[Soft] XORLib - old school game library
English forum for http://www.nedopc.org/nedopc
Source code under MIT-license:
https://gitlab.com/shaos/xorlib
Wiki with documentation (still empty):
https://gitlab.com/shaos/xorlib/wikis/home
XORLib - old school game library licensed under the MIT License
See for more info: http://www.xorlib.com
#ifndef _XORLIB_H_
#define _XORLIB_H_
#define XORLIB_VERSION 0x0002 /* v0.2 */
/* Available external macros:
   PIC32NTSC - for PIC32MX with 8 MHz crystal and NTSC timings (black and white modes)
   PIC32NTSCQ - for PIC32MX with 14.31818 MHz crystal (with possible color burst mode)
   PIC32PAL - for PIC32MX with 8 MHz crystal and PAL timings (black and white modes)
   PIC32VGA - experimental mode for PIC32MX connected to VGA monitor (future)
   DOS32 - for 32-bit DOS
   DOS16 - for 16-bit DOS
   TERM - emulation of some basic functions through terminal (ncurses)
   DECODEGIF - compiled with GIF decoder (xdec_gif.c)
   DECODEJPG - compiled with JPEG decoder (xdec_jpg.c)
/* NTSC compatible video modes - 320 bits per line */
#define XOMODE_320x200_MONO    0 /* Black and white 320x200 */
#define XOMODE_160x100_GRAY5   1 /* Pseudo mode on top of mode 0 with 5 shades of gray */
/* NTSC compatible video modes - 640 bits per line */
#define XOMODE_640x200_MONO    2 /* Black and white 640x200 */
#define XOMODE_213x200_GRAY4   3 /* Pseudo mode on top of mode 2 with 4 shades of gray */
#define XOMODE_160x200_COL15   4 /* Color burst mode over 640x200 with 15 unique colors (4 pallets) */
#define XOMODE_160x100_COL120  5 /* Pseudo mode on top of mode 4 with about 120 unique dithered colors */
/* NTSC compatible video modes with additional hardware - 640 bits per line */
#define XOMODE_320x200_COL4    6 /* CGA-like mode with configurable 4-color palette */
#define XOMODE_160x200_COL16   7 /* Color mode with standard 16-color palette */
/* NTSC compatible video modes with additional hardware - 1280 bits per line */
#define XOMODE_320x200_COL16   8 /* EGA-like mode with standard 16-color palette */
#define XOMODE_160x200_COL256  9 /* Predefined 256-color RGB-palette (including 64 shades of gray) */
/* NTSC compatible video modes with additional hardware - 2560 bits per line */
#define XOMODE_640x200_COL16  10 /* EGA-like mode with standard 16-color palette */
#define XOMODE_320x200_COL256 11 /* Predefined 256-color RGB-palette (including 64 shades of gray) */
/* VGA compatible video modes (just a placeholder for future) */
#define XOMODE_640x350_COL16  12 /* EGA-like mode with standard 16-color palette */
#define XOMODE_640x480_COL16  13 /* VGA-like mode with standard 16-color palette */
#define XOMODE_800x600_COL16  14 /* SVGA-like mode with standard 16-color palette */
#define XOMODE_ENHANCED_VGA   15 /* Placeholder for other VGA modes */
/* Standard colors (directly supported only in modes >=7 and simulated in mode 5) */
#define XOCOLOR_BLACK           0
#define XOCOLOR_BLUE            1
#define XOCOLOR_GREEN           2
#define XOCOLOR_CYAN            3
#define XOCOLOR_RED             4
#define XOCOLOR_MAGENTA         5
#define XOCOLOR_BROWN           6
#define XOCOLOR_WHITE           7
#define XOCOLOR_GRAY            8
#define XOCOLOR_BRIGHT_BLUE     9
#define XOCOLOR_BRIGHT_GREEN   10
#define XOCOLOR_BRIGHT_CYAN    11
#define XOCOLOR_BRIGHT_RED     12
#define XOCOLOR_BRIGHT_MAGENTA 13
#define XOCOLOR_BRIGHT_YELLOW  14
#define XOCOLOR_BRIGHT_WHITE   15
#define XOCOLOR_INVERT         -1
/* Configuration flags (bits 0..15 for supported graphics modes) */
#define XOCONFIG_BIGENDIAN 0x00010000 /* bit 16 */
#define XOCONFIG_32BITINT  0x00020000 /* bit 17 */
#define XOCONFIG_NTSCTV    0x00040000 /* bit 18 */
#define XOCONFIG_PALTV     0x00080000 /* bit 19 */
#define XOCONFIG_NETWORK   0x00100000 /* bit 20 */
#define XOCONFIG_KEYBOARD  0x00200000 /* bit 21 */
#define XOCONFIG_MOUSE     0x00400000 /* bit 22 */
#define XOCONFIG_SDCARD    0x00800000 /* bit 23 */
#define XOCONFIG_CDROM     0x01000000 /* bit 24 */
/* Control bits */
#define XOCONTROL_LEFT1  0x0001 /* bit 0 */
#define XOCONTROL_RIGHT1 0x0002 /* bit 1 */
