FizikS
Post by FizikS »
Очередное обновление программы SimulIDE 1.0.0 Tester builds доступно на официальном сайте программы:
https://simulide.forumotion.com/t390-si ... ter-builds
 Список изменений
Mostly minor issues and cosmetic improvements and fixed some error introduced in last update.
Also solved some compatibility issues with older versions.
Oscope and LA updated to the last version:
- Move and zoom with mouse.
- Thresholds and Export data to vcd in LA.
- Some issues fixed.
Note that now MCUs don't work if Reset Pin not connected.
A warning msg is shown and Reset Pin blinks in red.
Changes from Rev 1290:
Bugs fixed:
- RAM/ROM: Default to asynchronous.
- Load Circuit: Fix property order from old versions.
- Component: Keep elements legible when flipping.
- BJT & Diode: Error setting properties while debugging.
- Debugger: Jump to PC=0 at first step for asm files.
- Arduino Debugger fails to start debugging.
- Pin: Autoconnecting error.
- Meters: Initialization error (random).
- Oscilloscope: hide label should not be colored.
- Bus: Error at Bus::registerEnode().
- Ground: wrong animation color.
Changes:
- Plotters: Update to last version.
- Oscilloscope: Selected Channel Button more visible.
- WaveGen: Set icon per wave type.
- Several cosmetic improvements.
Shaos wrote:Почему-то бранч для 0.4.15 называется simulide_0.4.14 - я его скачал и собрал в Debian GNU/Linux 10.13 вот по таким шагам:
bzr checkout https://code.launchpad.net/~arcachofo/simulide/simulide_0.4.14
cd simulide_0.4.14/build_XX
qmake
make
А вот trunk у меня не собирается :(
g++ -c -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DREVNO=\"1590\" -DMAINMODULE_EXPORT= -DAPP_VERSION=\"\" -DBUILDDATE=\""07-03-23"\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CONCURRENT_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I. -I../src -I../src/gui -I../src/gui/circuitwidget -I../src/gui/circuitwidget/components -I../src/gui/circuitwidget/components/active -I../src/gui/circuitwidget/components/logic -I../src/gui/circuitwidget/components/micro -I../src/gui/circuitwidget/components/meters -I../src/gui/circuitwidget/components/other -I../src/gui/circuitwidget/components/outputs -I../src/gui/circuitwidget/components/outputs/displays -I../src/gui/circuitwidget/components/outputs/leds -I../src/gui/circuitwidget/components/outputs/motors -I../src/gui/circuitwidget/components/passive -I../src/gui/circuitwidget/components/passive/reactive -I../src/gui/circuitwidget/components/passive/resistors -I../src/gui/circuitwidget/components/passive/resist_sensors -I../src/gui/circuitwidget/components/sources -I../src/gui/circuitwidget/components/switches -I../src/gui/circuitwidget/properties -I../src/gui/circuitwidget/subcircuits -I../src/gui/dataplotwidget -I../src/gui/serial -I../src/gui/componentselector -I../src/gui/filebrowser -I../src/gui/editorwidget -I../src/gui/editorwidget/dialogs -I../src/gui/editorwidget/debuggers -I../src/gui/dialogs -I../src/gui/memory -I../src/simulator -I../src/simulator/elements -I../src/simulator/elements/active -I../src/simulator/elements/outputs -I../src/simulator/elements/passive -I../src/microsim -I../src/microsim/cores -I../src/microsim/cores/avr -I../src/microsim/cores/i51 -I../src/microsim/cores/pic -I../src/microsim/cores/mcs65 -I../src/microsim/cores/z80 -I../src/microsim/cores/scripted -I../src/microsim/cores/intmem -I../src/microsim/modules -I../src/microsim/modules/memory -I../src/microsim/modules/usart -I../src/microsim/modules/twi -I../src/microsim/modules/spi -I../src/angel/include -I../src/angel/JIT -I../src/angel/src -Ibuild/moc -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtMultimedia -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Ibuild/moc -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o build/objects/circuitwidget.o ../src/gui/circuitwidget/circuitwidget.cpp
In file included from ../src/gui/dialogs/appdialog.h:8,
                 from ../src/gui/circuitwidget/circuitwidget.cpp:17:
./ui_appdialog.h: In member function ‘void Ui_AppDialog::setupUi(QDialog*)’:
./ui_appdialog.h:159:54: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Active, QPalette::PlaceholderText, brush2);
./ui_appdialog.h:164:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush3);
./ui_appdialog.h:171:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush5);
./ui_appdialog.h:296:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette1.setBrush(QPalette::Active, QPalette::PlaceholderText, brush6);
./ui_appdialog.h:301:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette1.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush7);
./ui_appdialog.h:306:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette1.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush8);
./ui_appdialog.h:382:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette2.setBrush(QPalette::Active, QPalette::PlaceholderText, brush9);
./ui_appdialog.h:387:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette2.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush10);
./ui_appdialog.h:392:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette2.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush11);
./ui_appdialog.h:444:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette3.setBrush(QPalette::Active, QPalette::PlaceholderText, brush12);
./ui_appdialog.h:449:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette3.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush13);
./ui_appdialog.h:454:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette3.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush14);
./ui_appdialog.h:470:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette4.setBrush(QPalette::Active, QPalette::PlaceholderText, brush15);
./ui_appdialog.h:475:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette4.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush16);
./ui_appdialog.h:480:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette4.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush17);
./ui_appdialog.h:595:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette5.setBrush(QPalette::Active, QPalette::PlaceholderText, brush18);
./ui_appdialog.h:600:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette5.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush19);
./ui_appdialog.h:605:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette5.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush20);
./ui_appdialog.h:651:55: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette6.setBrush(QPalette::Active, QPalette::PlaceholderText, brush21);
./ui_appdialog.h:656:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette6.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush22);
./ui_appdialog.h:661:57: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette6.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush23);
In file included from ../src/gui/dialogs/infowidget.h:11,
                 from ../src/gui/circuitwidget/circuitwidget.cpp:19:
./ui_infowidget.h: In member function ‘void Ui_infoWidget::setupUi(QWidget*)’:
./ui_infowidget.h:51:54: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Active, QPalette::PlaceholderText, brush1);
./ui_infowidget.h:56:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Inactive, QPalette::PlaceholderText, brush2);
./ui_infowidget.h:63:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
         palette.setBrush(QPalette::Disabled, QPalette::PlaceholderText, brush4);
At global scope:
cc1plus: warning: unrecognized command line option ‘-Wno-deprecated-copy’
make: *** [Makefile:5930: build/objects/circuitwidget.o] Error 1
shaos@amd64s:~/src/OTHER/SimulIDE/trunk/build_XX$
shaos@amd64s:~/src/OTHER/SimulIDE/trunk$ git status
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
У меня Qt 5.11.3 в дебияне стоит...
P.S. Ветки 1.0.0 и 1.0.1 собрались без проблем.
arcachofo
Post by arcachofo »
Откройте этот файл в Qt Designer и сохраните его:
/src/gui/dialogs/appdialog.ui
Затем: make clean, qmake, make -j4
Post by fifan »
FizikS wrote:Очередное обновление программы SimulIDE 1.0.0 Tester builds доступно на официальном сайте программы:
Сразу схему часов под эту версию.
Замечание по схеме: DS1307 на выводе IRQ не генерирует прерывание (используется для индикации десятичной точки).
Замечание по версии симулятора: нет 14 выводных PIC микроконтроллеров, например PIC16F630.
Спасибо сделал - помогло
Теперь видимо тоже самое надо сделать с другим диалогом:
g++ -c -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DREVNO=\"1590\" -DMAINMODULE_EXPORT= -DAPP_VERSION=\"\" -DBUILDDATE=\""08-03-23"\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CONCURRENT_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I. -I../src -I../src/gui -I../src/gui/circuitwidget -I../src/gui/circuitwidget/components -I../src/gui/circuitwidget/components/active -I../src/gui/circuitwidget/components/logic -I../src/gui/circuitwidget/components/micro -I../src/gui/circuitwidget/components/meters -I../src/gui/circuitwidget/components/other -I../src/gui/circuitwidget/components/outputs -I../src/gui/circuitwidget/components/outputs/displays -I../src/gui/circuitwidget/components/outputs/leds -I../src/gui/circuitwidget/components/outputs/motors -I../src/gui/circuitwidget/components/passive -I../src/gui/circuitwidget/components/passive/reactive -I../src/gui/circuitwidget/components/passive/resistors -I../src/gui/circuitwidget/components/passive/resist_sensors -I../src/gui/circuitwidget/components/sources -I../src/gui/circuitwidget/components/switches -I../src/gui/circuitwidget/properties -I../src/gui/circuitwidget/subcircuits -I../src/gui/dataplotwidget -I../src/gui/serial -I../src/gui/componentselector -I../src/gui/filebrowser -I../src/gui/editorwidget -I../src/gui/editorwidget/dialogs -I../src/gui/editorwidget/debuggers -I../src/gui/dialogs -I../src/gui/memory -I../src/simulator -I../src/simulator/elements -I../src/simulator/elements/active -I../src/simulator/elements/outputs -I../src/simulator/elements/passive -I../src/microsim -I../src/microsim/cores -I../src/microsim/cores/avr -I../src/microsim/cores/i51 -I../src/microsim/cores/pic -I../src/microsim/cores/mcs65 -I../src/microsim/cores/z80 -I../src/microsim/cores/scripted -I../src/microsim/cores/intmem -I../src/microsim/modules -I../src/microsim/modules/memory -I../src/microsim/modules/usart -I../src/microsim/modules/twi -I../src/microsim/modules/spi -I../src/angel/include -I../src/angel/JIT -I../src/angel/src -Ibuild/moc -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtSvg -isystem /usr/include/x86_64-linux-gnu/qt5/QtWidgets -isystem /usr/include/x86_64-linux-gnu/qt5/QtMultimedia -isystem /usr/include/x86_64-linux-gnu/qt5/QtGui -isystem /usr/include/x86_64-linux-gnu/qt5/QtXml -isystem /usr/include/x86_64-linux-gnu/qt5/QtConcurrent -isystem /usr/include/x86_64-linux-gnu/qt5/QtSerialPort -isystem /usr/include/x86_64-linux-gnu/qt5/QtNetwork -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -Ibuild/moc -isystem /usr/include/libdrm -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o build/objects/circuitwidget.o ../src/gui/circuitwidget/circuitwidget.cpp
At global scope:
make: *** [Makefile:5951: build/objects/circuitwidget.o] Error 1
P.S. Теперь вот тут застряло:
In file included from ../src/gui/editorwidget/dialogs/editorprop.h:7,
                 from ../src/gui/editorwidget/editorwidget.cpp:21:
./ui_editorprop.h: In member function ‘void Ui_EditorProp::setupUi(QDialog*)’:
./ui_editorprop.h:65:54: error: ‘PlaceholderText’ is not a member of ‘QPalette’
./ui_editorprop.h:70:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
./ui_editorprop.h:77:56: error: ‘PlaceholderText’ is not a member of ‘QPalette’
At global scope:
make: *** [Makefile:6569: build/objects/editorwidget.o] Error 1
arcachofo
Post by arcachofo »
О DS1307:
Программа на этой веб-странице кажется неправильной (согласно техническому описанию):
https://www.electronics-lab.com/project ... s1307-rtc/
Он считывает бит 7 из регистра «секунды», чтобы проверить, разрешен ли вывод.
