>'+
'<table border=1 style="font-size:20px ;font-family: terminal ;">'+
'<tr><th colspan=3>PORTD</th></tr>'+
'<script>'+
'var str,i;'+
'str="";'+
'for(i=0;i<8;i++)'+
'{str+="<tr><td bgcolor=yellow>LED #"+i+"</td>";'+
'if(PORTD&(1<<i)){str+="<td bgcolor=red>ON";}'+
'str+="</td><td><a href=/t"+i+">Toggle</a></td></tr>";}'+
'</script>'+
'</table></td></tr></table>'+
'This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>';
var getRequest : array[15] of byte; // HTTP request buffer
dyna : array[30] of char; // buffer for dynamic response
tmp: string[11]; // auxiliary ram string
httpCounter : word ; // counter of HTTP requests
* user defined functions
* this function is called by the library
* the user accesses to the HTTP request by successive calls to SPI_Ethernet_getByte()
* the user puts data in the transmit buffer by successive calls to SPI_Ethernet_putByte()
* the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
* if you don't need to reply to HTTP requests,
* just define this function with a return(0) as single statement
function SPI_Ethernet_UserTCP(var remoteHost : array[4] of byte;
remotePort, localPort, reqLength : word; var canClose: byte) : word;
var i : word ; // my reply length
bitMask : byte ; // for bit mask
begin
result := 0;
// should we close tcp socket after response is sent?
// library closes tcp socket by default if canClose flag is not reset here
// canClose := 0; // 0 - do not close socket
// otherwise - close socket
if(localPort <> 80) then // I listen only to web request on port 80
begin
result := 0;
exit;
end;
// get 10 first bytes only of the request, the rest does not matter here
for i := 0 to 9 do
getRequest[i] := SPI_Ethernet_getByte() ;
getRequest[i] := 0 ;
// copy httpMethod to ram for use in memcmp routine
for i := 0 to 4 do
tmp[i] := httpMethod[i];
if(memcmp(@getRequest, @tmp, 5) <> 0) then // only GET method is supported here
begin
result := 0 ;
exit;
end;
Inc(httpCounter) ; // one more request done
if(getRequest[5] = 's') then // if request path name starts with s, store dynamic data in transmit buffer
begin
// the text string replied by this request can be interpreted as javascript statements
// by browsers
result := SPI_Ethernet_putConstString(@httpHeader) ; // HTTP header
result := result + SPI_Ethernet_putConstString(@httpMimeTypeScript) ; // with text MIME type
// add AN2 value to reply
WordToStr(ADC_Read(2), dyna) ;
tmp := 'var AN2=';
result := result + SPI_Ethernet_putString(@tmp) ;
result := result + SPI_Ethernet_putString(@dyna) ;
tmp := ';';
// add AN3 value to reply
WordToStr(ADC_Read(3), dyna) ;
tmp := 'var AN3=';
tmp := ';';
// add PORTB value (buttons) to reply
tmp := 'var PORTB= ';
WordToStr(PORTB, dyna) ;
tmp := ';';
// add PORTD value (LEDs) to reply
tmp := 'var PORTD= ';
WordToStr(PORTD, dyna) ;
tmp := ';';
// add HTTP requests counter to reply
WordToStr(httpCounter, dyna) ;
tmp := 'var REQ= ';
tmp := ';';
end
else
if(getRequest[5] = 't') then // if request path name starts with t, toggle PORTD (LED) bit number that comes after
begin
bitMask := 0;
if(isdigit(getRequest[6]) <> 0) then // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
begin
bitMask := getRequest[6] - '0' ; // convert ASCII to integer
bitMask := 1 shl bitMask ; // create bit mask
PORTD := PORTD xor bitMask ; // toggle PORTD with xor operator
end;
end;
if(result = 0) then // what do to by default
begin
result := result + SPI_Ethernet_putConstString(@httpMimeTypeHTML) ; // with HTML MIME type
result := result + SPI_Ethernet_putConstString(@indexPage) ; // HTML page first part
