Карта интернета
Карта интернета
В прошлом году ресёрчеры хакнули 420000 девайсов с BusyBox (точнее залогинились по дефолтному паролю или вообще без пароля ; ) и пропинговали с их помощью ВЕСЬ интернет в течение суток :)
Взято отсюда: http://dangerousprototypes.com/2013/05/ ... d-devices/
Но самое забавное не это. Забавно то, что они обнаружили, когда все это делали. Выделю сюда интересный абзац:
After development of most of the code we began debugging our infrastructure. We used a few thousand devices randomly chosen for this purpose. We noticed at this time that one of the machines already had an unknown binary in the /tmp directory that looked suspicious. A simple strings command used on that binary revealed contents like synflood, ackflood, etc., the usual abuse stuff one would find in malicious botnet binaries. We quickly discovered that this was a bot called Aidra, published only a few days before.
Aidra is a classic bot that needs an IRC C&C server. With over 250 KB its binary is quite large and requires wget on the target machines. Apparently its author only built it for a few platforms, so a majority of our target devices could not be infected with Aidra. Since Aidra was clearly made for malicious actions and we could actually see their Internet scale deployment at that moment, we decided to let our bot stop telnet after deployment and applied the same iptable rules Aidra does, if iptables was available. This step was required to block Aidra from exploiting these machines for malicious activity. Since we did not change anything permanently, restarting the device undid these changes. We figured that the collateral damage as a result of this action would be far less than Aidra exploiting these devices.
Within one day our binary was deployed to around one hundred thousand devices - enough for our research purposes. We believe Aidra gained a litte more than half of that amount. The weeks after our initial deployment we were able to build binaries for a few more platforms. We also probed telnet every 24 hours on every IP address. Since many devices restart every few days and needed to be reinstalled again, over time we gained machines that Aidra lost. Aidra apparently installed itself permanently on a few devices like Dreambox and a few other Mips platforms. This most likely affects less than 30 thousand devices.
