Программируем с ИИ
alexcp
Re: Программируем с ИИ
Post by alexcp »
Мне тут ChatGPT сочинил интерпретатор языка Brainfuck. Сам я не стал бы на это время тратить, а так вышла вполне годная игрушка.
  brainfuck.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
typedef struct {
    size_t open;
    size_t close;
} BracketPair;
typedef struct {
    char *program;
    size_t program_size;
    size_t *bracket_map;
    unsigned char *tape;
    size_t tape_size;
    size_t ip;  // instruction pointer
    size_t dp;  // data pointer
} BrainfuckInterpreter;
void build_bracket_map(BrainfuckInterpreter *bf) {
    size_t *stack = malloc(bf->program_size * sizeof(size_t));
    size_t stack_size = 0;
    for (size_t i = 0; i < bf->program_size; ++i) {
        if (bf->program[i] == '[') {
            stack[stack_size++] = i;
        } else if (bf->program[i] == ']') {
            if (stack_size == 0) {
                fprintf(stderr, "Error: Unmatched ']' at position %zu\n", i);
                exit(EXIT_FAILURE);
            size_t open_pos = stack[--stack_size];
            bf->bracket_map[open_pos] = i;
            bf->bracket_map[i] = open_pos;
    if (stack_size != 0) {
        fprintf(stderr, "Error: Unmatched '[' at position %zu\n", stack[stack_size - 1]);
        exit(EXIT_FAILURE);
    free(stack);
void run(BrainfuckInterpreter *bf) {
    while (bf->ip < bf->program_size) {
        char cmd = bf->program[bf->ip];
        switch (cmd) {
            case '>':
                bf->dp++;
                if (bf->dp >= bf->tape_size) {
                    bf->tape_size *= 2;
                    bf->tape = realloc(bf->tape, bf->tape_size);
                    memset(bf->tape + bf->tape_size / 2, 0, bf->tape_size / 2);
                break;
            case '<':
                if (bf->dp == 0) {
                    fprintf(stderr, "Error: Data pointer moved left of tape start.\n");
                    exit(EXIT_FAILURE);
                bf->dp--;
                break;
            case '+':
                bf->tape[bf->dp]++;
                break;
            case '-':
                bf->tape[bf->dp]--;
                break;
            case '.':
                putchar(bf->tape[bf->dp]);
                break;
            case ',':
                int c = getchar();
                if (c != EOF)
                    bf->tape[bf->dp] = (unsigned char)c;
                else
                    bf->tape[bf->dp] = 0;
                break;
            case '[':
                if (bf->tape[bf->dp] == 0)
                    bf->ip = bf->bracket_map[bf->ip];
                break;
            case ']':
                if (bf->tape[bf->dp] != 0)
                break;
            default:
                // Ignore non-Brainfuck characters
                break;
        bf->ip++;
char *read_file(const char *filename, size_t *out_size) {
    FILE *file = fopen(filename, "rb");
    if (!file) {
        perror("Error opening file");
        exit(EXIT_FAILURE);
    fseek(file, 0, SEEK_END);
    long size = ftell(file);
    rewind(file);
    char *buffer = malloc(size + 1);
    if (!buffer) {
        perror("Memory allocation failed");
        exit(EXIT_FAILURE);
    fread(buffer, 1, size, file);
    buffer[size] = '\0';
    fclose(file);
    if (out_size)
        *out_size = (size_t)size;
    return buffer;
int main(int argc, char *argv[]) {
    if (argc != 2) {
        fprintf(stderr, "Usage: brainfuck <program_file>\n");
        return EXIT_FAILURE;
    BrainfuckInterpreter bf;
    bf.program = read_file(argv[1], &bf.program_size);
    bf.bracket_map = malloc(bf.program_size * sizeof(size_t));
    bf.ip = 0;
    bf.dp = 0;
    // Initialize tape
    bf.tape_size = 1024;
    bf.tape = calloc(bf.tape_size, sizeof(unsigned char));
    build_bracket_map(&bf);
    run(&bf);
    free(bf.program);
    free(bf.bracket_map);
    free(bf.tape);
    return EXIT_SUCCESS;
Если что, компилируется и запускается примерно так:
gcc -std=c99 -O2 -Wall -Wextra -o brainfuck brainfuck.c
./brainfuck hello.bf
Пример программы (из Википедии):
 hello.bf
[ This program prints "Hello World!" and a newline to the screen; its
  length is 106 active command characters. [It is not the shortest.]