result := result + SPI_Ethernet_putConstString(@indexPage2) ; // HTML page second part
end;
// return to the library with the number of bytes to transmit
end;
* the user accesses to the UDP request by successive calls to SPI_Ethernet_getByte()
* the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
* if you don't need to reply to UDP requests,
function SPI_Ethernet_UserUDP(var remoteHost : array[4] of byte;
remotePort, destPort, reqLength : word) : word;
begin
result := 0;
// reply is made of the remote host IP address in human readable format
byteToStr(remoteHost[0], dyna) ; // first IP address byte
dyna[3] := '.' ;
byteToStr(remoteHost[1], tmp) ; // second
dyna[4] := tmp[0];
dyna[5] := tmp[1];
dyna[6] := tmp[2];
dyna[7] := '.' ;
byteToStr(remoteHost[2], tmp) ; // second
dyna[8] := tmp[0];
dyna[9] := tmp[1];
dyna[10] := tmp[2];
dyna[11] := '.' ;
byteToStr(remoteHost[3], tmp) ; // second
dyna[12] := tmp[0];
dyna[13] := tmp[1];
dyna[14] := tmp[2];
dyna[15] := ':' ; // add separator
// then remote host port number
WordToStr(remotePort, tmp) ;
dyna[16] := tmp[0];
dyna[17] := tmp[1];
dyna[18] := tmp[2];
dyna[19] := tmp[3];
dyna[20] := tmp[4];
dyna[21] := '[' ;
WordToStr(destPort, tmp) ;
dyna[22] := tmp[0];
dyna[23] := tmp[1];
dyna[24] := tmp[2];
dyna[25] := tmp[3];
dyna[26] := tmp[4];
dyna[27] := ']' ;
dyna[28] := 0 ;
// the total length of the request is the length of the dynamic string plus the text of the request
result := 28 + reqLength ;
// puts the dynamic string into the transmit buffer
SPI_Ethernet_putBytes(@dyna, 28) ;
// then puts the request string converted into upper char into the transmit buffer
while(reqLength <> 0) do
begin
SPI_Ethernet_putByte(SPI_Ethernet_getByte()) ;
reqLength := reqLength - 1;
end;
// back to the library with the length of the UDP reply
end;
begin
ANSEL := 0x0C ; // AN2 and AN3 convertors will be used
PORTA := 0 ;
TRISA := 0xff ; // set PORTA as input for ADC
ANSELH := 0; // Configure other AN pins as digital I/O
PORTB := 0 ;
TRISB := 0xff ; // set PORTB as input for buttons
PORTD := 0 ;
TRISD := 0 ; // set PORTD as output
httpCounter := 0;
// set mac address
myMacAddr[0] := 0x00;
myMacAddr[1] := 0x14;
myMacAddr[2] := 0xA5;
myMacAddr[3] := 0x76;
myMacAddr[4] := 0x19;
myMacAddr[5] := 0x3F;
// set IP address
myIpAddr[0] := 192;
myIpAddr[1] := 168;
myIpAddr[2] := 20;
myIpAddr[3] := 60;
* starts ENC28J60 with :
* reset bit on PORTC.B0
* CS bit on PORTC.B1
* my MAC & IP address
* full duplex
SPI1_Init(); // init spi module
SPI_Ethernet_Init(myMacAddr, myIpAddr, _SPI_Ethernet_FULLDUPLEX) ; // init ethernet module
SPI_Ethernet_setUserHandlers(@SPI_Ethernet_UserTCP, @SPI_Ethernet_UserUDP); // set user handlers
while true do // do forever
begin
SPI_Ethernet_doPacket() ; // process incoming Ethernet packets
* add your stuff here if needed
* SPI_Ethernet_doPacket() must be called as often as possible
* otherwise packets could be lost
end;
end.-
7400
7400
7400
Shaos вы ведь работали с мк и инетом(viewtopic.php?t=8854) возможно ли будет замутить это софтово + прилепить ммс карту? если да то такой девайс человек 5 выдержит?
7400
fifan
там не софтово, а хардверно - 4 сокета и TCP/IP7400 wrote:Shaos вы ведь работали с мк и инетом(viewtopic.php?t=8854) возможно ли будет замутить это софтово + прилепить ммс карту? если да то такой девайс человек 5 выдержит?
7400
7400
target devices :
но они на эти 4 кб еще и сайт влепили а я допустим буду по байту из ммс карты страницу передовать? правда урезанный фат15 0.5кб займет
дак на PIC16F887 (для которой этот проект и создан) всего лиш 8 кб и оперативы немного больше и вроди все
