Радио 86РК floppy & ROM disk
Rokl
Post by Rokl »
micko wrote:Пожалуйста, сделайте that.bin файл является идеальным для меня.
Да переименовать файл не трудно, только куда его девать? Куда засылать?
micko
Post by micko »
Извините. Ошибка при использовании в режиме он-лайн переводчик.
Я хочу сказать, что BIN, что хорошо для меня.
Вы можете отправить его прямо мне на mmicko@gmail.com
Так, хорош тусовать под столом! Выложи на обменник и все заберут.
2 micko: You can talk in english here.
micko
Post by micko »
Rokl: If you could also make a ROM dump of your main ROM of Radio86RK it would be nice, since that one is probably different since it has support to ROM disk. If it is a problematic for you it is not a problem since code changes are small and I have them in Radio magazine.
micko
Post by micko »
These are the changes that needs to be made on original Radio86 bios.
F88C: FE 55
F88E: CA 73 FF
FA6D: C3 82 FF
FF73: 21 00 7E
FF76: 11 FF 7F
FF79: 01 00 74
FF7C: C5
FF7D: CD 68 FA
FF80: E1
FF81: E9
FF82: 3E 80
FF84: B4
FF85: 32 02 A0
FF88: 22 01 A0
FF8B: C3 70 FA
Command U will boot ROM disk.
If there is a way to upload file here I could place a binary file so rest of you can use it.
I can attach file here - send it to me also
micko
Post by micko »
Check your email.
micko wrote:Check your email.
http://www.nedopc.org/nedopc/upload/radiorom.rom (2K)
P.S. If I remember correctly original ROM also supports external ROM-disk by R command...
micko
Post by micko »
Well this is thing published in Radio magazine number 10 from 1991, which loads code from ROM disk with menu and loader for rest of utilities.
However there is some initial support for ROM disk there but very simple think it's X command (R is used on Micro-80 and UT-88)
Re: Радио 86РК floppy & ROM disk
Shaos wrote:http://www.nedopc.org/nedopc/upload/radiorom.rom (2K)
Монитор - это хорошо, но я спрашивал за:
Rokl wrote:Если надо, у меня есть такая ПЗУ с BASIC, ED/ASS, ED/DISASSM, DP/DDT, DRIV/260, DUMPCOR, ORDOS2.4 на кристалле M27С512.
Как быть с ней?
Post by fifan »
Всем привет! Ну что за проблемы с переводом текста. Я брал Fine Reader, сканировал изображение в текст, потом текстовым редактором (название не помню, могу поискать) превращал в коды для прошивки. Так я набирал тестовый файл к брошюрке по Спецу МХ.
Error404
Post by Error404 »
Как быть с ней?
А ORDOS на РК-86 это было тоже самое, что и на Орионе?
Всем добра!
micko
Post by micko »
I have retyped a loader part from 10/1991. And with already posted ROM it is possible to boot it.
Here is preview.
I have sent a mail with romdisk content to Shaos to upload it.
It is however possible that there is som error, but for now looks fine.
Rokl
Post by Rokl »
Error404 wrote:А ORDOS на РК-86 это было тоже самое, что и на Орионе?
Да, ОRDOS 2.4 Работает на РК подобном компе без проблем только от РК осталась архитектура, часть стандартного монитора и отсутствие графики соответственно.
Все, отправил.
micko
Post by micko »
Rokl: I have received file now. Thanks a lot.
