TRIMUX - two ternary multiplexers on one PCB
jay4th
Re: TRIMUX - two ternary multiplexers on one PCB
Post by jay4th »
Cool re. working!
How did the invisible organic coating, as opposed to more traditional tin coating, behave with soldering? Any issues?
jay4th wrote: Cool re. working!
I don't know yet. I thought that it's just copper, so I finished this one manually using liquid rosin flux and my soldering iron...
Shaos wrote: 1st board was assembled and tested - it's working :)
When V-NEG=-4.4V and V-POS=+4.4V TRIMUX has thresholds at -3.1V and +1.6V (around second threshold there is a short range of voltage when one switch is already opened, but second is not yet closed). Later I will test it on voltages +5V and -5V.
When V-NEG=-5.0V and V-POS=+5.0V TRIMUX has thresholds at -3.4V and +1.9V
P.S. According to the logo, manufacturer of these DG403s is "Siliconix Inc" (current owner of this brand is Vishay):
See their datasheet here
One possible application of this device - Ternary Half-Adder:
Full adder will require 7 TRIMUX devices
More TRIMUX applications:
TRIMUX connected as buffer:
TRIMUX connected as inverter:
Speed test of TRIMUX connected as inverter (without resistors):
It looks like speed limit for TRIMUX is 1 MHz
I've got new boards:
boards to go:
Official place to buy TRIMUX board ($13) or kit ($30):
http://nedocon.com/store/trimux/
Free U.S. shipping!
you can still buy it
Re: [Ternary] TRIMUX - two ternary multiplexers on one PCB
How to use TRIMUX in English :)
https://web.archive.org/web/20190124001559/https://habr.com/en/post/437254/
UPDATE 2025: Changed direct link to archived one because article disappeared from the net...
Earliest mention of TRIMUX outside of this forum was in 2011:
https://forums.adafruit.com/viewtopic.php?t=22084&start=15
Some links there are dead, so I guess I need to write something about TRIMUX on the 1st page of ternary.info and create at least landing page on trimux.com...
