Open source CMOS reusable blocks for LTspice IV and Magic 8
English forum for http://www.nedopc.org/nedopc
Post Reply
Contact:
In January 2015 I was playing with LTspice IV and decided to create a number of reusable blocks of CMOS logic for our nedoPC.org community.
Later I started adding CMOS layouts, created in Magic VLSI Layout Tool v8.0, and some were even silicon proven in October 2015 for CMOS 0.5um technology...
http://nedopc.org/nedopc/files/nedocon-cmoslib.zip (693K) v1.0alpha (March 2016)
This PUBLIC DOMAIN archive consists of a number of close to reality
CMOS blocks for LTspice IV in form of ASC and ASY files that you need
to copy (from "sym" subfolder) to
C:\Program Files\LTC\LTspiceIV\lib\sym\
You can see internals of any block and you can use it anywhere.
Tests are also included with screenshots of oscillograms. Enjoy!
cmos-not - NOT gate (invertor)
cmos-nand - 2-input NOT-AND gate
cmos-nand3 - 3-input NOT-AND gate
cmos-nor - 2-input NOT-OR gate
cmos-nor3 - 3-input NOT-OR gate
cmos-tgate - transmission gate (SPST switch)
cmos-tgate2 - 2 transmission gates connected as SPDT switch
Then it will be xor, nor-and, rs-trig, d-trig, mux2, mux4, mux8 etc.
P.S. Used book:
Uyemura, John P. Circuit design for CMOS VLSI. 1992 (11th printing 1998) ISBN 0-7923-9184-5
P.P.S. On January 8th, 2016 I started adding silicon proven Magic layouts here...
Contact:
cmos-not
Inverter cmos-not (with added parasitic capacitor on output to simulate gate delay - about 0.1ns):
Testing:
Voltage transfer curve:
P.S. In January 2016 CMOS layout 0.5um for Magic v8.0 was added here (silicon proven in October 2015):
Simulation of 1 GHz input (SPICE model extracted from layout by Magic and simulated by ngspice):
Contact:
cmos-nand
Two input NAND block cmos-nand (with parasitic capacitor on output to simulate gate delay - about 0.2ns):
Test schematics:
Blue curve is output when both inputs connected together and two other curves for cases when one of the inputs tied to high voltage.
P.S. Magic layout and simulation (silicon proven in October 2015):
Both inputs changed, then just one - 1st one (A) and 2nd one (B):
1GHz signal on both inputs:
Contact:
cmos-nor2
Two input NOR cmos-nor
Test schematics:
Blue curve is output when both inputs connected together and two other curves for cases when one of the inputs tied to the ground.
Contact:
cmos-tgate
Single CMOS switch (transmission gate) cmos-tgate
Contact:
cmos-tgate2
SPDT CMOS-switch (2 transmission gates) cmos-tgate2
Contact:
Three input NAND block cmos-nand3
Test schematics:
Curve is moving if we connect different number of inputs to V+
Contact:
Three input NOR block cmos-nor3
Test schematics:
Curve is moving if connect different number of inputs to ground
Contact:
Re: CMOS reusable blocks for LTspice IV (PUBLIC DOMAIN)
I moved library elements to folder "sym"
Contact:
Re: Open source CMOS reusable blocks for LTspice IV and Magi
I decided to add "silicon proven" layouts of CMOS reusable blocks to the same archive...
Post Reply
