FZX: standard format and driver for proportional font
English forum about Speccy
cheveron
Post by cheveron »
FZX is a very compact and efficient (although extremely flexible and powerful) standard format to create new fonts for the ZX-Spectrum. It supports proportional fonts, you can print characters anywhere on screen, and it's very easy to use in Sinclair BASIC, or called directly from Assembly routines.
The official FZX font format definition (including several sample fonts) is now available in FZX_Standard.zip, a tape file containing some practical examples is available in FZX.tap.zip, and the source code for the proportional printing driver is available in FZX_Driver.zip.
However let's skip all the tech details and go straight to the interesting stuff! Every character in a regular ZX-Spectrum font is designed using a 8x8 grid like this:
But using FZX, each character definition is fully configurable and uses an arbitrary sized grid, like this:
In the example above, the character pixels are defined in a smaller 5x5 grid, and everything else is configurable. This particular FZX font specifies that all characters are 9 pixels tall ("baseline"), character "a" is located at a distance of 2 pixels from the top ("leading"), character "a" is 5 pixels wide ("width"), and there should be 2 pixels of distance before the next character ("tracking").
All these configurations make it possible to define proportional fonts that are fully flexible and configurable, but still very compact, using about the same amount of memory as a regular font.
Now let's consider a practical example. This is the original Sinclair font:
And here's the same text, using the same font style, but now converted to take advantage of FZX format using proportional spacing:
Although it's the same font style and size, the latter version is more comfortable to read and doesn't take so much room on screen, so it's certainly an improvement!
Another nice feature of FZX format is that it supports quite large fonts, with characters up to 16 pixels wide. Here's another example, this time using a much larger font called "Grotesk" (also supplied in the link above):
So how do you use FZX fonts in practice? It's actually very simple. First, load the driver from tape (together with any FZX font of your choice) and initialize it only once, like this:
CLEAR 59999: LOAD "Sinclair"CODE 60000: LOAD "FZXdriver"CODE 65000: RANDOMIZE USR 65000
Afterwards, simply use PRINT #4 to print your text, for instance:
PRINT #4;AT 0,0;"FZX driver code (c) Einar Saukas"'"FZX font format (c) Andrew Owen"
PRINT #4: FOR f=32 TO 127: PRINT #4;CHR$ f;: NEXT f
Using font "Zaibatsu" for instance (also supplied in this package), the program above will produce the following result:
That's easy, right? :)
As indicated in the screen above, Einar Saukas and I have worked together to create FZX. I concentrated on defining the standard and designing the sample fonts supplied in this package, while he focused on coding it. Anyway everything presented here is open source and royalty-free, so you are welcome to use any of this material in your own programs (even commercial releases) and to create new FZX fonts yourself!
I uploaded all images and files here
My special thanks! :kruto:
GREAT FONTS!
Source code of the printing driver:
; FZX driver - Copyright (c) 2013 Einar Saukas
        org     65000           ; driver address
FONT    EQU     60000           ; font address
MARGIN  EQU     0               ; left margin (in pixels)
STR_NUM EQU     4               ; stream #4
; CREATE CHANNEL AND ATTACH STREAM
DRIVER:
        ld      hl, ($5c53)     ; store system variable PROG in HL
        dec     hl
        ld      bc, 5           ; allocate 5 bytes for channel below BASIC area
        push    bc
        call    $1655           ; call routine MAKE-ROOM
        pop     bc
        ld      hl, CH_DATA + 4
        lddr                    ; copy CH_DATA to new channel space
        ld      hl, ($5c4f)     ; store system variable CHANS in HL
        ex      de, hl
        inc     hl
        inc     hl              ; now HL = allocated address + 1
        sbc     hl, de          ; calculate offset between start of channels
                                ;   area and start of the new channel space
                                ;   (notice the carry flag was already cleared
                                ;   from executing CALL $1655 earlier)
        ld      (STR_OFF), hl   ; attach stream by storing channel address
                                ;   offset in streams table
        ret
STR_OFF EQU $5c10+((STR_NUM+3)*2) ; address of channel offset in streams table
CH_DATA:
        defw    START           ; address of the PRINT # routine
        defw    $15c4           ; address of the INPUT # routine
        defb    'S'             ; channel type 'S'
; PROPORTIONAL PRINT ROUTINE
START:
        ld      hl, P_FLAG      ; initial address of local variables
        dec     (hl)            ; check P_FLAG value by decrementing it
        jp      m, CHK_AT       ; expecting a regular character?
        jr      z, GET_COL      ; expecting the AT column?