Он должен прочитать бит 7 из регистра «Управление».
РЕДАКТИРОВАТЬ: я ошибался, что код правильный.
Дай мне взглянуть.
О PICs:
Pic16F630 и другие были добавлены в более поздних версиях.
Попробую попробовать добавить их в 1.0.0.
О конфигурационном слове:
Я внедрил фреймворк Config Word и добавил его в 16F88x.
Он контролирует:
Внутренняя тактовая частота.
Выход Colck в CLKOUT.
Включить/отключить сброс ПИН-кода.
Включить/отключить сторожевой таймер.
arcachofo
Post by arcachofo »
Это головная боль...
Моя версия Qt немного новее.
Я постараюсь придумать что-нибудь, чтобы решить эту проблему.
В любом случае ствол сейчас довольно нестабилен.
FizikS
Post by FizikS »
Логические символы (УГО) для микропроцессорного комплекта MCS65xx. Какого либо стандарта на УГО я не нашел, поэтому критика приветствуется.
Установка: распаковать архив в каталог data программы.
Вроде таки собралось и запустилось
Какая версия Qt минимум требуется для транка, чтобы без изменений собиралось?
P.S. Это одна из причин, почему я не люблю Qt - они всячески агитируют за скачку самой наипоследнейшей версии, которая на поверку оказывается несовместимой со старыми версиями даже на уровне форм, в которых НИЧЕГО не изменилось - просто пересохранил форму в новом дизайнере и привет - чуть более старые версии уже её не понимают...
FizikS
Post by FizikS »
Вышло очередное обновление программы SimulIDE trunk Tester builds R1617.
Доступны версии для Windows x64, x86, Linux x64
Скачать можно здесь: https://simulide.forumotion.com/t550-si ... ter-builds
В релизе сделаны серьезные изменения, поэтому программа может быть нестабильной.
Логический анализатор теперь расшифровывает состояние шины.
FizikS
Post by FizikS »
Версия SimulIDE 1.0.0 получила статус стабильной.
Скачать можно на официальном сайте в разделе загрузок: https://www.simulide.com/p/downloads.html
Дополнительно:
1. Описание настроек 4 канального осциллографа: https://www.simulide.com/p/oscilloscope-100.html
2. Описание настроек 8 канального логического анализатора: https://www.simulide.com/p/logic-analyzer-100.html
> Дополнительно:
Там текста не так уж и много - не стесняйтесь прям сюда печатать с картинками и по русски :idea:
FizikS
Post by FizikS »
Сейчас перевожу хелп к ассемблеру SjASMPlus 1.20.2 (чисто для себя, чтобы немного разобраться), в перерыве сделаю переводы указанных выше материалов.
Вообще в планах сделать некое подобие справочного руководства по SimulIDE, т.к. официальное руководство очень сильно запаздывает, кое какая информация по применению новых возможностей программы "размазана" по официальному форуму. Буду постить помаленьку... Да и моим студентам сгодится.
forthuser
Post by forthuser »
Встретился такой сайт по схемотехнике и системе команд X86
http://www.club155.ru/about
P.S. Может информация с него окажется полезной и в рамках развития местного сабжа.
Данный сайт оказался на 31-м месте текущего рейтинга, по числу просмотров, по счётчику Mail-a
А, есть ли вообще, подборка каких то i-net ресурсов полезных в деле понимания подходов к симуляции железа и каких то справочных материалов?
Post by fifan »
FizikS wrote:Вышло очередное обновление программы SimulIDE trunk Tester builds R1617.
Смешно - оплата с России не возможна, теперь и не скачаешь? Когда программа становится платной, пропадает всякий интерес к её использованию.