#define XOCONTROL_UP1    0x0004 /* bit 2 */
#define XOCONTROL_DOWN1  0x0008 /* bit 3 */
#define XOCONTROL_LEFT2  0x0010 /* bit 4 */
#define XOCONTROL_RIGHT2 0x0020 /* bit 5 */
#define XOCONTROL_UP2    0x0040 /* bit 6 */
#define XOCONTROL_DOWN2  0x0080 /* bit 7 */
/* Some control aliases */
#define XOCONTROL_FIRE   XOCONTROL_LEFT2
#define XOCONTROL_X      XOCONTROL_UP2
#define XOCONTROL_Y      XOCONTROL_LEFT2
#define XOCONTROL_A      XOCONTROL_RIGHT2
#define XOCONTROL_B      XOCONTROL_DOWN2
#define XOCONTROL_UP     XOCONTROL_UP1
#define XOCONTROL_LEFT   XOCONTROL_LEFT1
#define XOCONTROL_RIGHT  XOCONTROL_RIGHT1
#define XOCONTROL_DOWN   XOCONTROL_DOWN1
/* Optional control bits */
#define XOCONTROL_LSHOULDER 0x0100 /* bit 8 */
#define XOCONTROL_RSHOULDER 0x0200 /* bit 9 */
#define XOCONTROL_KEYREADY  0x1000 /* bit 12 - keyboard buffer is not empty */
struct xoimage
 short width, height;     /* width and height of the image in pixels */
 unsigned char pitch;     /* pitch in bytes (to calculate vertical offset) */
 signed char bpp;         /* bits per pixel (negative for grayscale) */
 unsigned char *data;     /* pointer to the image data */
 unsigned char *mask;     /* optional pointer to the mask */
/* Some macros */
#define VIDEOSCREEN (struct xoimage*)0
#define TEXTNORMAL xotextattr(XOCOLOR_BRIGHT_WHITE,XOCOLOR_BLACK)
#define TEXTINVERT xotextattr(XOCOLOR_BLACK,XOCOLOR_BRIGHT_WHITE)
#ifdef __cplusplus
extern "C" {
#endif
/* System functions */
unsigned long xoconfig(void);                   /* return configuration bits (see above) */
unsigned long xocontrols(void);                 /* return state of controls (see above) */
unsigned long xoframes(void);                   /* return frames counter */
unsigned long xoseconds(void);                  /* return seconds counter */
int xocurline(void);                            /* return current line of the frame (0 is 1st line of the video) */
void xowaitretrace(void);                       /* wait for vertical retrace interval */
void xodelay(int ms);                           /* delay in milliseconds */
int xokeyboard(int *scancode);                  /* return ASCII code from keyboard */
int xomouse(int *px, int *py);                  /* return mouse state (bit 0 - left button, bit 1 - right button) */
/* Graphics functions */
int xoinit(short m);                                    /* set graphics mode -> 0 if failed */
int xopalette(short p);                                 /* set predefined palette (for color modes) -> 0 if invalid id */
int xomode(void);                                       /* get graphics mode -> -1 if not yet set */
int xowidth(void);                                      /* return width of the screen */
int xoheight(void);                                     /* return height of the screen */
int xocls(void);                                        /* clear the screen */
int xopixel(short x, short y, char c);                  /* draw a pixel (-1 means inversion) -> 0 if invalid args */
int xoget(short x, short y);                            /* get state of the pixel (actual value) -> -1 if not supported */
int xoline(short x1, short y1, short x2, short y2, char c); /* draw a line with a color (-1 means inversion) */
int xorect(short x, short y, short w, short h, char c); /* draw a rectangular with a color (-1 means inversion) */
int xobar(short x, short y, short w, short h, char c);  /* draw a solid rectangular with a color (-1 means inversion) */
int xocircle(short x, short y, short r, char c);        /* draw a circle with a color (-1 means inversion) */
int xoellipse(short x, short y, short rx, short ry, char c); /* draw an oval with a color (-1 means inversion) */
int xoarc(short x, short y, short rx, short ry, short a1, short a2, char c); /* draw an arc of oval (-1 means inversion) */
int xopie(short x, short y, short rx, short ry, short a1, short a2, char c); /* draw a solid piece of oval (-1 means inversion) */
int xofill(short x, short y, char c);                   /* fill a region with a color (inversion is not applicable) */
int xopoly(char c, short n, short *a);                  /* draw a polygon from array {x,y, x,y, etc. } */
int xotextattr(char i, char p);                         /* set text color attributes (ink, paper) */
int xochar(unsigned char x, unsigned char y, char c);   /* print character using text location */
int xostring(unsigned char x, unsigned char y, char* s);/* print string using text location */
int xoprintf(char* s, ...);                             /* print string to current position with a possible scroll */
int xouserchar(char c, unsigned char* p);               /* add user character with code 0...31 using 8 bytes -> 0 if error */
int xotextwidth(void);                                  /* return text screen width */
int xotextheight(void);                                 /* return text screen height */
int xogray5(int i);                                     /* 5 shades of gray function (0,1,2,3,4) returns ASCII code */
int xoswitchscreens(void);                              /* switch primary and secondary screens (in case of double buffering) */
int xouseprimary(void);                                 /* use primary screen (default) */
int xousesecondary(void);                               /* use secondary screen (in case of double buffering) */
unsigned char* xodirectline(short y);                   /* return pointer to video line for direct access */
unsigned char* xoprevline(unsigned char *p);            /* return pointer to the previous video line for direct access */
unsigned char* xonextline(unsigned char *p);            /* return pointer to the next video line for direct access */
int xocopy(struct xoimage* d, struct xoimage* s);       /* copy one image into another with mask if presented */
int xorcopy(struct xoimage* d, struct xoimage* s);      /* copy one image into another with xor -> 0 if not supported */
int xopcopy(struct xoimage* d, struct xoimage* s, short x, short y, short w, short h); /* partial copy without mask */
int xopcopyk(struct xoimage* d, struct xoimage* s, short x, short y, short w, short h, char c); /* partial copy with a key color */
int xocopytxt(struct xoimage* d, const char* s, short x, short y); /* render text to image coordinates x,y */
int xocopyxbm(struct xoimage* d, const unsigned char* s, short w, short h);  /* copy image from XBM */
int xocopyeta(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from ETA frame */
int xocopymyg(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from MYG frame */
int xocopygif(struct xoimage* d, const unsigned char* s, short f, short *t); /* copy image from GIF frame (if GIF decoder is enabled) */
int xocopyjpg(struct xoimage* d, const unsigned char* s); /* copy image from JPEG (if JPEG decoder is enabled) */
#ifdef __cplusplus
#endif
#endif
Re: [Soft] XORLib - old school game library for PIC32 and DO
Added basic support for CGA composite mode :o
But with 32-bit processor and it's tested only in DOSBox :roll:
P.S. Now the same program could be compiled for both PIC32 and DOS32 :kruto:
jardik
Post by jardik »
Hello,
I have a questions:
1. How can I change the program and font? Where can I get the fonts, if so, what editor I can use ??
The best would be a step by step tutorial on how to import a different font in the program.
2. How can you add a program to gif or jpeg image ?? if possible through step by step instructions and mentioning any specific editor for converting the image into the array.
thank you.
1. you can use any 8x8 raster font to substitute "nedofont" - it has to be array of bytes that starts with space character (with code 32 or 0x20):
const unsigned char font8x8[224][8];
also you can use any raster font and draw it using direct access to the memory through xodirectline function in your program
2. to prepare GIF image for Xorya you need to use free GIMP image editor and palette Xorya.gpl to convert any image to 16-color 160x200 (4:3 or 16:9 ratio) then should use function xocopygif (it's not yet fully integrated into the library)
P.S JPG will look much worse in 16 colors so I'll support it later...