GET_LIN:
        cpl
        add     a, 192          ; now A = 191 - char
        inc     hl
GET_COL:
        inc     hl
        ld      (hl), a
        ret
CHK_AT:
        cp      22              ; specified keyword 'AT'?
        jr      nz, CHK_CR
        ld      (hl), 2         ; change P_FLAG to expect line value next time
        ret
CHK_CR:
        inc     (hl)            ; increment P_FLAG to restore previous value
        inc     hl
        ld      bc, FONT
        push    bc
        pop     ix
        cp      13
        jp      z, NEWLINE
CHK_CHAR:
        dec     a               ; now A = char - 1
        cp      (ix+2)          ; compare with lastchar
        jr      nc, UNDEF_CHAR
        sub     31              ; now A = char - 32
        jr      nc, PRINT_CHAR
UNDEF_CHAR:
        ld      a, '?'-32       ; print '?' instead of invalid character
PRINT_CHAR:
        inc     a               ; now A = char - 31
        ld      l, a
        ld      h, 0
        ld      d, h
        ld      e, l
        add     hl, hl
        add     hl, de          ; now HL = (char - 31) * 3
        add     hl, bc          ; now HL references offset/kern in char table
        ld      e, (hl)
        inc     hl
        ld      a, (hl)
        and     63
        ld      d, a            ; now DE = offset
        xor     (hl)
        rlca
        rlca
        ld      c, a            ; now C = kern
        push    hl
        add     hl, de
        dec     hl              ; now HL = char definition address
        ex      (sp), hl        ; now HL references offset/kern in char table
        inc     hl              ; now HL references shift/width in char table
        xor     a
        rld                     ; now A = char shift
        push    af
        rld                     ; now A = (width - 1)
        ld      (WIDTH1+1), a
        cp      8               ; check if char width is larger than 8 bits
        rld                     ; restore char shift/width
        ld      de, $000e       ; same as "LD C,0"
        jr      c, NARROW_CHAR
        ld      de, $234e       ; same as "LD C,(HL)" and "INC HL"
NARROW_CHAR:
        ld      (SMC), de       ; self-modify code to handle narrow/large chars
        inc     hl              ; now HL references next char offset
        ld      a, (hl)         ; now A = LSB of next char offset
        add     a, l
        ld      e, a            ; now E = LSB of next char definition address
        ld      hl, P_COL
        ld      a, (hl)
        sub     c               ; move left number of pixels specified by kern
        jr      nc, ON_SCREEN   ; stop moving if it would fall outside screen
        xor     a
ON_SCREEN:
        ld      (hl), a
        ld      a, (WIDTH1+1)   ; now A = (width - 1)
        add     a, (hl)         ; now A = (width - 1) + column
        call    c, NEWLINE      ; if char width won't fit then move to new line
        ld      bc, (P_COL)
        ld      a, 1
        sub     (ix+0)          ; now A = 1 - height
        add     a, b            ; now A = P_LIN - height + 1
        jp      nc, $0c86       ; call routine REPORT-5 ("Out of screen")
        pop     af              ; now A = shift
        add     a, 191          ; range 0-191
        call    $22aa + 2       ; call PIXEL-ADD + 2 to calculate screen address
        ex      af, af'
                                ; now A' = (col % 8)
        jr      CHK_LOOP
MAIN_LOOP:
        ld      d, (hl)         ; now D = 1st byte from char definition grid
        inc     hl              ; next character definition
SMC:
        ld      c, (hl)         ; now C = 2nd byte from char definition or zero
        inc     hl              ;   (either "LD C,0" or "LD C,(HL)" + "INC HL")
        xor     a               ; now A = zero (since there's no 3rd byte)
        ex      (sp), hl        ; now HL = screen address
        ex      af, af'
                                ; now A = (col % 8), A' = 0
        jr      z, NO_ROTATE
        ld      b, a            ; now B = (col % 8)
        ex      af, af'
                                ; now A = 0, A' = (col % 8)
ROTATE_PIXELS:
        srl     d               ; rotate right char definition grid in D,C,A
        rr      c
        rra
        djnz    ROTATE_PIXELS
NO_ROTATE:
        inc     l
        inc     l
        or      (hl)
        ld      (hl), a         ; put A on screen
        dec     l
        ld      a, c
        or      (hl)
        ld      (hl), a         ; put C on screen
        dec     l
        ld      a, d
        or      (hl)
        ld      (hl), a         ; put D on screen
        inc     h               ; move screen address by 1 pixel down
        ld      a, h
        and     7
        jr      nz, CHK_LOOP
        ld      a, l
        add     a, 32
        ld      l, a
        jr      c, CHK_LOOP
        ld      a, h
        sub     8
        ld      h, a
CHK_LOOP:
        ex      (sp), hl        ; now HL = char definition address
        ld      a, l
        cp      e               ; check if reached next char definition address
        jr      nz, MAIN_LOOP   ; loop otherwise
        pop     hl              ; discard screen address from stack
        ld      hl, P_COL
        ld      a, (hl)         ; now A = column
WIDTH1:
        add     a, 0            ; now A = column + (width - 1)
        scf
        adc     a, (ix+1)       ; now A = column + width + tracking
        jr      nc, EXIT        ; if didn't fall outside the screen then exit
NEWLINE:
        ld      (hl), MARGIN    ; move to initial column at left margin
        inc     hl
        ld      a, (hl)         ; now A = line
        sub     (ix+0)          ; now A = line - height
EXIT:
        ld      (hl), a         ; move down a few pixels specified by height
        ret
P_FLAG:
        defb        0
P_COL:
        defb        MARGIN
P_LIN:
        defb        191
P.S. Also what is the license of actual fonts? Royalty free?
Chloe 8pt Bold
copyright (c) 2013 Andrew Owen
- a narrow monospaced font designed for CRT displays
Geneva 9pt Roman by Susan Kare
copyright (c) 1984 Apple, Inc.
- a Swiss style sans-serif font
Grotesk 24pt Condensed Bold
- a headline font inspired by Hermann Zapf
Lettera 10pt Roman
- a monospaced font inspired by Olivetti typewriters
Sabon 16pt Roman OSF
- a serif font inspired by Jan Tschichold
Sinclair 9pt Roman by Steve Vickers
copyright (c) 1982 Amstrad, plc.
- a proportional version of the Spectrum system font
Soxz 7pt Roman
- a small system font
Zaibatsu 9pt Bold
- a futuristic font
P.P.S. Word "Zaibatsu" looks very much as Russian equivalent of "f*cking awesome" ;)
cheveron
Post by cheveron »
The license for the fonts I designed is royalty free. You can use them as long as you don't modify them. An acknowledgement would be nice but is not required.
At some point I'll probably develop Sabon and Grotesk to include a full suite of fonts, including accents, small caps, and Cyrillic. I just don't have a heap of time to work on it right now. I'm also waiting for Claus Jahn to create an editor so I don't have to do all the work in an assembly file.
The Sinclair font is the example file so you can basically do what you like with it.
The Geneva font is copyright Apple and you should probably get permission from them to use it. On the other hand if you don't they probably won't notice.
Zaibatsu is a Japanese word. The meaning is roughly "mega corporation".
cheveron wrote:Zaibatsu is a Japanese word. The meaning is roughly "mega corporation".
Japanese - such gourmets. :3
cheveron
Post by cheveron »
So, an update. Three editors should be available soon on Windows, Mac, and Linux respectively. I have absolutely nothing to do with these efforts but I'll post the links when I get them.
cheveron wrote:So, an update. Three editors should be available soon on Windows, Mac, and Linux respectively. I have absolutely nothing to do with these efforts but I'll post the links when I get them.
font editors?
cheveron
Post by cheveron »
Shaos wrote:font editors?
Yes. There's a brand new FZX editor from Claus Jahn for Windows, a module for RoboFont for the Mac, and an FZX export option for gbdfed for Linux. None of them are ready yet.
Also, Einar has converted all the fonts that appeared with the Czech program Desktop (which is now public domain apparently):
DesktopFZX.zip (48493 bytes)
DesktopFontEditorFZX.zip (22477 bytes)
It should be relatively easy to create font converter for Windows that may convert any vector font from Windows to FZX with rasterization to proper size
P.S. I moved your archives to our upload folder
cheveron
Post by cheveron »
Shaos wrote:P.S. I moved your archives to our upload folder
You might want to add Einar's latest set too:
DesktopKud1FZX.zip (38027 bytes)
Thanks
P.S. I reupload your file here again ;)
Mediafile has really disturbing advertizing practices as new windows with fishy texts...
cheveron
Post by cheveron »
Shaos wrote:Mediafile has really disturbing advertizing practices as new windows with fishy texts...
Not sure why Einar uses it. I just use DropBox.
Ask him to register here - we will be more than happy to host his files ;)
FZX Editor 0.952 for Windows
https://www.spectrumforeveryone.co.uk/technical/zx-modules-software/
P.S. Link fixed and image uploaded right here in April 2021
P.P.S. Link changed again in January 2023