  This loop is an "initial comment loop", a simple way of adding a comment
  to a BF program such that you don't have to worry about any command
  characters. Any ".", ",", "+", "-", "<" and ">" characters are simply
  ignored, the "[" and "]" characters just have to be balanced. This
  loop and the commands it contains are ignored because the current cell
  defaults to a value of 0; the 0 value causes this loop to be skipped.
++++++++                Set Cell #0 to 8
    >++++               Add 4 to Cell #1; this will always set Cell #1 to 4
    [                   as the cell will be cleared by the loop
        >++             Add 2 to Cell #2
        >+++            Add 3 to Cell #3
        >+++            Add 3 to Cell #4
        >+              Add 1 to Cell #5
        <<<<-           Decrement the loop counter in Cell #1
    ]                   Loop until Cell #1 is zero; number of iterations is 4
    >+                  Add 1 to Cell #2
    >+                  Add 1 to Cell #3
    >-                  Subtract 1 from Cell #4
    >>+                 Add 1 to Cell #6
    [<]                 Move back to the first zero cell you find; this will
                        be Cell #1 which was cleared by the previous loop
    <-                  Decrement the loop Counter in Cell #0
]                       Loop until Cell #0 is zero; number of iterations is 8
The result of this is:
Cell no :   0   1   2   3   4   5   6
Contents:   0   0  72 104  88  32   8
Pointer :   ^
>>.                     Cell #2 has value 72 which is 'H'
>---.                   Subtract 3 from Cell #3 to get 101 which is 'e'
+++++++..+++.           Likewise for 'llo' from Cell #3
>>.                     Cell #5 is 32 for the space
<-.                     Subtract 1 from Cell #4 for 87 to give a 'W'
<.                      Cell #3 was set to 'o' from the end of 'Hello'
+++.------.--------.    Cell #3 for 'rl' and 'd'
>>+.                    Add 1 to Cell #5 gives us an exclamation point
>++.                    And finally a newline from Cell #6
Надо попросить Клода на Robby это переписать ;)
imsushka
Post by imsushka »
балуюсь с гпт чатом.
ересь он несет. или я ересь несу?
по статьям всяким у народа раз два и готовая программа полностью рабочая.
у меня с кучей обшибок и плюс левые алгоритмы.
чядн???
или все работает но только в платных версиях ?
дипсик такой же
alexcp
Post by alexcp »
Ересь несет ChatGPT (а также DeepSeek и иже с ними). А что вы хотели от Large Language Model? Она же обучена только языком болтать, все остальное - побочный эффект.
imsushka
Post by imsushka »
ну, дык, тут пишут что безработицца в мире. програмеры не нужны. все ии делает.
манагер пальцами щелкает и все готово.
вот я тоже манагером захотел стать
alexcp
Post by alexcp »
Проблема такая есть, но вроде бы пока в полный рост не стоит. Я сам достаточно далек от этого, но читал, что ИИ активно используется для создания прототипов - получается на порядок дешевле и быстрее, чем нанимать людей на раннем этапе, когда непонятно еще, получится что-то или нет.
imsushka
Post by imsushka »
хай, выше было - написать брайнфака - написал.
вроде рабочий.
или он просто где то был в инете и ИИ типа "написал"/нашел ?
была статья на хабре. типа тоже попросили написать какуюто игрушку. написал и типа сразу запустили и работает.
у меня ничо не работает. надо не просто напильником, надо кувалдой подправлять
А на каком языке пытаешься то писать?
P.S. В плане программирования работает подход как в Claude Code или Github Copilot, когда ты объясняешь ему как программу компилировать (глядя на ошибки компиляции) и затем как запускать (обозначая ожидаемый результат) и оно само начинает (после глобального одобрямса) всё исправлять-компилять-запускать, пока не придёт к удобоваримому результату. Единственное лучше это делать в "песочнице" (типа VirtualBox) т.к. он может сдуру в момент заскока все файлы на диске грохнуть :roll:
imsushka
Post by imsushka »
Shaos wrote: 27 Jan 2026 09:53 А на каком языке пытаешься то писать?
по русски
vhdl
и на асме и паскале пытался. да компилицца, но сам алгоритм ...
чатгпт в плане раритетов (vhdl или паскаль) может быть просто не силён - надо пробовать что-то другое
imsushka
Post by imsushka »
Shaos wrote: 27 Jan 2026 10:12 чатгпт в плане раритетов (vhdl или паскаль) может быть просто не силён - надо пробовать что-то другое
так он не силен даже в алгоритмах.
просишь одно, а на выходе хрень. поправляешь его, а он то что было до этого нормально - порет
Re: AI Cursor редактор кода с ИИ
Shaos wrote: 19 Oct 2024 13:08 Вроде говорят Cursor силён только в питоне и джаваскрипте, а во всех остальных языках - слабоват
Я сам какое-то время уже хочу этот ИИ редактор попробовать т.к. сам в питоне не эксперт (хотя свою первую программу на питоне я написал ещё в 1998 году - в те времена это был ещё питон v1.5)
Пришли к нам на работу продавцы Курсоров с презентацией :)
У них оказывается утилита с интерфейсом командной строки тоже есть (видимо по типу ClaudeCode) - она называется cursor :)
P.S. И у Google Gemini тоже Gemini-CLI есть (появился в июне 2025 года) - утилита называется gemini :mrgreen:
Залогинился через Google в выскочившем браузуре (у меня есть платная подписка на AI Pro):
Gemini-CLI показывает вот такие модельки:
Как можно видеть тут Auto (как в курсоре), которое само переключается со слабой модельки на сильную когда надо...
Вместе с Gemini-CLI второй вечер пишем программульку-надстройку над утилитой командной строки gemini работающей в режиме чата, чтобы был какой-то более-менее интеллектуальный доступ к старым (и текущим) чатам (бесконечный список на вебе аля ChatGPT уже задолбал) - чото даже работает, правда пока запросы не зависят друг от друга и иногда агенту надо проделать кучу лишней работы, чтобы понять о чём идёт речь (я про последний вопрос, где я попросил его перевести шутку на русский и это заняло порядка 5 минут т.к. сначала надо было найти шутку на английском):
Текущее положение дел можно поглядеть на гитлабе: https://gitlab.com/nedopc/nedochat
Научил Gemini-CLI ( Jimmy ; ) писать сюда на этот форум через MCP puppeteer :lol:
http://www.nedopc.org/forum/viewtopic.php?t=24079
Пользователя создал я, аватару и подпись дал ему тоже я, а также первое сообщение в том топике опять же я написал, а вот второе сообщение Джимми написал уже сам, успешно залогинившись и найдя секретный форум 8)
Статистика сессии:
│  Interaction Summary        │
│  Session ID:                 ................................................
│  Tool Calls:                 98 ( ✓ 81 x 17 )        │
│  Success Rate:               82.7%        │
│  User Agreement:             100.0% (98 reviewed)        │
│  Performance        │
│  Wall Time:                  33m 59s        │
│  Agent Active:               16m 15s        │
│    » API Time:               14m 21s (88.4%)        │
│    » Tool Time:              1m 53s (11.6%)        │
│  Model Usage        │
│  Use /model to view model quota information        │
│  Model                           Reqs  Input Tokens   Cache Reads Output Tokens                                   │
│  gemini-2.5-flash-lite             12        16,225             0           398                                   │
│    ↳ utility_router                12        16,225             0           398                                   │
│  gemini-3-flash-preview            76     1,796,107     1,299,304         5,274                                   │
│    ↳ main                          75     1,792,288     1,299,304         5,149                                   │
│    ↳ utility_loop_detector          1         3,819             0           125                                   │
│  gemini-3.1-pro-preview            38     1,023,616       851,580         3,420                                   │
│    ↳ main                          38     1,023,616       851,580         3,420
Чтобы залогиниться, разлогиниться, залогиниться снова, найти нужный форум и туда написать одно сообщение Джимми израсходовал 17% дневной квоты запросов Gemini :mrgreen:
